Bit Torrent help?
OrbitzXT
1,969 (0.29/day)
New York City
System Name AX-01
Processor Intel Core i5-2500K @3.7 GHz
Motherboard ASRock Z68 Extreme3 Gen3
Cooling Zalman 9700
Memory Kingston HyperX T1 Series 8GB DDR3 1600 MHZ
Video Card(s) GTX 590
Storage Intel X25-M
Display(s) 42" Samsung LED HDTV
Case Antec Twelve Hundred
Audio Device(s) HT | OMEGA STRIKER 7.1
Power Supply Kingwin 1000W
Software Windows 7 64-Bit
I'm somewhat new to using bit torrent so I'm not quite sure whats wrong here. I'll start by saying I've successfully downloaded a number of files, so I assume based on that that my settings are okay, but I'm here to find out what the deal is. So I'm downloading another file now with nearly 1700 seeds and 100,000 leechers, all the leechers seem stuck at the same amount. For example the availability is 0.893 and they're all at 89.3%, and I eventually get to this point too, never to move beyond. I've left it running for days and the availability doesn't change and I never get any farther on the download.
This seems to happen quite often, on both relatively new torrents and old ones as well. I have a linksys router and have the ports open, am using that utorrent client, I've tried Bit Tornado as well but I like utorrent better. So whats the deal with these situations, is there anything I can do to connect to seeds and get my file?
Lastly, a friend explained to me if you use all your upload bandwidth it makes your internet very slow or something, and I should limit my upload speed so I can continue to use my internet while the downloads are going. My max upload is something like 500 kbps, and download is about 9000 kbps. With only one torrent downloading, I limited the upload bandwidth to 20 kb/s, figuring thats a good enough amount. Even with this, my internet becomes unusable. The BT downloads reach very high speeds, I was downloading at 1.01 MB/s before.
The other weird thing is the second I open a torrent, before its even connected to anyone and started downloading/uploading, the internet becomes very slow. Why would simply opening the program slow my internet down? The one torrent I have downloading just before was downloading at 200 kb/s, and uploading at about 12 kb/s, this shouldn't be stopping up my internet. It won't work quickly again until I "Repair" the internet connection in network connections. I have encryption on, it helps a lot since I think my ISP (Road Runner) prevents me from downloading without it on. So any suggestions or thoughts?
umm i dont think talking about torrents and other piracy programs is .. legal?.. here so yeah..
I don't want this thread to turn into an argument about piracy or legality but I didn't say I was downloading movies or music, not every file available for download via BitTorrent is copyrighted. So can anyone help me?
cough cough use uTorrent its the best cought cough
Try turning off encryption, and using non standard ports. I use something in the 65k or 25k range.
What you have is a "fake" torrent. (Normally get them on free sites, like meganova, etc)
Always check the torrents before you download them. If you notice all the peers are stuck on a certain percentage, then it wont happen. Also, it "says" it has seeds, but in the actual torrent program, are you connected to any seeds?
I dont see why your net is slowing down before your torrent is downloading. Normally the net slows down because people set their upload too fast, but if you have it at 1/3 of your max upload, you should be right.
Ah thats a very useful piece of info, I didn't know there were fakes, Thanks! As for my internet slowing down I still don't understand that. The second a torrent starts up on either client I've tried I'll get websites timing out and the internet becomes unusable. While the internet stays slow, torrents can still download quickly as I said in my original post. My internet remains slow while the torrents are barely using any bandwidth or downloading even at 1 MB/s. It'll say that there are seeds but I'll never connect to one. What exactly are the purpose of fakes? Are they just there to inconvenience people?
BitTorrent is completely legal in every way shape and form. It's what you're downloading that matters.
