- May 31, 2006
- 1,156 (0.17/day)
System Name | Alienware laptop R4 |
Processor | intel i7-3610M @ 2,30Ghz |
Motherboard | dell? |
Cooling | 2 built in laptop cooling fans |
Memory | 16GB DDR3 1600mhz |
Video Card(s) | AMD Mobility Radeon HD m290x 4GB GDDR5 |
Storage | 256 ssd and 512ssd |
Display(s) | laptop screen 17.3" 1920x1080 + LG 22" inch LCD HD 1920 x 1200 |
Case | My laptop back pack case |
Audio Device(s) | Sound Blaster |
Power Supply | laptop brick |
Software | Windows 7 Home Premium 64 bit |
Are you using your laptop screen and external LCD at the same time? You might have to set it to only use the external display, as the video will only play if the player is on the primary display which is your laptop LCD unless you disable it.
yes im only using one screen at a time i will try downloading another program tomorrow thanks for the help so far
