Browsers using max bandwidth when downloading
FireFox
The Power Of Intel
7,507 (1.84/day)
Germany
Processor Intel i7 10700K
Cooling 2x Black Ice Nemesis GTX 480 - 1x Black Ice Nemesis GTX 420 - D5 VPP655P - 13x Corsair LL120 - LL140
Storage Samsung 970 EVO PLUS 500GB/1TB - WD Blue SN550 1TB - 2 X WD Blue 1TB - 3 X WD Black 1TB
Case Corsair Obsidian 1000D
Mouse Logitech G502 spectrum
Keyboard Virtuis Advanced Gaming Keyboard ( Batboard )
Software Windows 10 Enterprise/Windows 10 Pro/Windows 11 Pro
Hi TPU fellows
I don't remember exactly since when but for sure over a year there is an issue with my internet/Windows or whatever it is which i have always ignored maybe because i was too lazy to open a Thread or maybe because it doesn't/didn't really bothers me, anyway here is the thing, when i download a file let's say Heaven Benchmark from TPU the Browser ( Mozilla - Edge - Chrome ) uses all Bandwidth available ( 5Mb/s ) at this point while the file is downloading i cant use the internet because if i open a new page to do something else on the internet it will shows no Internet connection and if my Wife is using her Phone connected via WiFi she wont have internet, the only Internet page that it works is the one from where i am downloading the file ( TPU ) i was looking for answers/solutions on the Web but i didn't find anything helpful and the only thing i found was How to limit bandwidth for Windows Update which it is not my case.
I checked Firefox and Windows settings to see if there was an option to limit the bandwidth usage but didn't find anything the funny thing is that i don't remember having that issue with Windows 7 but maybe i could be wrong, right now i am using NetLimiter 4 as a temporary solution to limit the bandwidth usage.
Any idea of what is happening?
Thanks in advance for your help.
FireFox
The Power Of Intel
7,507 (1.84/day)
Germany
Bump.
Where are you people
Kursah
Super Moderator
14,764 (2.18/day)
Missoula, MT, USA
System Name Kursah's Gaming Rig 2018 (2022 Upgrade) - Ryzen+ Edition | Gaming Laptop (Lenovo Legion 5i Pro 2022)
Processor R7 5800X @ Stock | i7 12700H @ Stock
Motherboard Asus ROG Strix X370-F Gaming BIOS 6203| Legion 5i Pro NM-E231
Cooling Noctua NH-U14S Push-Pull + NT-H1 | Stock Cooling
Memory TEAMGROUP T-Force Vulcan Z 32GB (2x16) DDR4 4000 @ 3600 18-20-20-42 1.35v | 32GB DDR5 4800 (2x16)
Video Card(s) Palit GeForce RTX 4070 JetStream 12GB | CPU-based Intel Iris XE + RTX 3070 8GB 150W
Storage 4TB SP UD90 NVME, 960GB SATA SSD, 2TB HDD | 1TB Samsung OEM NVME SSD + 4TB Crucial P3 Plus NVME SSD
Display(s) Acer 28" 4K VG280K x2 | 16" 2560x1600 built-in
Case Corsair 600C - Stock Fans on Low | Stock Metal/Plastic
Audio Device(s) Aune T1 mk1 > AKG K553 Pro + JVC HA-RX 700 (Equalizer APO + PeaceUI) | Bluetooth Earbuds (BX29)
Power Supply EVGA 750G2 Modular + APC Back-UPS Pro 1500 | 300W OEM (heavy use) or Lenovo Legion C135W GAN (light)
Mouse Logitech G502 | Logitech M330
Keyboard HyperX Alloy Core RGB | Built in Keyboard (Lenovo laptop KB FTW)
Software Windows 11 Pro x64 | Windows 11 Home x64
What's your ISP provisioning for upload as well? I'm assuming 50/5? 50/4? 50/2? Errr. wait you said 5Mbps? So you're maybe at 5/.2 (256Kbps)?
So one issue that can happen is at maximum bandwidth usage, if you're weak on upload bandwidth provisioning, it'll choke everything else down and out. Downloads like that require 2-way transactions which requires available bandwidth both directions to be maintained. Or if the IO is overloading a home grade router, that could cause it too. Many have very weak CPU's, when the bandwidth/IO gets near peak or provisioned speeds, they struggle and drop devices.
I'm thinking you're hitting line capacity, and it almost sounds like a limit of the service rather than the router.
For bandwidth limiting in browsers, I'm assuming you've seen this article since you're using NetLimiter already:
https://www.howtogeek.com/347711/how-to-limit-any-applications-bandwidth-on-windows/
https://www.technorms.com/36800/limit-bandwidth-usage-firefox-chrome-opera
I'm at work right now, so limited on time...but I'm intrigued and would like to help get this solved. If you run a continuous ping to google.com ( ping -t google.com ) when you initiate a download, does it drop packets or just raise in latency. It should do the latter, but if its doing the former it comes down to hitting some hard limits and what you're doing now is one solution, increasing bandwidth or going with a different type if ISP service with higher bandwidth would be beneficial as well.
Another option depending on your router is to bandwidth limit devices (usually by IP address on more simple router or ones that take dd-wrt), or to use packet prioritization via QoS configurations if your router is capable of such but doing so and doing it "properly" may reduce your bandwidth peaks as you have to manage what you have meaning you have to maintain within the envelope of your provisioned bandwidth to properly QoS your traffic. It can be done, and might be useful here even if you lose a little peak speed for the sake of having more consistent connectivity for your devices.
5,731 (1.04/day)
West Midlands. UK.
System Name Ryzen Reynolds
Cooling Raijintek Leto Pro
Power Supply Corsair VS 550w
Mouse Zalman ZM-M401R
Keyboard Razor Lycosa
Just browsers? have you tried maxing your bandwidth on say torrents or a streaming service to see if the same thing happens? even though downloading a file from www does require both upload and download the upload requirement and overhead would be very minute and as you are still getting your full 5Mbps DL I can't see that being the issue here.
FireFox
The Power Of Intel
7,507 (1.84/day)
Germany
Download 50Mbps and Upload 10Mbps
For bandwidth limiting in browsers, I'm assuming you've seen this article since you're using Net Limiter already:
Yeap i saw it already, that is why i got NetLimiter
I am sure it is not an ISP problem considering i have never faced that issue before plus i am 200% sure this issue started since i am using Windows 10 before that everything was ok.
Maybe you should try downloading something from TPU and tell me if your Browser does the same ( something above 3GB )
339 (0.14/day)
Do you have a spare drive or can check it on a virtual machine with diff op.sys?
Did you check your networkcard setup? Are you sure there wasnt any firmware upgrade on your router? It happen on lan (cable) or wifi or both or either. If your wife browsing on phone than you cant use net too?
Did you restart or power off your router? If not try it turn off for a minute then turn on.
FireFox
The Power Of Intel
7,507 (1.84/day)
Germany
I solved the issue was something stupid but i didn't think about it before
The Ethernet cable was plugged into the Aquantia 5G / 10G Lan port i unplugged the Cable and plugged it into the other LAN port and now it is working without issue, downloaded a file from TPU ( Final Fantasy ) and at the same time used my Phone connected via WiFi and can navigate on the internet on my PC while downloading thing that i couldn't do before.
Regeneration
NGOHQ.COM
3,151 (0.44/day)
If you have a proper router, you can set priority for specific ports/services via QoS. In this case, HTTP ports (80,443).
With QoS, there is no need for 3rd party software.
FireFox
The Power Of Intel
7,507 (1.84/day)
Germany
My Networking knowledge is almost 0 that's why i ended up using a 3rd party Software.
Hehe, yeah, sometimes it happen, glad to everything ironed out :)
Despite the fact i managed to solve the issue i am still concerned about why the Aquantia 5G / 10G Lan port was behaving like that, maybe because it's just for High-speed Internet connections?
339 (0.14/day)
Yes it seems interesting, probably some priority related thing.
