Can i add memory slots to my mobo?
30 (0.01/day)
System Name Yes
Processor i5 10400f
Cooling stock intel
Memory 32gb
Video Card(s) GTX 1660 Super 6gb
Storage m.2, ssd, +hdd
Display(s) 1080p
Case HAF
I have a motherboard with only 2 Slots for memory. Now i was just thinking, could you sauter wire to another memory slot on some circuit board and expand your motherboard max capacity? I know in resource manager it says 2/4 dimms occupied so I know my chipset certainly isn't limited to only 2 mem slots.
Logical answer is no.
There isn't any way to wire up extra memory slots as far as I know, you are much better off just going out and buying higher capacity memory sticks instead
No chance. You are stuck with two RAM modules if you have two slots. Check maximum amount of supported RAM memory by your motherboard and buy two higher capacity sticks.
That's not how memory controllers work. You can't simply add another memory slot in series or parallel. On top of that, the wires would have to be very short, due to the high speeds that DRAM operates at today, or you'd get memory corruption.
As others have said, no, it's no possible to solder extra memory slots to a board.
You could always try, post the results after you're done experimenting with that mobo.
edit ~ j/k in case anyone gets offended.
No, you can't add more slots. Check your mobo manual to see if you can add higher capacity RAM.
It's pretty much a PCB limitation, if there is no physical space to accommodate them, there is nothing you can do about it.
Even if the OEM board has the position for more ram slots ( and some Budget OEM Boards do) you cannot Solder ram Carriers to the Board as modern boards can be up to 7 layers thick ( and then you would need a Relevant compatible new Bios)
As Others have said see if you can install higher Density Ram ( more Gigs)
Your only other Alternative is to source a better motherboard with more features
Even if you can put the ram slots on the board somehow your memory controller wont run them properly. For all the hassle you would need for this to do, it would be better just to buy a board with more ram slots.
Honestly I've been toying with the idea of trying this out. As you say, some motherboards (at least in the olden days) looked like they had all the wiring done for more slots, but they just skipped the slots. IIRC there was a dude that soldered a PCIe expansion slot to a server motherboard and that worked. Don't take my word for it though, it's been awhile since I read about it.
Is it worth it though? Absolutely not. But it might make for an interesting project if you have the skills.
I have a foxcon P55A ATX Board (1156 CPU) That has the Placeholder on the motherboard for an IDE interface ( never fitted )
Bios on that board shows the interface but greyed out
So in that Respect i suppose its possible to retrofit the IDE interface ( foxcon site has Bios for the Board Variant with IDE)
But its not worth Potentially wreaking a working Board
One Day if i am Boored and Drunk/stupid enough i might attempt it
Ps if someone gives me an Working 1156 MATX Board
Then i have nothing to lose trying the mod out apart from a few grams of solder
You may have some options to help in a different way for a lack of memory, one thing you can do is add a small SSD drive like say a 32GB or 64GB SSD and then set that up as a Page File only drive and then increase the page file size to match the SSD drive. I think I have seen a PCI-e slot Ram card before in our R&D department but can't comment on how they do. Oh yeah it was not a PCI-e Ram card it was a PCIe DRAM SSD, sorry about that.:oops:
What motherboard do you have anyway?
Something tells me that it would be fused off somewhere on a modern mobo, all done in the name of fun and profit. :rolleyes:
Thats a memory slot extension right? NICE! Wonder how the performance is on it.
It would all be dependent on the cpu/MoBo. Certainly not an elegant solution ,but a solution nonetheless. ;). It does make you wonder though , how much would it take to saturate a dimm slot
If I recall correctly they have one that plugs into the PCi-E lanes too. Apples been doing this for years ,that's how they've always installed there ram with some kind of offset card slot system, but extending for the op's purpose is different
Right on, I could have sworn I saw a PCIe one in our R&D but it was a bit ago and my old memory (pun) needs a upgrade.
