- Jun 14, 2021
- 2,522 (1.73/day)
- UK
Fans For this case that i got free ,what a bargin that was
It is a nice case to build in for my built from scratch
I see it goes for £99 pound on Amazon
Thermaltake Versa H18 Tempered Glass Black Spcc Micro ATX Gaming Computer Case i have all-ready put the motherboard in in the case. looking on Amazon to see what fans i should get.I am thinking of going fot these.
upHere 120mm 3PIN Case Fan with White LED Low Noise High airflow for Computer Cooling,CPU Cooler,PF120WT3-3 The price is right and they get lots of good reviews.
Or these black ones Apparently they don,t come with any instructions
The black ot white ones are £11.
Or these ones £13 EZDIY-FAB 120mm Blue LED Fan, Dual-Frame LED Case Fan for PC Cases, High Airflow Quiet,CPU Coolers, and Radiators,3-Pin-3-Pack The up
The UPHERE also come in red or blue.I was thinking of putting one of them in that heavy old case i got sometime ago.
TIPS:
Specification:*The 3PIN interface of the fan and the power 4PIN interface cannot be connected to the computer at the same time.*This part gets me confused can someone fill me in?
There are only 2 Fan headers on the board. Photo of my case build where do i connecte the Molex which has has male and female connections? There were none of the tiny power leds on the case just the Molex plug.
- Size:120*120*25mm
- Fan Speed:1300(±10%)RPM
- Noise Level:14.8dB.A
- Airflow:32.7CFM
- Bearing:Hydro Bearing
- Rated Voltage:DC12V
- Rated Power:1.7W
- Interface:Motherboard 3PIN / power supply 4PIN
- Do i need to get a fan hub for these?
