Cases with removable dust filters on all intakes?
Vertrucio
29 (0.01/day)
Processor AMD Phenom II X4 965 3.4GHz
Motherboard ASUS M4A79 Deluxe
Cooling Air
Memory 8GB DDR2 (forgot the Hz)
Video Card(s) Gigabyte Radeon HD 7950 3GB (1000mhz/1250mhz)
Storage 120GB Corsair SSD, 1TB Seagate HD
Display(s) 2x Samsung Syncmaster T240 24" LCD (1920x1200)
Case Corsair C70
Audio Device(s) SB X-Fi Xtrememusic
Power Supply Antex Basiq 550W
Software Windows 7 64bit
I'm looking for a good case with removable (cleanable) dust filters on all air intakes. I prefer not to have a case with open grills unless they all have dust filters on them. Mid tower or larger, and $200 or less.
I live in a very dusty home with cats that shed and kick up even more dust. My computer is also on the floor, so it just seems like every week I have to clean dust out of my system since it's an older case with open front grills (that just get clogged with dust). I've also had parts burn out from their heat sinks being clogged from dust in years past.
I've done searches online, but a lot of reviews and tech specs don't list dust filters, even if some cases have them. So it's been tricky finding one.
I believe the antec 1200 has dust filters on the fans. I'll text my brother and check, but I'm pretty sure it does.
edit: the front and side fans have dust filters on them (i.e. all the intake fans)
the coolermaster mystique 632 does,i cleaned mine just this morning
To contribute to my own thread, looks like the Cooler Master HAF X has filters on all vents except for one for the bottom power supply. This info was buried in an amazon review of all places. No word on if they're removable, or at least easily accessed. I've found a few cases that do have filters, but they're sitting behind metal grills that you have to unscrew if you want to clean.
Thanks for the other options listed, please keep the recommendations coming.
Silverstone Raven 2 Evolution (RV02-E) or the new RV03, but I don't like the air filtering as well.
Antec Nine Hundred Two Black is what I have. Both front fans have removable filters so it can very easily be cleaned using a small vacuum. I don't remember if the optional side fan has a filter on it...
edit: actually I just looked at a case review on hardwaresecrets and it in fact does have a dust filter on the side...don't know if it is removable though.
Source: http://www.hardwaresecrets.com/article/696
Another vote for the Raven 2, unsure of the price in US though.
alternative you could nick your mrs/girlfriends pantyhose and cover the fan in an offcut from them :)
im really disappointed with the filters that most cases come with and the fact that u have to do this and that to remove them for cleaning, that's why u should take matters in your own hands.
here are a couple of ideas
this is my favorite result, still using it
case is Antec1200, filter was bought at local home depot
