Cod Warzone running low FPS on High end PC
Rukini
4 (0.00/day)
Hello, everyone, I'm new here, And looking for some help/advice.
I recently made an upgrade to my PC with a clear intention of running Warzone with more FPS and be able to stream without issues, the thing is, after the upgrade my game is still running on 80 FPS just like with the old setup and it does not make any sense with the current setup:
- i7 10700K
- Asus Rog Strix Z490
- Aorus 3070 8 Gib
- 16 RAM ddr 4 3200 (running on XMP profile for full 3200
- Game installed on a Samsung 970 SSD M2
- Aerocool 700 WATTS
MY Gear is really high-end at the moment, and with full Nvidia control panel set for performance. I formatted and clean installed windows, game settings set also for performance just like in the old setup, checked, temperatures, volts, see if everything is running as it is supposed to, but, in the end, the system is still running the same game performance as the old one.
The thing is, i know a lot of people running much weaker systems than me and getting average 100 / 120 / 140 FPS on 8 generations CPUs and 10 Gen Nvidia graphic cards.
Any type of advise what could be wrong?
My old setup was a 1080TI 11Gb and a I5 8600K and runned the game with the same quality than now.
Thanks.
1,928 (0.40/day)
Romania
Do you have vsync or any other frame limiter on ? did you try lowering the graphical settings or see if there is some sort of resolution scaling active.
Rukini
4 (0.00/day)
Hello vsync is off graphics are set to low and scale is at 100, so I have none scaling active.
167 (0.10/day)
USA
Processor 5800x3D
Motherboard x570 Extreme 4
Cooling Deepcool AK620 Digital
Memory 2x16 Steel Viper 3600 Mhz
Video Card(s) 4070 SUPER FE
Storage 500 GB WD SN750 / 870 Evo 500 GB / Kingston 480 GB SSD
Display(s) Alienware 34 aw3418dw / ROG Swift pg27q
Case Corsair 3000D
Power Supply Seasonic V3 1000w
Mouse Model O
Keyboard GMMK Pro w/ SP Magic Girls
Software WIndows 10 Pro
Have you changed monitors as well?
qubit
Overclocked quantum bit
17,865 (2.81/day)
Quantum Well UK
System Name Quantumville™
Cooling Noctua NH-D14
Case Cooler Master HAF 922
Power Supply Corsair AX1600i
Keyboard Yes
That's about the performance you can expect in Warzone, because it's a large open world map, even with your system.
You say it's running at 80fps, but games don't run at a set number. It wobbles up and down with the rendering complexity and I'll bet if you benchmarked it, or just looked carefully at that fps counter, you'd see that your new system is faster.
3,104 (2.02/day)
Germany
Processor AMD Ryzen 9 9950X3D
Motherboard ASRock B850M PRO-A
Cooling Corsair Nautilus 360 RS
Memory 2x32GB Kingston Fury Beast 6000 CL30
Video Card(s) PowerColor Hellhound RX 9070 XT
Storage 1TB Samsung 990 Pro, 2TB Samsung 990 Pro, 4TB Samsung 990 Pro
Display(s) LG 27GS95QE-B, MSI G272QPF E2
Case Lian Li DAN Case A3 Black Wood Edition
Power Supply Corsair RM1000X ATX 3.1
Mouse Razer Deathadder V3
VR HMD Oculus Rift S
still a bit low.
my 3070 at 1080p sits at around 120 (lowest) to 180 (highest) FPS
Rukini
4 (0.00/day)
not at all, still got my 27 inch AOC 144Hz
still a bit low.
That´s why I´m going crazy here, I tested cyberpunk and the difference for the old PC is HUGE! but in Warzone, it just runs like the old one makes no sense in this new PC.
3,104 (2.02/day)
Germany
ever deleted the CoD MW folder under documents?
