Code 05 on shutdown
58 (0.04/day)
Processor Core 2 Quad Q9650
Motherboard XFX nForce 780i SLI
Cooling Zalman
Memory 4x1GB Ballistix DDR2-1066
Video Card(s) 2x Quadro FX 4800
Storage 2x WD RE3 500GB RAID 0
Display(s) Apple Cinema HD
Case Chieftec Dragon
Audio Device(s) Sound Blaster X-Fi
Power Supply Corsair 500W
Got my cheap x79 board to work but now it won't fully shut down.
I hit shut down in Windows, seems to work, but it goes to debug code 05 shown on the board and freezes.
I have disabled as many sleep state settings as I can find in the BIOS and Windows fast startup is disabled. It doesn't seem to properly shut down in Ubuntu either.
Any ideas? I've cleared CMOS, used different RAM... it doesn't happen on restart or hibernate (or sleep) - just shutdown.
BCHICK1
16 (0.01/day)
Have you added any new devices? It is usually device drivers that will cause the issue. What does the code indicate according to the MoBo manual?
58 (0.04/day)
Cooling Zalman
It does not come with any manual unfortunately, haven't added any new drivers but I'll do a total driver purge and retry
44,274 (6.80/day)
What motherboard,be specific, we are not psychics
BCHICK1
16 (0.01/day)
Yes. Maybe there is a manual on-line. You could probably use one anyway!
58 (0.04/day)
Cooling Zalman
7,607 (1.44/day)
Rīga, Latvia
System Name HELLSTAR
Processor AMD RYZEN 9 5950X
Motherboard ASUS Strix X570-E
Case Lian Li O11 Dynamic EVO
Mouse Razer Basilisk
Software FEDORA 41
Install the OS on full uefi and GPT, no legacy mode.
FreedomEclipse
~Technological Technocrat~
24,785 (3.77/day)
(currently) Hong Kong
System Name WorkInProgress
Processor AMD 7800X3D
Display(s) LG GP850-B
Mouse Logitech G502 X
Software Windows 11 Home
Benchmark Scores ლ(ಠ益ಠ)ლ
If this is your board then you are SOL
These boards tend to be assembled and pieced together like Robocop at OCP from parts of dead boards that have been 'recycled' for the Chinese market and the price reflects the quality that you would expect from these boards because there isnt none. Even the bios is custom written by amateurs for these boards so you might have options that dont do anything in the bios because nobody has written the code for it to do anything.
The bios is probably flipping its shit because its been partnered with a chipset that doesnt have all the extra features it was originally supposed to come with. Either that or its bad coding of the bios.
They dont give you a manual because in the last 3-4years there has been a shortage of toilet paper due to people panic buying.
A quick google pulls this up albeit for a different board.
You might have some luck if the options in the bios works (if there are such options available)
Anyway, Sorry for roasting your board - although it is the hard truth. I hope you have a good day.
::EDIT No. 3000::
basically these are Frankenstein'd motherboards. some work - some dont really work and some dont work at all. Its the nature of these kinds of boards.
Deleted member 24505
this says it all-
Notice,
the chipset of board is send out by randomly. All the parcel is send from warehouse randomly. We can't guarantee the chipset model even you leave me a message. Please do not place order if you mind
58 (0.04/day)
Cooling Zalman
this says it all-
Notice,
yeah hwinfo recognizes the chipset as x58 iirc despite it being allegedly x79
FreedomEclipse
24,785 (3.77/day)
boom smile GIF
Nothing you can do apart from send it back for a refund or a replacement and hope the replacement was put together with parts that actually work with one another.
