Code 43 My Gtx 760
bruhmoment1
29 (0.03/day)
When ı played the game My PC did reset and it opened but got code 43 error and cant see nvidia control panel I did DDU with uninstall drivers and again install but still not work my motherboard Msı 970 gaming PSU thermaltake 420w tr-2pp
44,267 (6.80/day)
Get screenshots of hwinfo64 sensors please.
Did your system get a os update?
bruhmoment1
29 (0.03/day)
Um ım on mobile now can give for now these look at screen there are lines also ı saw my gpu memory 0 in gpu z so its hardware?
FreedomEclipse
~Technological Technocrat~
24,778 (3.77/day)
(currently) Hong Kong
System Name WorkInProgress
Processor AMD 7800X3D
Display(s) LG GP850-B
Mouse Logitech G502 X
Software Windows 11 Home
Benchmark Scores ლ(ಠ益ಠ)ლ
Did you recently buy the graphics card?
FreedomEclipse
24,778 (3.77/day)
Trying using an older drive then your one you're trying to install and see what happens. Code 43 is normally a driver issue.
If trying to run older drivers doesnt solve anything, I would take the graphics card out and test it in spare PC - Even take it down to a repair shop just so they can test the card for you if you dont have a spare PC and none of your friends will allow you to use theirs. Code 43 also could be a hardware issue as windows isnt able to fully communicate with your graphics card.
as point of note - your powersupply is also under the recommended limit even though a 970 can draw as low as 145w when gaming. Nvidia recommends 500w - so your power supply is also something thats worth upgrading.
::EDIT::
I dont know why i said 970 so you can ignore that. But its still a good idea to replace such an old PSU IMO. That thermaltake is 10 years old.
Mussels
Freshwater Moderator
58,412 (7.78/day)
Oystralia
Case Fractal Design R6
Benchmark Scores Nyooom.
This is what happens when these cards fail.
While there are other potential causes, it is entirely possible the card simply failed under load due to age - that card is upto 9 years old.
bruhmoment1
29 (0.03/day)
hwinfo64 sensörlerinin ekran görüntülerini alın lütfen.
Sisteminiz bir işletim sistemi güncellemesi aldı mı?
Yep my PC when did windows update or geforce experience update it did reset PC and got code 43 error
bug
14,325 (3.95/day)
Processor Intel i5-12600k
Motherboard Asus H670 TUF
Cooling Arctic Freezer 34
Case Raijintek Thetis
Keyboard G.Skill KM780R
Software Arch Linux + Win10
Too bad it's not 42 :(
bruhmoment1
29 (0.03/day)
How Can I Fix It? Also what is the operating system bios update? @eidairaman1
bug
14,325 (3.95/day)
@bug do u know how can ı solve it?
I can't read Turkish, but if it's GeForce Experience error, I would say just get rid of GeForce Experience. It's not required.
Failing that, contact Nvidia support, they will know what the error code means.
44,267 (6.80/day)
Did your system receive a Windows update before this issue occurred, because that seems to be a common issue in Windows 10 and 11.
Put the card in another system, at a shop even and verify if it works or not.
bruhmoment1
29 (0.03/day)
Yep my sistem was get windows update also if ı test this card to another pc and if it not work so my Gpu death?
r9
3,300 (0.54/day)
System Name Primary|Secondary|Poweredge r410|Dell XPS|SteamDeck
Processor i7 11700k|i7 9700k|2 x E5620 |i5 5500U|Zen 2 4c/8t
Memory 32GB DDR4|16GB DDR4|16GB DDR4|32GB ECC DDR3|8GB DDR4|16GB LPDDR5
Video Card(s) RX 7800xt|RX 6700xt |On-Board|On-Board|8 RDNA 2 CUs
Storage 2TB m.2|512GB SSD+1TB SSD|2x256GBSSD 2x2TBGB|256GB sata|512GB nvme
Display(s) 50" 4k TV | Dell 27" |22" |3.3"|7"
VR HMD Samsung Odyssey+ | Oculus Quest 2
Software Windows 11 Pro|Windows 10 Pro|Windows 10 Home| Server 2012 r2|Windows 10 Pro
Clean up with display driver uninstaller first and just install the latest driver for the card.
bruhmoment1
29 (0.03/day)
Önce ekran sürücüsü kaldırıcı ile temizleyin ve sadece kart için en son sürücüyü yükleyin.
Ye I did it but still same also windows auto update my drivers
r9
3,300 (0.54/day)
bruhmoment1
29 (0.03/day)
44,267 (6.80/day)
Yes put it in another computer to test, if it gets error 43 there the card is bad, if it doesn't your OS is broken from a windows update.
hertzzz
2 (0.00/day)
@bruhmoment1 hey did u manage to fix the problem? i also have gtx 760. I wiped my ssd out and intalled new windows, now i cant install driver i get error code 43
(istersen turkce de anlata bilirsin)
1,891 (1.29/day)
Romania
System Name Gaming1 / Office 2
Processor Intel i7 7700k@4.8ghz / Ryzen 7 5700G
Motherboard MSI 270 SLI PLUS / MSI MAG X570S - TOMAHAWK MAX WIFI
Cooling ID-Cooling Frostflow X 120 - Liquid / ID-Cooling SE-903 V2
Memory 2x16GB Corsair Vengeance LPX 3600 Black / 2x16GB Corsair Vengeance RGB Pro SL - 3600Mhz
Video Card(s) XFX RX 6600XT 8GB / XFX RX 5700XT THICC III Ultra 8GB
Storage 1st : 1x SSD Samsung 980 Pro 1Tb + 4x SAS HDD in RAID / 2nd : 1 Tb SSD Nvme Samsung 980 Pro 1Tb
Display(s) 2x Dell 3008 WFP
Case CoolerMaster HAF 932 / GENESIS IRID 300
Audio Device(s) Soundblaster XFI / Onboard
Power Supply Seasonic Focus 850 W / Seasonic Focus 850 W
Mouse Logitech G502 HERO / Logitech G5
Keyboard Dell SmartCard Reader SK 3205 / Dell SmartCard Reader SK 3205
Software 1st - Win 10 Pro X64 / Win 7 X86 / Ubuntu / 2nd - Windows 11 Pro x64
Hello.
In order to try to solve it, we will proceed like this :
You download from Nvidia site the driver suitable for you card (i suggest an older whql driver)
Download DDU - Display Driver Uninstaller
Unplug the network.
Restart computer in safe mode.
Run DDU while you are in safe mode and uninstall the drivers.
Restart computer normally.
Install the drivers from Nvidia you downloaded previously.
Restart computer.
Plug the network cable back in.
Check now the device manager
bruhmoment1
29 (0.03/day)
@bruhmoment1 hey, did you manage to solve the problem? I have a gtx 760 too. I deleted my ssd and installed new windows, now I can't install the driver I get error code 43
(you can also tell it in Turkish if you want)
No I could not figure out how many degrees your video card was working in games if it is over 80 get past
