I am having a problem with an Acer desktop PC.
Specs: It has a Phenom II Quad core CPU, and an Acer branded mother board, a confirmed working stick of ram.
Problem: Computer turned on ok first time logged in Windows .. etc. Now, it went to sleep after like 10 minutes of inactivity but after around 15-20 minutes of it sleeping it shut off. After it was shuts off I tried to turn it on by pressing the power button, everything turns on for a split second and then off again. After opening the case I removed all connectors accept the fan & PSU connectors from the motherboard and I discovered that the computer will actually turn on when either the P2 connector is NOT plugged in or when the CPU is completely removed.
Things I tried:
1. Removed Video card and connected the monitor to integrated vga, same problem.
2. Removed all ram then installed a confirmed working stick of ram, same issue
3. I changed the PSU with a confirmed working PSU nothing worked
4. Re-applied thermal paste to CPU same issue
5. Switched the CPU with an Athlon II X4 CPU, same issue
6. Re-seated the motherboard, same issue
7. Turned off the PC, unplugged the PSU and removed the CMOS Battery, pushed the power button for more than 10 seconds, but same problem.
I need your guys's help. Not sure what to do. It's not the CPU, because when the CPU was switched I've had the same issue. Any advice would be greatly appreciated
Things I tried:
