Computer won’t display at all after putting GPU in
Bonkirz
29 (0.01/day)
I have a problem with my PC
So my friend got a used graphics card that he bought on offer up which was the rx570 he let me borrow it because I needed a GPU because I was running my pc off my CPU which was the ryzen 3 2200G the same day I was using my PC very well everything worked when I plugged in the GPU my monitor was black so I shut down everything and removed the GPU so I can run the PC off my CPU again and the same thing happened my monitor was black everything works my fan sound but it just won’t display I tried using HDMI port and VGA post and nothing I removed the battery from my motherboard and inserting it again and rebuilt the pc and still nothing and when I plug in my keyboard my keyboard blinks then turns off
So if someone could help me fix this it will mean everything to me thanks
Have you made a reset of your motherboard ?. Otherwise turn off the power at take out the battery on the motherboard.
When you removed the motherboard battery, did you hold the power button for 30 seconds or so to drain all power from the motherboard?
Some people have had trouble with this and had to do it a few times to get the bios to properly clear itself.
I just tried that right now and it didn’t work
Does the monitor turn on at all during bootup?
I'm not asking if the monitor is working. I'm asking if the monitor turns on at all during boot.
What motherboard are you using?
You said previously that the fans spin and you have sound. Does that mean you can boot into Windows, but with no display?
Only my fans spin there’s no sound and I can’t boot into windows
So the system will just sit there with fan spinning until you turn the pc off again?
What's installed in your system. How many sticks of memory? How many drives?
You said you rebuit the pc. Are the drives plugged into the same ports they were previously?
Could you please remove both memory sticks. Then plug only 1 back into the light grey slot on the left. Then try to start the system.
Could you please remove that stick. Then plug it into the light grey slot on the right. Then try to start the system.
Using only that same stick, could you please try again using the left black slot, then again on the right black slot.
