- Oct 15, 2006
- 14,781 (2.16/day)
- Missoula, MT, USA
System Name | Kursah's Gaming Rig 2018 (2022 Upgrade) - Ryzen+ Edition | Gaming Laptop (Lenovo Legion 5i Pro 2022) |
Processor | R7 5800X @ Stock | i7 12700H @ Stock |
Motherboard | Asus ROG Strix X370-F Gaming BIOS 6203| Legion 5i Pro NM-E231 |
Cooling | Noctua NH-U14S Push-Pull + NT-H1 | Stock Cooling |
Memory | TEAMGROUP T-Force Vulcan Z 32GB (2x16) DDR4 4000 @ 3600 18-20-20-42 1.35v | 32GB DDR5 4800 (2x16) |
Video Card(s) | Palit GeForce RTX 4070 JetStream 12GB | CPU-based Intel Iris XE + RTX 3070 8GB 150W |
Storage | 4TB SP UD90 NVME, 960GB SATA SSD, 2TB HDD | 1TB Samsung OEM NVME SSD + 4TB Crucial P3 Plus NVME SSD |
Display(s) | Acer 28" 4K VG280K x2 | 16" 2560x1600 built-in |
Case | Corsair 600C - Stock Fans on Low | Stock Metal/Plastic |
Audio Device(s) | Aune T1 mk1 > AKG K553 Pro + JVC HA-RX 700 (Equalizer APO + PeaceUI) | Bluetooth Earbuds (BX29) |
Power Supply | EVGA 750G2 Modular + APC Back-UPS Pro 1500 | 300W OEM (heavy use) or Lenovo Legion C135W GAN (light) |
Mouse | Logitech G502 | Logitech M330 |
Keyboard | HyperX Alloy Core RGB | Built in Keyboard (Lenovo laptop KB FTW) |
Software | Windows 11 Pro x64 | Windows 11 Home x64 |
And those devices that cannot connect, you have disabled/enabled their WiFi and still have this issue?
Do those devices that connect to the AP's WiFi after reset have Internet access tested and confirmed?
Could be a compatibility issue with the signal from the AP with those that cannot.
Have you set the bandwidth to 40Mhz or 20/40? If so, try just 20. Are you running B/G/N for compatibility or strictly N?
If you have older WiFi devices, you'll need to sacrifice speed for compatibility....if that's the case here.
Edit: Why are you showing me that screenshot? Not only is that of your router, but it's also one you posted before if I recall correctly. Your Motorola is your router, not your AP if we're still on the same page here. The Motorola is the gateway for the AP. So if your AP has a gateway option, you should set it to the IP of your router (192.168.0.1).
