Controller Problem with GRID
86SlyD
6 (0.00/day)
Hi all.
I can see this is an old issue, but its a new game and a new problem for me.
I'm having trouble running a game controller with the game GRID. After much stuffing around I've managed to set up 2 controllers, one generic dual shock and the other a logitech dual action.
The problem I'm having is all the buttons/commands seem to work except for the accelerator. I've tried setting both the right analog stick and the right bottom button as accelerator. Neither seem to register in the game and I'm left on the start line.
What am I missing? This is really frustrating.....:banghead: Everthing is up to date, patch and drivers.
Any help would be greatly appreciated.
Thanks.
hat
Enthusiast
21,754 (3.23/day)
Ohio
Cooling Cryorig M9 :: Stock
Benchmark Scores >9000
try general hardware or games... this hardly belongs in the WCG section
922 (0.16/day)
London, UK
Processor AMD FX 8350 Black Edition @ 4.2Ghz
Motherboard Gigabyte 990FXA-UD3 Rev 4.0
Cooling Corsair H100i
Memory Samsung Green 16GB 30nm 1600Mhz DDR3
Video Card(s) XFX HD 7950 DD 3GB @ 850/5000Mhz
Storage 240GB Intel 520 SSD + 2TB Seagate Barracuda
Display(s) ASUS PB278Q 27" QHD
Case Fractal Design R5 Black
Power Supply Seasonic Platinum 760W
Mouse Corsair Raptor M40
Keyboard Corsair Raptor K50
go in game controllers in windows and make sure all buttons work on there
86SlyD
6 (0.00/day)
Yeh it's all calibrated and the buttons work. It just wont recognize in game... I've got two different controllers and the same problem with both.
Sorry if this is in the wrong section.
12,453 (1.87/day)
Yankee lost in the Mountains of East TN
Processor 5800x(2)/5700g/5600x/5600g/2700x/1700x/1700
Motherboard MSI B550 Carbon (2)/ MSI z490 Unify/Asus Strix B550-F/MSI B450 Tomahawk (3)
Cooling EK AIO 360 (2)/EK AIO 240, Arctic Cooling Freezer II 280/EVGA CLC 280/Noctua D15/Cryorig M9(2)
Memory 32 GB Ballistix Elite/32 GB TridentZ/16GB Mushkin Redline Black/16 GB Dominator
Video Card(s) Asus Strix RTX3060/EVGA 970(2)/Asus 750 ti/Old Quadros
Storage Samsung 970 EVO M.2 NVMe 500GB/WD Black M.2 NVMe 500GB/Adata 500gb NVMe
Display(s) Acer 1080p 22"/ (3) Samsung 22" 1080p
Case (2) Lian Li Lancool II Mesh/Corsair 4000D /Phanteks Eclipse 500a/Be Quiet Pure Base 500/Bones of HAF
Power Supply EVGA Supernova 850G(2)/EVGA Supernova GT 650w/Phantek Amps 750w/Seasonic Focus 750w
Mouse Generic Black wireless (5)
Keyboard Generic Black wireless (5)
Software Win 10/Ubuntu
moved to games.
1,880 (0.32/day)
UK Warwickshire
System Name PC-Chips
Processor AMD Ryzen 7 5700x3D
Motherboard Asus ROG Strix B550-F Gaming.
Cooling White arctic liquid freezer iii 360 a-rgb AIO.
Memory Patriot Viper 32gig dual channel 3600mhz
Video Card(s) PowerColor HellHound RX 7900 GRE OC.
Storage Samsung 860 EVO 500gig / 2TB crucial P3-NVME / WD-BLUE SN550 1TB M.2 / Toshiba X300 8TB
Display(s) TCL 50-inch 4k TV freesync HDR
Case White NZXT H9 Flow Dual-Chamber
Audio Device(s) Realtek S1220A - Yamaha A-S501 AMP - Wharfedale diamond 9.1 speakers - Wharfedale SW150 sub
Power Supply EVGA SuperNOVA G6 750W 80+ Gold
Mouse Some cheap wireless thing
Keyboard Razer Cynosa lite
VR HMD Oculus Quest 2 128gig version
Software Windows 11 pro 64bit
hmm try this.
go into the windows pad settings, click on the advanced tab and make sure the prefered pad is set to the pad your using.
i have a converter so i can use my PS1 and PS2 pads and it seems to default to pad 2 when the pc restarts so im woundering if this is the prob your having. i also play grid a lot and have the same prob as you when my pad sets itself to pad2.
2,417 (0.39/day)
Toronto, Ont
Processor AMD Ryzen 5 2600
Motherboard MSI B450 Gaming Plus
Memory GSkill 8GB Dual Channel DDR4-2800
Video Card(s) MSI GamingX RX580 4GB
Storage Kingston V300 240GB SSD + WD Green 2TB
Display(s) ACER K212HL 27" + Haier 55" + Lenovo Explorer Mixed Reality Headset
Case Enermax Ostrog (Red)
Power Supply EVGA SuperNOVA B2 750W
Software Win10 64bit
according to Wiki a 360 controller is the only one that works with it.
Input methods Keyboard, Xbox 360 Controller, DualShock 3
6,270 (0.89/day)
New York
Processor INTEL CORE I9-9900K @ 5Ghz all core 4.7Ghz Cache @1.305 volts
Motherboard ASUS PRIME Z390-P ATX
Cooling CORSAIR HYDRO H150I PRO RGB 360MM 6x120mm fans push pull
Memory CRUCIAL BALLISTIX 3000Mhz 4x8 32gb @ 4000Mhz
Video Card(s) EVGA GEFORECE RTX 2080 SUPER XC HYBRID GAMING
Storage ADATA XPG SX8200 Pro 1TB 3D NAND NVMe,Intel 660p 1TB m.2 ,1TB WD Blue 3D NAND,500GB WD Blue 3D NAND,
Display(s) 50" Sharp Roku TV 8ms responce time and Philips 75Hz 328E9QJAB 32" curved
Case BLACK LIAN LI O11 DYNAMIC XL FULL-TOWER GAMING CASE,
Power Supply 1600 Watt
nah man grid works with many controllers...i have used three different ones with out driver installs and all worked fine...I am currently using a rumblepad by logitech...cuz my good one wore out. Did you try removing from usb slot and then putting back in usb slot with the game NOT running? Then run game and try again.
86SlyD
6 (0.00/day)
hmm try this.
Yep done that, for both. Even tried one at a time. Same thing.
I'll give it a shot....
86SlyD
6 (0.00/day)
Ok this is getting weirder. Just out of curiosity, after trying the above, I set the commands back to key board and no aacelerator.
Uninstall/Reinstall??
86SlyD
6 (0.00/day)
Problem solved:toast:
I started a new profile in game and now everything works:ohwell:
Thanks for all the suggestion guys:)
1,880 (0.32/day)
UK Warwickshire
i dont like the way most new games try to force you to go out and buy a 360 pad just to play the damn games, i hate xbox pad personly but there are ways round this to, i found a small program called xinputemu360 it makes most pads think its an xbox pad and also fixes some probs with games where up goes down and down goes up if that makes sense hehe.
as for grid glad you got it working, also remeber to manulay set ya controls if they go funny again, i also had the game default back to keyboard for no reason.
1,880 (0.32/day)
UK Warwickshire
haha ill defo be having some happy gaming when my new ram gets here, and i think grid is one of the first games ill play as i have to sstart all over again due to a recent format and forgot to save me profile lol. hope the next few hours flys past as ram is supose to turn up today but have no idea what time :(
