[Case Gallery] Cool Stacker
Blacky
10 (0.00/day)
Specs:
Foxconn BlackOps X48
Intel Q6600 @ 3.6 Ghz
G.Skill Memory F3 PC 12800
ATi 4870 X2
Seagate 7200.11 320 Gb
Mods:
Watercooling Parts
D-Tek Fuzion V2 with Quad Nozzle
Liang D5 Variable Pump
Thermochill PA 120.3 Radiator
Faser UV Hose 1/2 ID - 3/4 OD
Faser Acid Green Liquid
Yateloons Fans
Nice looking rig you have there.
The tube coming out of the X2 waterblock is a pretty tight bend, keep an eye on it because it may flatten out a bit over time.
Oh and welcome to TPU.
I have in this area a bits power pci bracket. In this area I don't have kink or bend, the photo is not clear but is complete safe this tubing there.
Thanks for you coment
its soo funny you put this mod up.. I am building one using the same case and damn near the same WC parts. But i have the rad mounted in the 5.25 bay in order to keep everything inside the case. And i will be using the ASUS Maximus II Formula P45 board and a single HD 4870 1GB card paired with 8 gigs of Corsair xms dinominator ddr2 1066 mem and a E8500, along with 2 150gb vilociraptors raid0. =] anyways.. great job dude 9/10 from me.
yes.. you should put a spiral or something on that vc to rad bend.
Very nice build overall 10/10
