CoolerMaster Stacker 830 Nvidia Edition
grotesque
7 (0.00/day)
kastamonu
Processor Q6600 3,6GHZ
Motherboard GIGABYTE X48-DS5
Cooling AC-FREEZER PRO7
Memory 2X2 KINGSTON HYPERX 1066MHZ
Video Card(s) HIS 4850 ICEQ4 TURBO 512MB
Storage SEAGATE 320GBx2 RAID0
Display(s) LG L1960TR
Case CM STACKER STC-T01
Power Supply BE QUIET 500W
Software WINDOWS 7
i have the 831 version solid black
Tons of room, you have the ability to put a rad under the case which i did .
I bought a Silver CM Stacker 830 Evo last year. Worst quality control of any case I've ever own. The motherboard standoff holes were slightly misaligned, the frame for add-on cards (PCI, PCI-E) was slightly too high and warped, the fan bracket for the side panel is too thick and precludes using all four fan slots since a tall CPU cooler with hit it. Everything about the assembly was a p.i.t.a and I had about four bloody nicks on my hands from all the sharp edges. I may have just gotten a "lemon", but I was very disappointed considering how much I paid for it (over $200).
Just replaced it last week with a little Antec 300 that cost me $59. It had better quality control, the install process was much easier and the darn thing is cooler with the same hardware vs. the CM.
hmmm I think I will rethink about this case. Thanks for your comments
ive owned the case for nearly 2 years. It is fantastic. Best case i ever owned.
What the 2nd post said isn't really true for me. the case is thick and sturdy, lots of room. Holes were aligned right, and honestly, words dont describe how much i love this case.
check it out in my sp. (copy the link ;) )
http://forums.techpowerup.com/showthread.php?t=80485
http://forums1.techpowerup.com/showthread.php?t=52816&highlight=0+kelvin
not really most updated but GREAT case.
Very nice paint job on the panels! Looks really sharp. Yeah, as I said, I must have just gotten a lemon with mine. Even the best product can have a bad one come down the assembly line once in a while. I'm not getting rid of mine - someday when I have the time, inclination and a dremel I'll take care of its defects. Too expensive to get rid of!
i hear ya, i took the dremal and added the little bit of missing feauters. Holes in mobo and the bar in the top i cut out to hide cables.
I would give the CM a miss and pick something with a bit of style:
http://www.newegg.com/Product/Product.aspx?Item=N82E16811112058
Less money, oozes quality and lots sexier than the Stacker, cable management is also a breeze as its very easy to hide your unused cables under the "floor". :toast:
Edit: Pictures:
case is a matter of opinion.
i like that lian li though :)
I knows, and I also really like the looks of the Lian Li. It's just that the ATCS 840 has a TON of features, is stylish, and is not too overpriced; therefore I seconded.
Lian Li should be considered on the quality of their cases alone....but, as always, there is more to buying a case than just one thing.
I love my Lian Li and to be honest, I'd never buy another case that wasn't a LiLi as it simply is the best case I have ever owned or worked on.
imho the CM is no slouch of a case. Yes it was missing a few features but this was easily fixable with a dremal :)
wow, black and red are more attractive than black and green
As a recommendation, and to throw yet another spanner in your works, have you looked at any silverstone cases? Namely the model I own, the Fortress FT01B-W? I owned that linked Lian Li for a day and hated it, the build quality was awful and the cooling is a big let down, going to this case was amazing - take Lian Li's 'supposed' build quality and times it by 10, and you have this fortress. Such an amazing case - excellent CM from stock (first case I havent had to mod for cable management from stock), amazing airflow + pressure (aided by 18cm fans that are silent) and it looks bloody stunning.
can't help you but looks good!
