core i7 950 OC problem
kayawish24
70 (0.01/day)
hello....
(my system specs are below in my signature)
Now i dont know that is my i7 950 D0 is bad batch or i am doing something wrong in overclocking.my Overclock is 10 hours prime95 stable @ 3.7GHz and the settings i used in bios are.
23x multiplier
BCLK 161
DRAMFrequency 1614 MHz
UCLK 3227 MHz
8-8-8-21
CPU VTT 1.22
QPI 1.4
Dram volts 1.54
rest of everything is on AUTO and HT is also OFF /Turbo is also OFF
on these settings my i7 950 @ 3.7GHz is stable more then 10 hours in prime95 blend test and NO errors but when i try to overclock my cpu to 4 GHz its even not stable @ 1.33v
the settings i used for OC it to 4 GHz is same as above except Dram is running @ 1750 MHz and even its not stable if i run the ram @ 1450 MHz.even increasing / decresing Multi & Bclk is not stable @ 4ghz on 1.33v.so why my i7 950 requires such a high increase in CPUVTT from 3.7GHz to 4GHz.
3.7GHz stable on 1.22v while for 4GHz it take more then 1.33v.why is this?
__________________
CPU: Intel Core i7 950 @ 3.7GHz w/o HT 1.22v 24/7 * | Cpu Cooler: Thermaright 120 ULTRA Xtreme | Board: ASUS P6t6 WS Revolution | Mem: 6GB DDR3 G.Skills PC3 16000 Running @ 1600 MHz 8-8-8-21 @ 1.54v QPI @ 1.4 | GPU: Nvidia 3 x XFX GTX 260 Core 216 3-WAY SLI @ 700/1250/1431 (Core/Memory/Shader)
| HDD:- 640GB S-ATA Seagate Baracuda 32 Mb Cache 7200 Rpm | Cassing: NZXT Tempest *BIG TOWER*
PSU: Xigmatik NRP 1500 Watts
Problems with temps?whats ur temp when running@3.7g?
Beware though.running prime95 for 10hours might killed you mobo
what how can running prime 95 for 10 hours kill my mobo? and @ 3.7ghz load temps were 60-65C in all four cores with HT off and now i am trieing for 4 ghz and temps are 68-73C @ 1.34v and prime95 blend test is running.my idle temps are mostly 44-46C
Well,some guys @xtremesystems forums killed their mobo when running prime95 for 8hours.
It got stable when doing prime for 8hours,and when he wants to reboot he got bsod and his mobo died.
Just like the software said,it is a stressing program ;)
How do you have cpu vvt and qpi listed as 2 different voltages? On Asus x58 boards: qpi/vdram = vvt.
Do you mean its taking a lot of vcore? Also, are you getting any BSOD and what are the error codes?
sory by cpu vtt i mean Vcore.i get BSOD after 2 hours running i7 950 @ 4ghz on 1.35Vcore & 1.4 QPI.Ram is rated for 2000MHz but it wont boot my system thats y i am running it on 1740 MHz and still i got BSOD.i think my Batch is A which very bad so i am still working for 4 ghz OC otherwise i will stay with 3.7GHz OC which is rock solid
A batches aren't inherently bad. I've got a 3903A and it does 21x200 on ~1.2875v in bios.
Can you list your settings? Use this templet I got off i4memory
Code:
AI Tweaker
AI Overclock Tuner: AUTO
CPU Ratio Setting: AUTO
BCLK Frequency: 133
PCIE Frequency: 100
DRAM Frequency: AUTO
UCLK Frequency: AUTO
QPI Link Data Rate: AUTO
DRAM Timing Control
DRAM CAS Latency: AUTO
DRAM RAS# to CAS# Delay : AUTO
DRAM RAS# PRE Time: AUTO
DRAM RAS# ACT Time: AUTO
DRAM RAS# to RAS# Delay: AUTO
DRAM REF Cycle Time: AUTO
DRAM WRITE Recovery Time: AUTO
DRAM READ to PRE Time: AUTO
DRAM FOUR ACT WIN Time: AUTO
DRAM Back-To-Back CAS# Delay: AUTO
DRAM Timing Mode: AUTO
DRAM Round Trip Latency on CHA: AUTO
DRAM Round Trip Latency on CHB: AUTO
DRAM Round Trip Latency on CHC: AUTO
DRAM WRITE To READ Delay(DD): AUTO
DRAM WRITE To READ Delay(DR): AUTO
DRAM WRITE To READ Delay(SR): AUTO
DRAM READ To WRITE Delay (DD): AUTO
DRAM READ To WRITE Delay (DR): AUTO
DRAM READ To WRITE Delay (SR): AUTO
DRAM READ To READ Delay(DD): AUTO
DRAM READ To READ Delay(DR): AUTO
DRAM READ To READ Delay(SR): AUTO
DRAM WRITE To WRITE Delay(DD): AUTO
DRAM WRITE To WRITE Delay(DR): AUTO
DRAM WRITE To WRITE Delay(SR): AUTO
CPU Voltage: AUTO
CPU PLL Voltage: AUTO
QPI/DRAM Core Voltage: AUTO
IOH Voltage: AUTO
IOH PCIE Voltage: AUTO
ICH Voltage: AUTO
ICH PCIE Voltage: AUTO
DRAM Bus Voltage: AUTO
DRAM DATA REF Voltage on CHA: AUTO
DRAM CTRL REF Voltage on CHA: AUTO
DRAM DATA REF Voltage on CHB: AUTO
DRAM CTRL REF Voltage on CHB: AUTO
DRAM DATA REF Voltage on CHC: AUTO
DRAM CTRL REF Voltage on CHC: AUTO
Load-Line Calibration: AUTO
CPU Differential Amplitude: AUTO
CPU Clock Skew: AUTO
CPU Spread Spectrum: AUTO
IOH Clock Skew: AUTO
PCIE Spread Spectrum: AUTO
CPU Advance Settings
C1E Support: Enabled
Hardware Prefetcher: Enabled
Adjacent Cache Line Prefetcher: Enabled
Intel (R) Virtualization Tech: Enabled
CPU TM Function: Enabled
Execute Disable Bit: Enabled
Intel (R) HT Technology: Enabled
Active Processor Cores: ALL
A20M: Disabled
Intel (R) C-State Tech: Enabled
Express Gate: Disabled
Sure is Johnny. What is your pack date, if you know? Mine is 5/15/09
Have you tried relaxing your uncore? I've been messing a little today and did 20x200 with 1.25 for ~20 minutes. Nothing great for OOCT Linpack, but couldn't do that before. All I did was relax my uncore from 3600 to 3200. Still have my memory at 1600 8-8-8-21 90tRFC. Here are some settings for my P6T6.
Code:
AI Tweaker
AI Overclock Tuner: Manual
CPU Ratio Setting: 20x
BCLK Frequency: 200
PCIE Frequency: 100
DRAM Frequency: 8x
UCLK Frequency: 16x
QPI Link Data Rate: 18x
DRAM Timing Control
DRAM CAS Latency: 8
DRAM RAS# to CAS# Delay : 8
DRAM RAS# PRE Time: 8
DRAM RAS# ACT Time: 21
DRAM REF Cycle Time: 90
DRAM Back-To-Back CAS# Delay: AUTO (Believed to be 4)
DRAM Timing Mode: 1N
DRAM Round Trip Latency on CHA: Normal (55)
DRAM Round Trip Latency on CHB: Normal (56)
DRAM Round Trip Latency on CHC: Normal (57)
CPU Voltage: 1.25
CPU PLL Voltage: 1.8
QPI/DRAM Core Voltage: 1.28750
IOH Voltage: 1.22
IOH PCIE Voltage: 1.58
ICH Voltage: 1.1
ICH PCIE Voltage: 1.5
DRAM Bus Voltage: 1.64
Load-Line Calibration: Enabled
CPU Clock Skew: Auto
CPU Spread Spectrum: Disabled
IOH Clock Skew: Auto
PCIE Spread Spectrum: Disabled
C1E Support: Disabled
Intel (R) Virtualization Tech: Disabled
CPU TM Function: Disabled
Execute Disable Bit: Disabled
A20M: Disabled
Intel (R) C-State Tech: Disabled
Like I said, I can do higher on the uncore, but it seems to just eat voltage on QPI/vDram (vvt) and vCore.
My pack date is same as yours mastr, I've tried 1600 mem/3200 uncore. Still falls on its face during prime. I have a DFI T3EH8 btw.
Don't know then. Maybe its the power supply. :shrugs:
I have a 850w Thermaltake ToughPower XT, definitely not PSU. I'll have to bust out my multimeter :)
Hmmm, believe it or not it maybe the board. Evga has both of our boards and noted this with the same processor:
First overclock on Asus P6T6 WS Revolution and paired it with my worst i7 920 3836A756 #2 C0 stepping cpu which on DFI UT X58-T3EH8 on TRUE120 air cooling and EK Supreme LT water cooling needed around 1.360-1.376v vcore to be Prime95 stable. Now same i7 920 3836A756 C0 #2 cpu managed 4000Mhz for Prime95 at just 1.304v idle/1.320v load vcore with 20x200Bclk with OCZ Platinum DDR3-1333Mhz 7-7-7-24 (OCZ3P1333LVA6GK 'Animal Series') @DDR3-1600Mhz 7-7-7-24 1T at 1.60v vdimm.
http://i4memory.com/117786-post4.html
Johnny! Start over!
I just ran LinX 0.6.1 with 60 loops of ~4800mb of memory with 200bclk, 3200 uncore, and 3600 qpi with.....1.225v vvt! No errors and was still going. I only had the core at 3200, but I was amazed at the low voltage needed from vvt. I'm working on messing with 4ghz though. Also had 1600 on the memory with 8-8-8-21 1T timings and I would bet I could go 7-7-7-x 1T without a problem.
