Could not enter Bios after CPU / Mobo upgrade.
2,706 (0.41/day)
Oulu, Finland
System Name Enslaver :)
Processor Ryzen 7 7800X3D
Motherboard ASUS TUF Gaming B650-Plus
Cooling CPU: Noctua D15 G2, Case: 2 front in, 1 rear out
Memory 2x16GB Kingston Fury Beast RGB 6000MHz
Video Card(s) ASUS TUF RTX 4070Ti OC
Storage Samsung Evo Plus 1TB NVMe , internal WD Red 4TB for storage, WD Book 8TB
Display(s) LG CX OLED 65"
Case Lian Li LANCOOL II Mesh C Performance
Audio Device(s) HDMI audio powering Dolby Digital audio on 5.1 Z960 speaker system
Mouse Logitech G700
Keyboard ASUS Strix Tactic Pro
Software Windows 11 Pro x64
Just wanted to share a strange behavior of my ASUS TUF Gaming B650-Plus when I installed it yesterday with my new shiny Ryzen 7 7800x3d.
After first boot it asked something about fTPM reset and then went to the normal first startup screen where it lists the CPU, ram, shows the Bios logo and usually shows the error messages.
It wanted me to press F1 key to enter Bios but keyboard wouldnt react to F1. Would not boot to Windows before I accessed the Bios. CRTL+ALT+DEL to reboot PC worked normally though.
Tried 2 keyboard on different USB ports but nothing helped.
Solution was to turn PC off and make a USB stick with latest Bios file (use biosrenamer.exe to rename the bios first) stick it in the Bios marked USB port in the back and press the Bios flashback button so long that it blinks 3 times. The blinking continued for like 2-3min and stopped after it had installed the Bios update (note: PC was not turned on during this, no fans spinning at least)
After I turned on the PC it updated something related to the AURA LED stuff and I think for the next 2 reboots it acted like before not letting me in Bios but soon after F1 started working and I could use my PC.
My mobo should have supported my new CPU out of the box so I really dont have no clue what the problem was.
Some folks on the web said they even had to buy a PS/2 connector keyboard to fix this problem, but I dont even have a port for that anymore.
Lost 2h troubleshooting this shit :(
I am glad you shared a solution so others can find it.
Truly odd behavior, I have the same mb and cpu. I had no keyboard (usb) problems on my install. Glad you got it working.
I've had this issue before on different motherboards. Different USB port usually does it for me. There was a Microsoft keyboard I had that would not communicate before windows as well. Very strange stuff.
So the problem was fixed by upgrading the bios. Nice to know!
just asked a bit too much from an average user to blindflash bios. np for me but others might struggle
