Could this be a CPU issue?
533 (0.12/day)
Processor i7 6900k @ 4.3GHZ
Motherboard MSI X99A Godlike Gaming Carbon
Cooling CPU/GPU loop with 480mm and 360mm radiators
Memory 32GB Corsair Dominator 3000MHz C15
Video Card(s) 2x EVGA 1080 SC ACX @ 1830/1330
Storage Samsung 950 Pro M.2 512GB, WD 2TB Black HDD
Case Corsair 900D
Power Supply EVGA 850W Gold 80 plus PSU
Hey guys. I bought my PC about 2 months ago, i'm running two HD7970's, ones an Asus Matrix and ones an XFX. In the past i have i had both cards slightly overclocked on stock voltages, however, i started getting artifacts and so reset both to default. After a few weeks without any artifacts, i randomly started getting greyish colored artifacts when running World of Warcraft. So i tested both cards individually and seemed to have no issues with either. So i then re-connected the two together. I had no issues to start and my Furmark scores were as normal but after a few hours, they started to come back. Even when i disabled crossfire they remained. I have tried changed the port for the crossfire cables and the same thing is still happening. I have tried re-inserting both cards several times but the same thing continues to happening. I originally thought that it may be an issue that has to do with the crossfire cable, however i'm thinking it could be to do with my processor. Note: I have not touched the settings on either card since the artifacts and they still continue to occur. Any advice would be greatly appreciated. Thanks.
I would look at the video cards and PSU(yes, I know, your PSU should be plenty for your set-up). Never heard of a CPU to cause artifacting
How exactly would i know if it was a psu issue? (I have re-connected all of the pins back into the psu) And do you think that it could possibly be the crossfire bridge?
Hi
set system defaults [do not OC while testing]
test each card in the system one at a time; grey flecks *May be Vmem
nb: running Furmark may damage this further [test with games]
atb (all the best)
Law-II
Persoanlly, I would start by testing each card seperately. Install just one video card and run furmark with it for a few hours. If you don't get any artifacts, do the samething with the other card. As for testing your PSU, run HWMonitor and post what it says about your voltages. Other than that, the only way I know to test a PSU is by either trying another PSU in your system or trying your PSU in a equal system to yours.
Hi
atb (all the best)
Law-II
One note, like Law said, Furmark can cause more damage to your video card if one is faulty, but it will show you if one is faulty, and if it is, it's already broken. So yeah.
I have tested each card individually with furmark. I can't leave it going for more than about 15 minutes though cause they get up to 90 degrees fairly quickly even with the fans on 100%.
Oh really? Then your artifacting is coming from over-heating your video cards. What temps do they get to under normal use? Give me acouple minutes and I'll post what temps my 7970 gets in Furmark. I can already say that this is what my 7970 runs at crunching full load-
Hi
It would have helped if you had stuck with the original thread - http://www.techpowerup.com/forums/showthread.php?t=181191
rather than getting repeat answers
nb: If you have third party OC applications installed [uninstall them ~ and reinstall AMD catalyst]
TEST with game that caurses "greyish colored artifacts when running World of Warcraft"
- [greyish colored artifacts] do you see these at post, bios screen and or desktop?
atb
Law-II
10 minute run on furmark, my 7970 got as high as 89'c.
I'm running WoW atm and am getting no artifacts, howver, when i test furmark on its own i only get about 50 FPS whilst it says crossfire is enabled...
I just ran a 1080p 1 minute benchmark. The loads on card 1 (The matrix) sat at around 80% while card 2 was at around 65%. The matrix reached about 75 degrees and the XfX card got to about 70.
Here is the data from HWmonitor:
CPUID HWMonitor Report
Binaries
HWMonitor version 1.2.1.0
Monitoring
Mainboard Model MAXIMUS V FORMULA (0x000004D0 - 0x865AD010)
LPCIO
LPCIO Vendor Nuvoton
LPCIO Model NCT6779
LPCIO Vendor ID 0x5CA3
LPCIO Chip ID 0xC5
LPCIO Revision ID 0x62
Config Mode I/O address 0x2E
Config Mode LDN 0xB
Config Mode registers
00 01 02 03 04 05 06 07 08 09 0A 0B 0C 0D 0E 0F
00 FF FF 00 FF FF FF FF 0B FF FF FF FF FF FF FF FF
10 FF FF FF FF FF FF FF FF FF FF 00 70 94 00 FF FF
20 C5 62 FF 00 04 00 00 00 00 FF 40 00 00 FF 00 05
30 01 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
40 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
50 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
60 02 90 00 00 FF FF FF FF FF FF FF FF FF FF FF FF
70 00 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
Register space LPC, base address = 0x0290
Hardware Monitors
Hardware monitor Nuvoton NCT6776
Voltage 0 1.36 Volts [0xAA] (CPU VCORE)
Voltage 1 1.01 Volts [0x7E] (VIN1)
Voltage 2 3.33 Volts [0xD0] (AVCC)
Voltage 3 3.33 Volts [0xD0] (3VCC)
Voltage 4 1.02 Volts [0x7F] (VIN4)
Voltage 6 2.03 Volts [0xFE] (VIN6)
Temperature 0 33°C (91°F) [0x21] (SYSTIN)
Temperature 1 37°C (98°F) [0x4A] (CPUTIN)
Temperature 3 37°C (98°F) [0x25] (TMPIN3)
Fan 1 2276 RPM [0x8E4] (CPUFANIN)
00 04 AA 04 62 00 FF FF FF FF FF FF FF FF FF FF FF
10 04 AA 04 AA 04 FF FF FF 40 8B FE FF 21 17 FE 00
20 AA 7E D0 D0 7F FF FE 21 FF FF FF DA 00 00 00 00
30 00 00 00 00 00 00 00 00 00 00 00 FF FF FF FF FF
40 03 00 00 FF DF 00 1F FF 2D FF FF 10 00 55 00 A3
50 01 FF FF FF FF FF FF FF C1 FF FF FF FF 01 00 FF
60 A0 FF FF FF FF 01 00 FF FF FF FF FF FF FF FF FF
70 00 0A 00 25 00 25 00 25 00 25 00 C3 00 FF FF FF
80 FF 7F 1F BF FF 05 05 05 00 00 00 00 00 00 00 00
90 0A 00 00 00 00 FD FD FD 0A 95 EF 80 FF 40 46 C4
A0 0E FF 00 00 FF 00 00 FF 00 00 80 66 06 06 03 00
B0 00 00 00 00 00 00 31 00 04 00 00 34 28 00 04 FF
C0 FF FF FF FF FF FF FF FF FF 02 07 02 FF FF FF FF
D0 05 05 05 05 00 00 00 00 00 00 00 00 FD FD FD FD
E0 55 80 00 00 00 FF FF FF FF FF FF FF FF FF FF FF
F0 00 00 00 00 00 00 00 00 00 00 00 00 96 FF FF FF
Hardware monitor ACPI
Temperature 0 28°C (82°F) [0xBC2] (TZ00)
Temperature 1 30°C (85°F) [0xBD6] (TZ01)
Hardware monitor AMD ADL
Voltage 0 0.95 Volts [0x3B6] (VIN0)
Temperature 0 66°C (150°F) [0x42] (TMPIN0)
Processors
Number of processors 1
Number of threads 8
APICs
Processor 0
-- Core 0
-- Thread 0 0
-- Thread 1 1
-- Core 1
-- Thread 0 2
-- Thread 1 3
-- Core 2
-- Thread 0 4
-- Thread 1 5
-- Core 3
-- Thread 0 6
-- Thread 1 7
Timers
ACPI timer 3.580 MHz
HPET timer 14.318 MHz
Perf timer 3.418 MHz
Sys timer 1.000 KHz
Processors Information
Processor 1 ID = 0
Number of cores 4 (max 8)
Number of threads 8 (max 16)
Name Intel Core i7 3770K
Codename Ivy Bridge
Specification Intel(R) Core(TM) i7-3770K CPU @ 3.50GHz
Package (platform ID) Socket 1155 LGA (0x1)
CPUID 6.A.9
Extended CPUID 6.3A
Core Stepping E1
Technology 22 nm
TDP Limit 77 Watts
Core Speed 4700.2 MHz
Multiplier x FSB 47.0 x 100.0 MHz
Stock frequency 3500 MHz
Instructions sets MMX, SSE, SSE2, SSE3, SSSE3, SSE4.1, SSE4.2, EM64T, VT-x, AES, AVX
L1 Data cache 4 x 32 KBytes, 8-way set associative, 64-byte line size
L1 Instruction cache 4 x 32 KBytes, 8-way set associative, 64-byte line size
L2 cache 4 x 256 KBytes, 8-way set associative, 64-byte line size
L3 cache 8 MBytes, 16-way set associative, 64-byte line size
FID/VID Control yes
Turbo Mode supported, enabled
Max non-turbo ratio 35x
Max turbo ratio 63x
Max efficiency ratio 16x
Min Power 60 Watts
O/C bins unlimited
Ratio 1 core 63x
Ratio 2 cores 63x
Ratio 3 cores 63x
Ratio 4 cores 63x
TSC 3499.8 MHz
APERF 4699.9 MHz
MPERF 3500.1 MHz
Thread dumps
CPU Thread 0
APIC ID 0
Topology Processor ID 0, Core ID 0, Thread ID 0
Type 01020101h
Max CPUID level 0000000Dh
Max CPUID ext. level 80000008h
Cache descriptor Level 1, D, 32 KB, 2 thread(s)
Cache descriptor Level 1, I, 32 KB, 2 thread(s)
Cache descriptor Level 2, U, 256 KB, 2 thread(s)
Cache descriptor Level 3, U, 8 MB, 16 thread(s)
CPUID
0x00000000 0x0000000D 0x756E6547 0x6C65746E 0x49656E69
0x00000001 0x000306A9 0x00100800 0x7F9AE3BF 0xBFEBFBFF
0x00000002 0x76035A01 0x00F0B2FF 0x00000000 0x00CA0000
0x00000003 0x00000000 0x00000000 0x00000000 0x00000000
0x00000004 0x1C004121 0x01C0003F 0x0000003F 0x00000000
0x00000004 0x1C004122 0x01C0003F 0x0000003F 0x00000000
0x00000004 0x1C004143 0x01C0003F 0x000001FF 0x00000000
0x00000004 0x1C03C163 0x03C0003F 0x00001FFF 0x00000006
0x00000005 0x00000040 0x00000040 0x00000003 0x00001120
0x00000006 0x00000077 0x00000002 0x00000009 0x00000000
0x00000007 0x00000000 0x00000281 0x00000000 0x00000000
0x00000008 0x00000000 0x00000000 0x00000000 0x00000000
0x00000009 0x00000000 0x00000000 0x00000000 0x00000000
0x0000000A 0x07300403 0x00000000 0x00000000 0x00000603
0x0000000B 0x00000001 0x00000002 0x00000100 0x00000000
0x0000000B 0x00000004 0x00000008 0x00000201 0x00000000
0x0000000C 0x00000000 0x00000000 0x00000000 0x00000000
0x0000000D 0x00000007 0x00000340 0x00000340 0x00000000
0x80000000 0x80000008 0x00000000 0x00000000 0x00000000
0x80000001 0x00000000 0x00000000 0x00000001 0x28100800
0x80000002 0x20202020 0x49202020 0x6C65746E 0x20295228
0x80000003 0x65726F43 0x294D5428 0x2D376920 0x30373733
0x80000004 0x5043204B 0x20402055 0x30352E33 0x007A4847
0x80000005 0x00000000 0x00000000 0x00000000 0x00000000
0x80000006 0x00000000 0x00000000 0x01006040 0x00000000
0x80000007 0x00000000 0x00000000 0x00000000 0x00000100
0x80000008 0x00003024 0x00000000 0x00000000 0x00000000
MSR 0x0000001B 0x00000000 0xFEE00900
MSR 0x0000003A 0x00000000 0x00000001
MSR 0x000001A0 0x00000000 0x00850089
MSR 0x000000CE 0x00081010 0xF0012300
MSR 0x00000017 0x00040000 0x00000000
MSR 0x00000035 0x00000000 0x00040008
MSR 0x000000C1 0x00000000 0x00000000
MSR 0x000000C2 0x00000000 0x00000000
MSR 0x000000C3 0x00000000 0x00000000
MSR 0x000000C4 0x00000000 0x00000000
MSR 0x00000186 0x00000000 0x00000000
MSR 0x00000187 0x00000000 0x00000000
MSR 0x000001AD 0x00000000 0x3F3F3F3F
MSR 0x00000194 0x00000000 0x000F0000
MSR 0x0000019A 0x00000000 0x00000000
MSR 0x000001A4 0x00000000 0x00000000
MSR 0x000001B1 0x00000000 0x883E0008
MSR 0x000001FC 0x00000000 0x0014005D
MSR 0x00000601 0x18141494 0x80001FFF
MSR 0x00000602 0x18141494 0x80000190
MSR 0x00000606 0x00000000 0x000A1003
MSR 0x00000610 0x8000FFF8 0x0022FFF8
MSR 0x00000611 0x00000000 0x8E798F24
MSR 0x00000639 0x00000000 0x778C6483
MSR 0x00000641 0x00000000 0x00000000
MSR 0x00000614 0x00000000 0x01E00268
MSR 0x0000019C 0x00000000 0x883E0008
MSR 0x000001A2 0x00000000 0x00691400
MSR 0x00000198 0x0000261C 0x00002F00
MSR 0x00000199 0x00000000 0x0000FF00
CPU Thread 1
APIC ID 1
Topology Processor ID 0, Core ID 0, Thread ID 1
Type 01020101h
CPUID
0x00000001 0x000306A9 0x01100800 0x7F9AE3BF 0xBFEBFBFF
0x0000000B 0x00000001 0x00000002 0x00000100 0x00000001
0x0000000B 0x00000004 0x00000008 0x00000201 0x00000001
MSR 0x0000001B 0x00000000 0xFEE00800
MSR 0x000001B1 0x00000000 0x88400008
MSR 0x00000611 0x00000000 0x8E7A71C3
MSR 0x00000639 0x00000000 0x778D26E8
MSR 0x0000019C 0x00000000 0x88440008
CPU Thread 2
APIC ID 2
Topology Processor ID 0, Core ID 1, Thread ID 0
Type 01020101h
CPUID
0x00000001 0x000306A9 0x02100800 0x7F9AE3BF 0xBFEBFBFF
0x0000000B 0x00000001 0x00000002 0x00000100 0x00000002
0x0000000B 0x00000004 0x00000008 0x00000201 0x00000002
MSR 0x00000611 0x00000000 0x8E7B5C36
MSR 0x00000639 0x00000000 0x778DF004
MSR 0x0000019C 0x00000000 0x88430008
CPU Thread 3
APIC ID 3
Topology Processor ID 0, Core ID 1, Thread ID 1
Type 01020101h
CPUID
0x00000001 0x000306A9 0x03100800 0x7F9AE3BF 0xBFEBFBFF
0x0000000B 0x00000001 0x00000002 0x00000100 0x00000003
0x0000000B 0x00000004 0x00000008 0x00000201 0x00000003
MSR 0x00000611 0x00000000 0x8E7C3E1C
MSR 0x00000639 0x00000000 0x778EB1EF
MSR 0x0000019C 0x00000000 0x88450008
MSR 0x00000198 0x00002645 0x00002F00
CPU Thread 4
APIC ID 4
Topology Processor ID 0, Core ID 2, Thread ID 0
Type 01020101h
CPUID
0x00000001 0x000306A9 0x04100800 0x7F9AE3BF 0xBFEBFBFF
0x0000000B 0x00000001 0x00000002 0x00000100 0x00000004
0x0000000B 0x00000004 0x00000008 0x00000201 0x00000004
MSR 0x00000611 0x00000000 0x8E7D299A
MSR 0x00000639 0x00000000 0x778F7C29
MSR 0x0000019C 0x00000000 0x88410008
CPU Thread 5
APIC ID 5
Topology Processor ID 0, Core ID 2, Thread ID 1
Type 01020101h
CPUID
0x00000001 0x000306A9 0x05100800 0x7F9AE3BF 0xBFEBFBFF
0x0000000B 0x00000001 0x00000002 0x00000100 0x00000005
0x0000000B 0x00000004 0x00000008 0x00000201 0x00000005
MSR 0x00000611 0x00000000 0x8E7E1952
MSR 0x00000639 0x00000000 0x77904AD9
CPU Thread 6
APIC ID 6
Topology Processor ID 0, Core ID 3, Thread ID 0
Type 01020101h
CPUID
0x00000001 0x000306A9 0x06100800 0x7F9AE3BF 0xBFEBFBFF
0x0000000B 0x00000001 0x00000002 0x00000100 0x00000006
0x0000000B 0x00000004 0x00000008 0x00000201 0x00000006
MSR 0x000001B1 0x00000000 0x883F0008
MSR 0x00000611 0x00000000 0x8E7EFA6D
MSR 0x00000639 0x00000000 0x77910C1B
CPU Thread 7
APIC ID 7
Topology Processor ID 0, Core ID 3, Thread ID 1
Type 01020101h
CPUID
0x00000001 0x000306A9 0x07100800 0x7F9AE3BF 0xBFEBFBFF
0x0000000B 0x00000001 0x00000002 0x00000100 0x00000007
0x0000000B 0x00000004 0x00000008 0x00000201 0x00000007
MSR 0x00000611 0x00000000 0x8E7FD862
MSR 0x00000639 0x00000000 0x7791CA3B
Storage
USB Device Generic USB Hub, class=0x09, subclass=0x00, vendor=0x8087, product=0x0024
USB Device Bluetooth module, class=0xFF, subclass=0x01, vendor=0x0B05, product=0x17B5
USB Device USB Input Device, class=0x00, subclass=0x00, vendor=0x1B1C, product=0x0C04
USB Device USB Composite Device, class=0x00, subclass=0x00, vendor=0x1532, product=0x001F
Graphic APIs
API ATI I/O
API ADL SDK
Display Adapters
Display adapter 0
Name AMD Radeon HD 7900 Series
PCI device bus 1 (0x1), device 0 (0x0), function 0 (0x0)
Vendor ID 0x1002 (0x1043)
Model ID 0x6798 (0x044C)
Display adapter 1
PCI device bus 2 (0x2), device 0 (0x0), function 0 (0x0)
Vendor ID 0x1002 (0x1682)
Model ID 0x6798 (0x3212)
Hi
I would have helped if you had stuck with the original thread - http://www.techpowerup.com/forums/showthread.php?t=181191
atb
Law-II
Sorry for the double post. And no, i havn't noticed the artifacts out side of WoW. Not even in furmark.
Here is a picture of what is happenning in the game (Aswell as the grey artifacts).
so how did it go? you still seeing those grey stuff?
Hi
Set PC to stock remove all OC's [when testing]
Check system RAM one stick at a time *May be
Have a look here - http://www.playtool.com/pages/artifacts/artifacts.html
Try this [First Part repeat this for both cards]
- shutdown PC power down PSU wait a couple of minutes
Remove the XFX HD 7970 at this stage and only Select the Asus HD7970 R.O.G
and install it in PCIEx16 [top slot] and attach power cables
NEXT
power up and boot into windows
go here - Control Panel\All Control Panel Items\Windows Update\Change settings and set Important updates to *Download updates but let me choose whether to install them [Note: this can be changed back afterwards]
go here - http://sites.amd.com/us/game/downloads/Pages/radeon_win7-64.aspx and download catalyst 13.1 [or a version of the catalyst drivers you know work]
Next
Uninstall all third party OC applications through Control Panel\All Control Panel Items\Programs and Features
Next
Uninstall and deap clean AMD vga drivers
download this ATiManUninstaller to completely clean out your drivers, you can get that here: http://www.mediafire.com/?0jdko53gk5npzo0 (Link is safe, erocker uploaded it)
install to C:\
Run Atiman Uninstaller.exe
Select: A
system will reboot
Select: C
application will end
reselect window
Select: Q = Exit
Next
install Catalyst driver; windows will need to restart and boot back into windows [allow this]
Next
run tests again
Next [Second Part crossfireX]
shut down the PC power down the PSU [wait for a couple of minutes], then install the XFX HD 7970 [*Do Not Install the crossfire bridge at this stage] attach the power cables
Next
power up the PSU, boot into windows and allow windows to install the driver for the new hardware, next: restart and boot back into windows
Next
Shutdown windows ; power down the PSU [wait for a couple of minutes] then install the Crossfire Bridge
Next
Power up the PSU, boot into windows; goto catalyst control center and select crossfire
Next
Install latest version of CAPS available here - http://sites.amd.com/us/game/downloads/Pages/crossfirex-app-profiles.aspx
Next
re-run tests again
nb: If you can, replace the crossfire bridge
Edit: -game up to date; any other games effected?;
Edit: -both vga cards at stock are running same Core and Mem speed?
atb
Law-II
I shut down my computer, unplugged the PSU, waited a few minutes, removed both graphics cards and inserted just the Matrix (for the fifth time) and now for some reason it isn't detecting my mouse, keyboard or monitor. I may just take to it be fixed at the place i bought it from :s
In SLI if the SLI bridge is damaged or wrongly placed it can cause weird colors to show up on screen, or even colored lines.
I assume the same could happen in crossfire. I would try reseating the bridge (a few times) or try a new one.
Thanks, i will try to buy a new bridge if i can resolve that the graphics cards are not to blame.
Hi
reset the bios/clear cmos, remove the Asus, place the XFX card in PCIe x16 top slot and [try again]
for the fifth time
I understand
atb
Law-II
Hi
I understand
atb
Law-II
Thanks, i was able to get into my pc and test the cards individually. Both seemed to be fine when tested in both World of warcraft on ultra for 15 minutes and in furmark 1080p for a couple. I have re-installed the 13.1 drivers but was not able to clear them using the program you linked, it said i did not have sufficient privileges even though i was using an admin account. I also re-seated each memory stick individually. I am almost certain now that it must have to do with the crossfire bridge being faulty. Thanks so much for your help, i really appreciate it. :toast:
Do you still get the artifacts when you disable crossfire in the control panel and run the game with crossfire disabled?
There isn't a known issue about this in the driver your currently using is there? Sometimes artifacts happen in drivers and they will be notated under "known problems" in the release notes of the driver.
I had a look in the issues and couldn't see anything about World of Warcraft. I have tested both graphics cards individually in both WoW and furmark, i allowed them to get up to about 85 degrees and didn't see any problems. I think that it must be the crossfire bridge. Can a faulty crossfire bridge cause artifacts and the game to bug out (In the photo that i inserted above). Thanks for your reply.
This is from another thread, http://www.techpowerup.com/forums/showpost.php?p=2856105&postcount=1752
The SLI bridge was not placed properly, so it was causing that issue.
Try to remove and put it back a few times.
Although, theres something that confuses me.
In the link above, the person had to take a picture with a camera because the "yellow blob" wasn't showing when taking a screenshot in game.
That said, not sure anymore if it really is the bridge.
I understand you tested them individually, but I'm asking if you tried with both cards in and disabling crossfire if you still get the artifact.
Also if it's only in this game, it's probably not the bridge and it may not even be a problem with the card since if it was then it should be artifacting (of some kind) in other games as well.
What driver are you on?
The problem is on the card since he can take a ss of the game and it captures the corruption which means it's in the frame buffer.
There's also a W7 update (KB2670838) that was causing yellow roads in BF3 with the newest nVidia drivers. I'm kind of wondering if this might be related.
after reading all the things you posted, it is either a driver related problem, or your cards are overheating. also there is no need to overclock. specially since you are using 7950s.
so take off the overclock and let them run stock.
btw 90C is not hot enough for a GPU to go bad.
if you have a OC on the CPU, you should try taking that off too.
Most cold solder problems start slowly and become more noticible... may only do it sparingly at first.
90c is not bad for the core but if the pcb heats and cools under high temperatures the board can warp and this can exacerbate cold solder problems.
Lastly... I myself would never run a card at 90c even under load.... There should be no reason to. Just pull the coolers off, wipe all the gunked on shit that the manufacturer put on the core and use the credit card method to reaply thermal paste... Your core temps should drop a good 20 celsius under load. If they don't then you need more airflow in the case.
One last question? I can't remember if you posted full gpuz temps in the last thread, but what are the other temps on the cards? VRM phase 1,2,3, memory, and shaders?
