KvngSteven
- Dec 22, 2022
- 20 (0.02/day)
Hello,
I have a CNPS4X Zalman RGB CPU Cooler and the speed of the fan does not change it stays at the same speed and won't go any lower or higher.
It is plugged in to a 4 PIN PWM Fan Header on my motherboard, I also tried using a 4 Pin PWM Fan Hub and it still won't change.
The only way to change the speed is to go into the BIOS but there are only 3 options, Enhanced, Auto and Full. Enhanced doesn't do anything it just keeps the fan at low speeds and doesn't increase the speed, Auto just keeps the fan at medium speeds and doesn't increase the speed or lower. Full Keeps the fan at max speed as it should.
I want to know if there is a way to make my CPU Cooler Fan Speed to change automatically according to the temperature of the CPU like it is supposed to be instead of running it at a certain speed.
