CPU for virtualization (VirtualBox)
For the use of virtual machines, which CPU would be more recommended?
  • Intel i9-13900
  • Ryzen 9 7950X
  • Other (comment, please)
Results are only viewable after voting.
23 (0.03/day)
Processor Intel Xeon E5-2696v3 (18 cores / 36 threads)
Memory 64 GB DDR4-2133 Quad Channel
Video Card(s) XFX AMD Radeon RX 6600 8 GB GDDR6
Display(s) HP LP2475W 24" 1920x1200
Hi all,
I am considering an upgrade of my computer for work purposes and I want a powerful home machine. The use will be for programming and use of several virtual machines (VirtualBox type, with Windows and GNU/Linux operating systems running).
For the use of virtual machines, which one would be more recommended? For example, an Intel i9-13900 or a Ryzen 9 7950X? I say this because the Intel efficient cores issue has me somewhat confused in a VirtualBox type virtual machine environment. When assigning cores to the machines? do you see only the P-cores or the E-cores as well?
Thanks!
6,431 (2.85/day)
Poland
Video Card(s) RTX3080 Ti FE
Display(s) LG 34GN850P-B
Mouse Endgame Gear XM1R
Keyboard Wooting Two HE
5950X, why? Cost efficient, don't need expensive AM5 board, DDR5 etc. And should cool better too.
Count von Schwalbe
Nocturnus Moderatus
3,445 (2.73/day)
Knoxville, TN, USA
Hi all,
Thanks!
Does VirtualBox support AVX-512 instructions for the host side? I cannot seem to find it on Google.
302 (0.29/day)
Germany
System Name Galaxy Tab S8+
Processor Snapdragon 8 gen 1 SOC
Cooling passive
Memory 8 GB
Storage 256 GB + 512 GB SD
Display(s) 2.800 x 1.752 Super AMOLED
Power Supply 10.090 mAh
Software Android 12
While I really like your logic, it still might be better to go with AM5, especially on a system used for professional applications where you want to be able to have an easy upgrade path without having to replace motherboard and memory later on nonetheless.
18,584 (2.63/day)
System Name AlderLake
Most people have an AMD system here so they probably recommend AMD.. :D
6,431 (2.85/day)
Poland
Key thing being professional applications and for that you want stability. AM5 is still in its infancy.
302 (0.29/day)
Germany
Cooling passive
Memory 8 GB
Software Android 12
Based on that logic you would have to get a Workstation. Your original argumentation just was about pricing and cooling.
23 (0.03/day)
I don't mind paying a bit more in the end. The performance between the 5000 and 7000 series in terms of single-core and multi-core is enough to consider the 7950X.
I really don't know. But in the case that it does support it, what would be the choice, and would it have a big impact on performance?
Thanks for your help!
That's right. It's really for a home PC, not a professional one. In that case, I would have opted for a ThreadRipper with many cores.
501 (0.52/day)
System Name Firestarter
Processor 7950X
Motherboard X670E Steel Legend
Cooling LF 2 420
Memory 4x16 G.Skill X5 6000@CL36
Video Card(s) RTX Gigabutt 4090 Gaming OC
Storage SSDS: OS: 2TB P41 Plat, 4TB SN850X, 1TB SN770. Raid 5 HDDS: 4x4TB WD Red Nas 2.0 HDDs, 1TB ext HDD.
Display(s) 42C3PUA, some dinky TN 10.1 inch display.
Case Fractal Torrent
Audio Device(s) PC38X
Power Supply GF3 TT Premium 850W
Mouse Razer Basilisk V3 Pro
Keyboard Steel Series Apex Pro
VR HMD Pimax Crystal with Index controllers
I think the 7950x is the better option of the two. I currently have it but cannot say many things about professional work and stability. (I have to wait for my new GPU so I'm just enjoying stuff.)
It's also pretty much the best time to get one.
Count von Schwalbe
Nocturnus Moderatus
3,445 (2.73/day)
Knoxville, TN, USA
AVX-512 support can dramatically improve performance if you have a CPU that supports it. The only current CPUs that support it are the Ryzen 7000 series.
I could find that the guest machines are unable to access it, however some other virtualization programs (particularly PS3 emulation) can use it for the performance boost.
If it were me I would go for the 7950X, but I am a bit biased by dislike for Intel's business practices.
501 (0.52/day)
Processor 7950X
Cooling LF 2 420
Advanced Marketing Devices has affected this forum too much according to UserBenchMarkarkdark.com.
948 (0.14/day)
Round Rock, TX
Processor 9800x3d
Motherboard Asus Strix X870E-E
Cooling Kraken Elite 280
Memory 64GB G.skill 6000mhz CL30
Video Card(s) Sapphire 7900XTX Pulse
Storage 1X 4TB MP700 Pro - 1 X 4TB SN850X
Display(s) LG 32" 4K OLED + LG 38" IPS
Case Lian Li o11 Air Mini
Power Supply Corsair RM1000x
Software WIndows 11 Pro
I have a 12900K system and a 7950X system, I have run vmware workstation on both of them.
They both handle virtualization without any issues.
Having said that, i would probably choose the 7950X because it doesn't have the hybrid architecture.
Like i said, my 12900k handles virtualization fine, but i only ever run a single VM at a time (i have a dedicated esxi box for other virtual machines)
44 (0.04/day)
Processor Epyc 7302
Motherboard Supermicro H12
Cooling Arctic SP3 4U
Memory 512GB
Video Card(s) Both of them
Storage 90 TB or so
Display(s) yes
Case Filled with RGB
Audio Device(s) Apple USB-C DAC
Virtual machines are not emulation. If the hypervisor bares the AVX instructions, they'll work as is.
Any (even old) CPU will work, it just boils down what sort of program are you intending to run in the VM.
23 (0.03/day)
I'm a teacher and I usually run several VirtualBox instances to explain how to interconnect different virtual machines (Windows and GNU/Linux using Samba, for example).
While I'm programming, I use to compile big amount of code, resize a huge amount of images, etc. So I need a powerful machine.
302 (0.29/day)
Germany
Cooling passive
Memory 8 GB
Software Android 12
The "problem" with intel is it's socket policy in my opinion. Their latest desktop CPUs (LGA1700 being EOL) are really good pieces of hardware but - not only for cost reasons but also eco-friendliness (e-waste) - having a socket for just 2 generations and sometimes even having to get a new motherboard nonetheless, because the old chipset on the same socket might not support it, is - at least for me - the reason not to buy intel.
qubit
Overclocked quantum bit
17,865 (2.81/day)
Quantum Well UK
System Name Quantumville™
Cooling Noctua NH-D14
Case Cooler Master HAF 922
Power Supply Corsair AX1600i
Keyboard Yes
Do those CPUs have VT-d? That might be important to you since you'll have multiple VMs running at once.
23 (0.03/day)
I supposed that for a hi-end processor nowadays :confused:
freeagent
10,381 (4.30/day)
Winnipeg, Canada
System Name Step_sis Rodeo
Display(s) LG 50UP7100
Case Asus ProArt PA602
Audio Device(s) JBL Bar 700
VR HMD Oculus 3
Software Yes
Benchmark Scores Yes
There was a time not too long ago where it was the other way around :D
I haven't tried to run a VM for a while, but had no problem with it on Intel, haven't tried with AMD.
qubit
17,865 (2.81/day)
Quantum Well UK
Keyboard Yes
948 (0.14/day)
Round Rock, TX
Processor 9800x3d
Either one will work, both CPUS have their respective virtualization tech (Intel VT-x or AMD-V)
I'm a little old school in that i'd rather have all the same types of cores for that, but honestly intel thread director would take care of that part of it.
Deleted member 223428
From W1zzard's own testing, the 7950x (and 5950x) were faster for VirtualBox:
From here:
bug
14,338 (3.95/day)
Processor Intel i5-12600k
Motherboard Asus H670 TUF
Cooling Arctic Freezer 34
Case Raijintek Thetis
Keyboard G.Skill KM780R
Software Arch Linux + Win10
From here:
I'm not sure how VirtualBox feels about E-cores. That may be a factor in deciding what to buy.
23 (0.03/day)
From here:
Thanks for the review, it's useful.
That's what it dizzy me... When you select a number of cores in VirtualBox, will they be e-core or p-core? Strange...
bug
14,338 (3.95/day)
Without further information, you can assume they'll be picked at random and you may be able to exert some control by disabling E-cores entirely or use process lasso to avoid them. Whether you want to do that or you'd be better served by a homogeneous architecture (i.e. Zen), I cannot say.
I'd read up a little about VirtualBox on Alder Lake first, who knows, maybe they play nicely together.
44 (0.04/day)
Processor Epyc 7302
Memory 512GB
Storage 90 TB or so
Display(s) yes
Doesn't matter. You can create virtual machine even without VT-d but you won't be able to access PCI devices. If you don't know / understand what it is, you won't need it. I don't believe VirtualBox even supports it. Hyper-V, xen, ESXi, kvm et al do but you need to be more than hobbyist to use them.
Should be up to the host OS. VirtualBox in essence is like running a game, but you get to choose how many cores it exposes to the process. It can be as simple as running solitare or heavy like modern AAA games. If it's heavy on the processor, the host will allocate more resources, so it would use P-core to run it or if it's light it'll just use the E-cores. Running multiple VMs just mean you run multiple heavy process simultaneously. It's up to the host system.
You guys assume virtual machines are something exotic or complex. In the end your browser window can be thought of a hypervisor running multiple VMs if you have multiple tabs.
