CPU not coming out of am4 socket
avria
6 (0.01/day)
If the motherboard I have does not release the processor, the security lock is broken, the socket is cracked, how can I remove it? Processor installed
I just want to remove the processor, the top part is cracked.
44,283 (6.80/day)
Clean the ihs and use a suction cup, gently use a razer blade on 2 sides and get between the cpu and socket use a prying motion
freeagent
10,391 (4.30/day)
Winnipeg, Canada
Cooling Thermalright Phantom Spirit 120 EVO, 2x T30
Memory 2x 16GB Lexar Ares @ 6400 28-36-36-68 1.55v
Display(s) LG 50UP7100
Case Asus ProArt PA602
Audio Device(s) JBL Bar 700
VR HMD Oculus 3
Software Yes
Benchmark Scores Yes
It shouldn't take much to get it out, it is a ZIF socket, There is noting holding it in place.
44,283 (6.80/day)
The crack is where the latch bar is so it may not allow the locking mechanism to slide upwards/downwards
avria
6 (0.01/day)
what is ihs and what is suction cup i don't have much english sorry
Should I insert the razor blade into the processor or the edge of the plastic?
top full crack.
100 (0.05/day)
System Name Annihilator
Processor 5800X
Motherboard MSI x570 Gaming Plus
Cooling ID-COOLING FrostFlow X 240
Memory 32GB TForce Xtreem White
Video Card(s) ASRock RX 7800XT Steel Legend
Storage NVME Gen-3 1 TB, 2 TB SSD
Display(s) 32" 144Hz 2k + 34" UW 2k
Case Kediers C-580
Audio Device(s) Sony 5.1 Home Theater
Power Supply TT 850W True Power
Mouse EVGA x20
Keyboard EVGA Z15 RGB Mechanical Gaming Keyboard
Software Winbdows 11
Benchmark Scores 13,797 with AMD Radeon RX 7800 XT(1x) and AMD Ryzen 7 5800X on FireStrike Ultra
Re-paste it, put the heat sink, run a few hours. Then pull cooler as fast as you can, and the cpu might come out with it.
Disclaimer: obviously joking, AM4 does tend to have that problem often.
avria
6 (0.01/day)
I applied mx4 thermal paste and waited for 1 day, I suddenly pulled it out, but there is no movement of an inch.
Should I apply super glue? @eidairaman1
44,283 (6.80/day)
Erm that's the first time ive seen a latch bar crack, and ive only ever pulled out 2 478 p4s by accident because stuck to heatsink.
No, use the suction cup on the face of the processor (integrated heat sink- IHS) and 2 razorblades between the cpu and socket, be gentle with the razorblades getting them in so you don't nick the pins or scratch the circuit board the pins are mounted to. Get another set of hands to help you pull on the suction cup while you are prying with the razorblades
44,283 (6.80/day)
@eidairaman1
I removed the processor, but I have a problem, the socket has pulled the plug, is there a repair for it?
No there is no repair you can do at your level.
You are going to need an electronics repair shop such as Northridgefix or Krisfix.de to replace the socket.
Were there any pins removed from the cpu itself?
avria
6 (0.01/day)
cpu pin normal.
44,283 (6.80/day)
1,029 (0.29/day)
Nova Scotia, Canada
Cooling Cooler Master Hyper 212 Plus
Memory 32GB 4x8 G.SKILL Trident Z 3200 CL14 1.35V
Video Card(s) PCWINMAX RTX 3060 6GB Laptop GPU (80W)
Storage 1TB Kingston NV2
Case Fractal Design Arc XL
Audio Device(s) ATH-M20x
Mouse Evga Torq X3
Software Win 11 Pro 64-Bit
IMO I'd just get a new (or used) motherboard. Looks like a budget board and not worth the repair cost.
44,283 (6.80/day)
Yup, by the time the repair happens a brand new board can be had for less
avria
6 (0.01/day)
Thankyou everyone.
but the cpu is working i just unplugged the socket....
freeagent
10,391 (4.30/day)
Winnipeg, Canada
VR HMD Oculus 3
Software Yes
Nice one bud.
Didn't see that one coming..
2,837 (1.29/day)
PNW, USA
System Name Metalia
Processor AMD Ryzen 7 5800X3D
Memory 2x32GB DDR4-3600
Thankyou everyone.
:eek:
This thread was some genuine "eGore".
@TPUstaff, do we need to blurr his pics?! That's gruesome!
Laughs aside, I'd bet the socket cracked under an overtighted cooler, or something was dropped on the mounted cooler.
For future reference:
many hardware stores sell suction cups for bathroom-shower mounting hooks, as well as handling/installing/uninstalling glass.
Oh, I got quite the laugh @BetrayerX .
That was exactly what I was thinking:
"I've accidentally done this at least 3 times, and OP can't manage it on-purpose?!"
Turned out, OP's socket was already pretty F'd; not sure if 'care' would've prevented the horrors witnessed.
Thankfully, AM4 boards aren't that spendy, especially if not an 'enthusiast' board.
Also, as mentioned: an experienced board-level repair-er will have the tools and skill to replace the socket, but unless "you know someone" it's gonna prolly be more cost-effective to replace the whole board.
44,283 (6.80/day)
:eek:
Ive never damaged a zif at all, but yeah overtightening like above would do that
2,837 (1.29/day)
PNW, USA
System Name Metalia
I've broken a ZIF socket before, but not exactly like OP.
I've busted the retaining 'nub' off S370 (thankfully, it was fixable with a swap of the retaining clip to one that contacted all 3(err, 2) nubs.)
I've seen cracked sockets and broken retension mechanisms too, but CPUs still slotted in/out fine, and the cooler retained the CPU fine.
44,283 (6.80/day)
I've seen cracked sockets and broken pretension mechanisms too, but CPUs still slotted in/out fine, and the cooler retained the CPU fine.
I killed an Athlon XP 3200 by bending the clip to add more clamp force on a heatsink, that is when i grabbed an AXP-M 2500+
I Have broken the P4 retention Bracket though.
I have acquired an AXP 3200+ 2 years ago from @Mr.Scott, just haven't used it yet.
100 (0.05/day)
Processor 5800X
Case Kediers C-580
Mouse EVGA x20
I've been careful pulling out an AM4 CPU, and yet it sticks on the cooler. No damage has ever happened, luckily.
Gotta agree, the repairs on the board could cost a lot, May be a new board should be the best option.
8,312 (5.24/day)
São Paulo, Brazil
Cooling Pichau Lunara ARGB 360 + Honeywell PTM7950
Memory 32 GB G.Skill Trident Z5 RGB @ 7600 MT/s
Video Card(s) Palit GameRock GeForce RTX 5090 32 GB
Storage 500 GB WD Black SN750 + 4x 300 GB WD VelociRaptor WD3000HLFS HDDs
Display(s) 55-inch LG G3 OLED
Case Cooler Master MasterFrame 700 benchtable
Mouse Microsoft Classic IntelliMouse
Software Windows 10 Pro 22H2
I broke a CPU inside an AM3 socket once (a Phenom 1090T I lazily mounted on a motherboard without the retention bracket), but the socket survived as far as I could tell. Just the pins center mass on the CPU didn't. That said, it almost looks like the same happened here except the CPU survived and the motherboard broke because of its shoddy build quality. OP should just buy another and go on their merry way.
