Crazy - computer starts up by itself
Raw
551 (0.11/day)
System Name it's a computer
Processor INTEL i5-2500K OC'ed @ 4.5GHz
Motherboard ASUS Z68-V DELUXE Gen3
Cooling NOCTURA NH-C14
Memory 16 GB CORSAIR Vengeance (4 x 4GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800)
Video Card(s) EVGA GTX 970 SSC 4GB
Storage Intel® Solid-State Drive 730 Series SSDSC2BP240G4R5 2.5" 240GB SATA 6Gb/s MLC
Display(s) SAMSUNG 24HD Model # 2494 Sync Master
Case CM HAF 922
Power Supply CORSAIR Gold AX850 Full Modular
Crazy - computer starts up by itself all of a sudden.
I don't have a clue as to what is causing this but I power down one of my computers and come back to it in a couple hours and it's on.
Sitting there at the log-in screen.
Yea, I know I can turn off the power switch at the power supply or unplug it at the wall... but I want to find out what is causing this.
Only one machine is doing this out of four.
All run the same Win 7 setup.
Any ideas?
954 (0.22/day)
Cumberland Plateau
System Name EVGA-FX | Lenny (Lenovo Y480)
Processor AMD FX-8320 @ 4.5GHz 1.416v | i7 3610qm
Motherboard Asus M5A99FX Pro R2.0
Cooling Phanteks PH-TC14PE
Memory 2x4GB Corsair Vengeance @ 1600 | 8gb DDR3 @ 1600
Video Card(s) EVGA GTX780 Classified @ 1228MHz 1.615v | GT640m LE
Storage Crucial M500 480GB, WD Caviar Blue 500GB, WD Scorpio Blue 750GB | Samsung 250GB 840
Display(s) Qnix QX2710 1440p | 42" Vizio 3D LCD TV 1080p
Case CoolerMaster HAF XB Evo
Power Supply Seasonic G-650
Software Windows 6.3.9600
Swap the power supplies and see if the problem follows?
rtwjunkie
PC Gaming Enthusiast
14,034 (2.29/day)
Louisiana
Processor Core i9-9900k
What are your power settings in BIOS?
Raw
551 (0.11/day)
Case CM HAF 922
I don't think that's it
I think it's not hardware related, but thanks.
It's probably software, like Windows Firewall rules.
I am going through them right now.
I found a couple strange things in there related to File and Printer Sharing.
I had that stuff all turned off but I find some of the rules have changed and were on??
I'm playing with Windows Firewall Advanced at the moment to see what else looks strange.
Raw
551 (0.11/day)
Case CM HAF 922
Which particular power settings
Which particular power settings are you referring to?
What power setting would cause random power ons?
brandonwh64
19,542 (3.42/day)
Windows would have no effect on your PC's physical power pulse unless you are mistakenly putting it in sleep or hybernate with say the mouse being moved to activate.
Raw
551 (0.11/day)
Case CM HAF 922
Ok, I'm listening to ya. I'm all ears.
And I would think not, too. But what would you think may be causing it?
My power settings in Windows are "never" for display and sleep.
brandonwh64
19,542 (3.42/day)
Could be a grounding issue or issues with the power button not decompressing. Also I have my machine at work set in the bios to be always on so if the PSU has power then it automatically boots the PC. I do this to ensure it continues crunching for TPU.
Open the case and unplug the power pin that goes to the motherboard and shutdown then wait. It could tell alot!
Raw
551 (0.11/day)
Case CM HAF 922
Ok, just for the hell of it
Ok, just for the hell of it and because I have a lot of spare stuff laying around I did swap the PS for a brand new Corsair 850, although I don't believe that's the issue.
I also checked the power on switch, it's not sticky at all. It's a Cooler Master HAF case in a clean environment and seems to be working good.
Now I have to watch it for a while to see if it starts up by itself.
:toast:
1,571 (0.30/day)
Kolkata, India
System Name Coffee | Maximus
Processor Intel Core i7 9700K @ 5.2 GHz with AVX/4.8 GHz cache | i7 9700KF @ 5.0 GHz/4.7 GHz cache
Motherboard ASUS Maximus X Formula | ASUS Maximus VIII Ranger (modded BIOS for Coffee Lake)+TPM2.0 module
Cooling Cooler Master ML240 Illusion | Cooler Master ML120L RGB
Memory 2*16 GB (32 GB) Kingston Fury Beast @3600 MHz CL17 | 4*8 GB (32 GB) HyperX Fury @3200 MHz CL14
Video Card(s) Zotac RTX 3070 8 GB Twin Edge OC | Galax RTX 2060 Super 8 GB
Storage Samsung PM981a 1TB+Crucial P5 1TB+480GB SATA SSD+2 TB HDD | Crucial P1 500GB+2.5TB HDDs
Display(s) LG OLED 55 G3, 4K 120 Hz, VRR, ALLM, GSync, FreeSync | Samsung 43AU9070 4K TV, VRR, ALLM
Case Corsair Crystal 460X RGB | Lianli Lancool 215
Audio Device(s) Creative Sound Blaster Z SE w LG SC9S Dolby/DTS | Realtek ALC1150 (Supreme FX) w 2.1 speakers
Power Supply ASUS ROG Strix 750G (80+ Gold) | Cooler Master MWE 650 V2 (80+ Bronze)
Mouse Cooler Master MM731 19000 DPI gaming mouse
Keyboard Cooler Master CK721 65% mechanical gaming keyboard (tactile)
Software Windows 11 Pro x64 |Windows 11 Pro x64
Benchmark Scores Cinebench R20 MT 4200,ST 547 CPU-Z MT 4871, ST 620 | R20 MT - 4158, ST - 534, CPU-Z MT 4798, ST 603
Check and see if Wake on LAN or wake on mouse and similar stuff is enabled or disabled in BIOS.
stinger608
11,250 (1.87/day)
Wyoming
System Name 2023 Ryzenfall
Processor AMD Ryzen 5800X
Cooling SilverStone AH240 AIO
Case Corsair Air 540
Audio Device(s) On board
Also check to make sure the CMOS battery is still okay. A dead battery can cause this as well.
Raw
551 (0.11/day)
Case CM HAF 922
Damn machine did it again
Damn machine did it again about an hour after I replaced the PS.
I went out for an hour and came back, it was on.
Battery...the bios is holding the date and time ok.
All power on settings are set to disabled state in the bios.
:eek:
TheMailMan78
Big Member
22,598 (3.46/day)
'Merica. The Great SOUTH!
That's not really 100% true. A computer can be turned on remotely via the Ethernet card if the mobo supports it. Raw turn that bitch off and disconnect the Ethernet cable. I bet she stays off. If it does you got other issues. ;)
Wrigleyvillain
PTFO or GTFO
7,702 (1.20/day)
Chicago
System Name DarkStar
Processor i5 3570K 4.4Ghz
Motherboard Asrock Z77 Extreme 3
Cooling Apogee HD White/XSPC Razer blocks
Memory 8GB Samsung Green 1600
Video Card(s) 2 x GTX 670 4GB
Storage 2 x 120GB Samsung 830
Display(s) 27" QNIX
Case Enthoo Pro
Power Supply Seasonic Platinum 760
Mouse Steelseries Sensei
Keyboard Ducky Pro MX Black
Software Windows 8.1 x64
Yeah. Ghostly issues.
Or maybe some weird short. A packet is the most likely culprit though.
Raw
551 (0.11/day)
Case CM HAF 922
Thanks MM.
4,357 (0.87/day)
Mexico
System Name Dell-y Driver
Processor Core i5-10400
Motherboard Asrock H410M-HVS
Cooling Intel 95w stock cooler
Memory 2x8 A-DATA 2999Mhz DDR4
Video Card(s) UHD 630
Storage 1TB WD Green M.2 - 4TB Seagate Barracuda
Display(s) Asus PA248 1920x1200 IPS
Case Dell Vostro 270S case
Power Supply Dell 220w
Software Windows 10 64bit
You could also look into "Wake Up on RTC" options, although that only works with sleep mode as far as I know.
8,102 (1.32/day)
Hillsboro, OR
System Name Main/DC
Processor i7-3770K/i7-2600K
Audio Device(s) on board
Another thing that can make systems restart is a shorted USB. Normally this causes an immediate restart, but maybe you have something that shorts as it cools down.
Outback Bronze
Super Moderator
2,196 (0.44/day)
Walkabout Creek
System Name Raptor Baked
Processor 14900k w.c.
Motherboard Z790 Hero
Cooling w.c.
Memory 48GB G.Skill 7200
Video Card(s) Zotac 4080 w.c.
Storage 2TB Kingston kc3k
Display(s) Samsung 34" G8
Case Corsair 460X
Power Supply PCIe5 850w
Mouse Razer
Keyboard Corsair
Software Win 11
Hmm, default the bios and check if your power on switch is not sticking. Also check the pins on the mainboard where the power on switch connects too.
Solaris17
Super Dainty Moderator
27,591 (3.84/day)
Alabama
System Name RogueOne
Processor Xeon W9-3495x
Video Card(s) MSI SUPRIM Liquid 5090
VR HMD Quest 3
all bout that WOL
6,270 (0.89/day)
New York
Processor INTEL CORE I9-9900K @ 5Ghz all core 4.7Ghz Cache @1.305 volts
Motherboard ASUS PRIME Z390-P ATX
Cooling CORSAIR HYDRO H150I PRO RGB 360MM 6x120mm fans push pull
Memory CRUCIAL BALLISTIX 3000Mhz 4x8 32gb @ 4000Mhz
Video Card(s) EVGA GEFORECE RTX 2080 SUPER XC HYBRID GAMING
Storage ADATA XPG SX8200 Pro 1TB 3D NAND NVMe,Intel 660p 1TB m.2 ,1TB WD Blue 3D NAND,500GB WD Blue 3D NAND,
Display(s) 50" Sharp Roku TV 8ms responce time and Philips 75Hz 328E9QJAB 32" curved
Case BLACK LIAN LI O11 DYNAMIC XL FULL-TOWER GAMING CASE,
Power Supply 1600 Watt
Take a look at your log files, there may be some hints there! Good luck :toast:
Raw
551 (0.11/day)
Case CM HAF 922
What else should I know about WOL?
all bout that WOL
Doing a little reading about WOL and here is what I gather. WOL is the Wake-on-LAN feature and only allows computers to be switched on; it does not in itself bypass password and other forms of security.
Raw
551 (0.11/day)
Case CM HAF 922
Raw
551 (0.11/day)
Case CM HAF 922
Hmmm...
I thought I did have a USB problem a couple weeks ago and a mouse died on me.
Bought a new mouse, thought all was good because the USB works good with the new mouse.
The plot thickens.
Thanks:toast:
Fourstaff
10,089 (1.79/day)
Home
Processor 3570K // 10400F
Cooling Stock // Stock
My Sensei RAW starts my brother's PC up, if that is of any help.
5,968 (0.93/day)
New York
Processor AMD Ryzen 9 9950x / AMD Epyc 7773x
Motherboard Gigabyte B850 Gaming X/ ASROCK ROME
Cooling Be Quiet Dark Rock Pro 4(Custom) / Custom Air
Memory 64GB Crucial Pro 6400 / 384GB
Video Card(s) MSI RTX5070Ti(Temporary)/ 4X RTX3090
Storage Adata SX8200 1TB NVME/WD Black 1TB NVME
Display(s) Dell 27 Inch 165Hz
Case Lian Li A3 Mini
Audio Device(s) IFI Zen Dac/JDS Labs Atom+/SMSL Amp+Rivers Audio
Mouse Logitech G502 SE Hero
Keyboard Corsair K70 RGB Mk.2
VR HMD Samsung Odyssey Plus/ Quest 3
I had a problem similar to this years ago, when I turned on my 360 it would turn on my pc instantly, are you sure that when you turn on something on the same socket its not causing the pc to turn on.
