System Name | Step_sis Rodeo |
Processor | AMD R9 9900X @ booost |
Motherboard | Asus Strix X670E-F |
Cooling | Thermalright Frost Commander 140, TY-143. T30 |
Memory | 2x 16GB Lexar Ares @ 6200 28-36-36-68 1.45v |
Video Card(s) | Zotac 4070 Ti Trinity OC @ 3045/1500 |
Storage | WD SN850 1TB, SN850X 2TB, 2x SN770 1TB |
Display(s) | LG 50UP7100 |
Case | Asus ProArt PA602 |
Audio Device(s) | JBL Bar 700 |
Power Supply | Seasonic Vertex GX-1000, Monster HDP1800 |
Mouse | Logitech G502 Hero |
Keyboard | Logitech G213 |
VR HMD | Oculus 3 |
Software | Yes |
Benchmark Scores | Yes |
System Name | WorkInProgress |
Processor | AMD 7800X3D |
Motherboard | MSI X670E GAMING PLUS |
Cooling | Thermalright AM5 Contact Frame + Phantom Spirit 120SE |
Memory | 2x32GB G.Skill Trident Z5 NEO DDR5 6000 CL32 |
Video Card(s) | Asus Dual Radeon™ RX 6700 XT OC Edition |
Storage | WD SN770 1TB (Boot)|1x WD SN850X 8TB (Gaming)| 2x2TB WD SN770| 2x2TB+2x4TB Crucial BX500 |
Display(s) | LG GP850-B |
Case | Corsair 760T (White) {1xCorsair ML120 Pro|5xML140 Pro} |
Audio Device(s) | Yamaha RX-V573|Speakers: JBL Control One|Auna 300-CN|Wharfedale Diamond SW150 |
Power Supply | Seasonic Focus GX-850 80+ GOLD |
Mouse | Logitech G502 X |
Keyboard | Cherry G80-3000N (TKL) |
Software | Windows 11 Home |
Benchmark Scores | ლ(ಠ益ಠ)ლ |
System Name | Compy 386 |
Processor | 7800X3D |
Motherboard | Asus |
Cooling | Air for now..... |
Memory | 64 GB DDR5 6400Mhz |
Video Card(s) | 7900XTX 310 Merc |
Storage | Samsung 990 2TB, 2 SP 2TB SSDs, 24TB Enterprise drives |
Display(s) | 55" Samsung 4K HDR |
Audio Device(s) | ATI HDMI |
Mouse | Logitech MX518 |
Keyboard | Razer |
Software | A lot. |
Benchmark Scores | Its fast. Enough. |
its not the contacts itself that're missing tho, looks like one side of the pcb's totally chipped off there, like this
nothing much you can do besides rma
System Name | Pioneer |
Processor | Ryzen 9 9950X |
Motherboard | MSI MAG X670E Tomahawk Wifi |
Cooling | Noctua NH-D15 + A whole lotta Sunon, Phanteks and Corsair Maglev blower fans... |
Memory | 128GB (4x 32GB) G.Skill Flare X5 @ DDR5-4000(Running 1:1:1 w/FCLK) |
Video Card(s) | XFX RX 7900 XTX Speedster Merc 310 |
Storage | Intel 5800X Optane 800GB boot, +2x Crucial P5 Plus 2TB PCIe 4.0 NVMe SSDs, 1x 2TB Seagate Exos 3.5" |
Display(s) | 55" LG 55" B9 OLED 4K Display |
Case | Thermaltake Core X31 |
Audio Device(s) | TOSLINK->Schiit Modi MB->Asgard 2 DAC Amp->AKG Pro K712 Headphones or HDMI->B9 OLED |
Power Supply | FSP Hydro Ti Pro 850W |
Mouse | Logitech G305 Lightspeed Wireless |
Keyboard | WASD Code v3 with Cherry Green keyswitches + PBT DS keycaps |
Software | Gentoo Linux x64, other office machines run Windows 11 Enterprise |
This. I see the same.its not the contacts itself that're missing tho, looks like one side of the pcb's totally chipped off there, like this
It's possible to repair it, but you shouldn't have to. If it was not disclosed in the ad, send it back.Hi i bought a GPU with damaged PCI-E connectors.
The card is detected gives image no artifacts but sometimes the driver restart itself at load.
Could it be because of this? I think those are 12v lines.
How should i test them or fix them?
Processor | i5-6600K |
Motherboard | Asus Z170A |
Cooling | some cheap Cooler Master Hyper 103 or similar |
Memory | 16GB DDR4-2400 |
Video Card(s) | IGP |
Storage | Samsung 850 EVO 250GB |
Display(s) | 2x Oldell 24" 1920x1200 |
Case | Bitfenix Nova white windowless non-mesh |
Audio Device(s) | E-mu 1212m PCI |
Power Supply | Seasonic G-360 |
Mouse | Logitech Marble trackball, never had a mouse |
Keyboard | Key Tronic KT2000, no Win key because 1994 |
Software | Oldwin |
Some good ideas here. However, the conductive ink ... I very much doubt its conductivity is anywhere close to copper. Has anyone tried to repair PCB tracks carrying high current, and succeeded? The ink would also need to have enough mechanical strength so it's not peeled or chipped off the first time the card is inserted into slot.Tape the long side, use very tiny amounts of super glue (cyanoacrylate) and then some baking soda (sodium bicarbonate) to form the plastic, use a scalpel and mask off with tape to sand the new plastic and then the conductive pen to form the new traces.
Or solder some wires to the traces and make a connector to attach to the PSU
System Name | nope |
Processor | I3 10100F |
Motherboard | ATM Gigabyte h410 |
Cooling | Arctic 12 passive |
Memory | ATM Gskill 1x 8GB NT Series (No Heatspreader bling bling garbage, just Black DIMMS) |
Video Card(s) | Sapphire HD7770 and EVGA GTX 470 and Zotac GTX 960 |
Storage | 120GB OS SSD, 240GB M2 Sata, 240GB M2 NVME, 300GB HDD, 500GB HDD |
Display(s) | Nec EA 241 WM |
Case | Coolermaster whatever |
Audio Device(s) | Onkyo on TV and Mi Bluetooth on Screen |
Power Supply | Super Flower Leadx 550W |
Mouse | Steelseries Rival Fnatic |
Keyboard | Logitech K270 Wireless |
Software | Deepin, BSD and 10 LTSC |
If you think that 2mm x 3mm piece that is missing will cause a noticeable stability issue, be realistic. It will be just as secure as any other gpu.I would avoid plugging this card directly to any motherboard , buy a pci-e riser and jump-solder the broken pads from the gpu to the riser and use it that way , that connector is supposed to carry so much weight and mechanical friction I don’t see any way to restore normal function besides using a riser that will be attached to this gpu forever
System Name | PCGOD |
Processor | AMD FX 8350@ 5.0GHz |
Motherboard | Asus TUF 990FX Sabertooth R2 2901 Bios |
Cooling | Scythe Ashura, 2×BitFenix 230mm Spectre Pro LED (Blue,Green), 2x BitFenix 140mm Spectre Pro LED |
Memory | 16 GB Gskill Ripjaws X 2133 (2400 OC, 10-10-12-20-20, 1T, 1.65V) |
Video Card(s) | AMD Radeon 290 Sapphire Vapor-X |
Storage | Samsung 840 Pro 256GB, WD Velociraptor 1TB |
Display(s) | NEC Multisync LCD 1700V (Display Port Adapter) |
Case | AeroCool Xpredator Evil Blue Edition |
Audio Device(s) | Creative Labs Sound Blaster ZxR |
Power Supply | Seasonic 1250 XM2 Series (XP3) |
Mouse | Roccat Kone XTD |
Keyboard | Roccat Ryos MK Pro |
Software | Windows 7 Pro 64 |
Higher resistance can occurIf you think that 2mm x 3mm piece that is missing will cause a noticeable stability issue, be realistic. It will be just as secure as any other gpu.
Physically there is enough blade area from the big blade to hold in place but with the contact area being smaller there is a higher chance of electrical failureWhen I say stability, I mean physical stability. The previous poster alluded that the card would physically fall out of the slot or damage it further somehow.
System Name | Asus X450JB |
Processor | Intel Core i7-4720HQ |
Memory | 2x 4GiB |
Video Card(s) | nVidia GT940M |
Storage | 2x 1TB |
System Name | HELLSTAR |
Processor | AMD RYZEN 9 5950X |
Motherboard | ASUS Strix X570-E |
Cooling | 2x 360 + 280 rads. 3x Gentle Typhoons, 3x Phanteks T30, 2x TT T140 . EK-Quantum Momentum Monoblock. |
Memory | 4x8GB G.SKILL Trident Z RGB F4-4133C19D-16GTZR 14-16-12-30-44 |
Video Card(s) | Sapphire Pulse RX 7900XTX. Water block. Crossflashed. |
Storage | Optane 900P[Fedora] + WD BLACK SN850X 4TB + 750 EVO 500GB + 1TB 980PRO+SN560 1TB(W11) |
Display(s) | Philips PHL BDM3270 + Acer XV242Y |
Case | Lian Li O11 Dynamic EVO |
Audio Device(s) | SMSL RAW-MDA1 DAC |
Power Supply | Fractal Design Newton R3 1000W |
Mouse | Razer Basilisk |
Keyboard | Razer BlackWidow V3 - Yellow Switch |
Software | FEDORA 41 |
Which gpu is it anyway ?When I say stability, I mean physical stability. The previous poster alluded that the card would physically fall out of the slot or damage it further somehow.
System Name | MSi Coffee Lake |
Processor | i7-8700k |
Motherboard | MSI Z370 GAMING PRO CARBON AC |
Cooling | NZXT something AIO loop |
Memory | 16GB Kingston HyperX 2133 C14 Fury Black |
Video Card(s) | TITAN Xp Jedi Order Edition |
Storage | Samsung 960 Evo NVMe |
Display(s) | Medion 23' |
Case | Cooler Master Stryker |
Audio Device(s) | onboard |
Power Supply | BeQuiet 600W |
Mouse | Logitech Trackman T-BB18 |
Keyboard | Generic hp |
Software | Windows 10 |
Good, hope it last you till you can get a new shiny gpuThanks for all the replies.
Fortunately it was only a wrong vBIOS (memory manufacturer was incorrect).
It's working correctly under load now, so I think it makes contact.
BTW I bought it for ~100eur as "not working" so I couldn't return it. For that price i'm really happy with it.
