DDR2 REF Voltage????
DaMulta
My stars went supernova
16,168 (2.35/day)
Oklahoma T-Town
System Name Work in progress
Processor AMD 955---4Ghz
Motherboard MSi GD70
Cooling OcZ Phase/water
Memory Crucial2GB kit (1GBx2), Ballistix 240-pin DIMM, DDR3 PC3-16000
Video Card(s) CrossfireX 2 X HD 4890 1GB OCed to 1000Mhz
Storage SSD 64GB
Display(s) Envision 24'' 1920x1200
Case Using the desk ATM
Audio Device(s) Sucky onboard for now :(
Power Supply 1000W TruePower Quattro
How do I add Ref voltage to normal DDR voltage?
I can go +2.0 on the Ref.
But only up to 2.3 on the normal DDR2 Voltage.
2.3V is the maximum DDR2 can go.
But if you want more you should buy a DDR Maximizer
I just want to know what DDR2 REF Voltage is.....
I'd like to know also, that's a term I'm not familiar with. I looked into some M/B's that use DDR2 REF Voltage settings along with regular DDR2 Voltage settings and it appears to be another way to fine tune/adjust/increase the voltage being applied to the memory. But I have yet to find a decent explanation of it. Probably would be useful for extreme overclocking of memory, I am intrigued by this now, I will keep diggin for info on it! :toast:
I don't know if this helps but here is the link
It's a PDF
1.8 is ref.
Besides I don't trust a document that misspells compromising.
so REF=Reference or stock setting then? That would make sense, so then Dam's 8500 ref or recommended stock voltage is 2.0v then? Interesting, good to know. But what about DDR Voltage REF settings on M/B's, a couple had +2%, 0%, -2%, or +.3mv, 0mv, -3mv, something along those lines...
The problem is when DDR2 hit the streets it was supposed to be the final answer to high power hot memory. But that didn't happen, just like with DDR, more voltage means more speed or lower latencies. So some brands require 2.0 or 2.2 for their rated speed and timings. Thus making then no better than a 1.8 set that runs looser timings but can run faster at higher voltage.
Long story short.
1.8V @ 5.5.5.15 400Mhz
2.0v @ 5.5.5.12 400Mhz
Both should do 420 or 430 at 2.0 or 2.1v and @ 5.5.5.12 timings most likely. The rest is just bullshit marketing games.
So far as the mother board values it is just showing compatibility for SPD modules to boot to stocks settings IE 5.5.5.12 @ 2.0 400Mhz.
That's what my board has.
So on one has used this?
