- Apr 18, 2013
- 1,260 (0.28/day)
- Artem S. Tashkinov
As late as of the summer of 2022 there were reports that ADL systems couldn't keep up with four DDR5 memory modules/sticks and as a result RAM ran at much lower speeds or the system didn't POST at all.
@W1zzard
What's your experience been like? Could you run an article about the issue or lack of?
1) Do Ryzen 7000/RPL CPUs maintain advertised DDR5 speeds with all four modules installed?
2) Are there better/worse motherboard vendors or motherboard brands in this regard?
3) What about performance? At least Ryzen 5000 CPUs showed slight performance improvements when installing four memory modules. Is this still the case for DDR5?
4) Is running four DDR5 sticks an install and forget experience or you need to tweak something, e.g. RAM/IMC voltage?
The reason I'm asking is because my current Ryzen 5800X system has 64GB of RAM (16x4, 3600MHz, CL17) and if I am to upgrade to DDR5 I want to have 128GB of relatively fast DDR5 RAM which starts at ~$400 for 6000MHz CL32 (hopefully pricing will improve soon).
@W1zzard
