Bald Eagle
- Sep 26, 2012
- 74 (0.02/day)
- London - UK
I discovered some time ago a simple means of adding two desktop icons to cover Shutdown and Standby/Hibernate. I now use these icons all the time as it avoids using the Start procedure, which I never use at all unless I wish to Restart immediately after shutdown. Even then, I tend to use my desktop icons. Just close the browser, click the desktop icon and it is done.
On your desktop, right click the free space, then click new shortcut, you get a Wizard, copy/paste the command for the location type from one of the below commands (in this case, %windir%\System32\rundll32.exe powrprof.dll,SetSuspendState ). Then click Next. You are asked to give it a title - Standby, Hibernate or Shutdown, I suggest using "Standby/Hibernate", click Finish.
Shutdown: %windir%\System32\shutdown.exe -s
Reboot: %windir%\System32\shutdown.exe -r
Logoff: %windir%\System32\shutdown.exe -l
Standby: %windir%\System32\rundll32.exe powrprof.dll,SetSuspendState
Hibernate: %windir%\System32\rundll32.exe powrprof.dll,SetSuspendState Hibernate
I have listed Hibernate for reference only, as the Hibernate desktop icon does not work for systems reasons, Hibernate can only be achieved by manually using the Power Options properties panel.
Use CNTRL+C to copy and CNTRL+V to paste.
Hibernate is automatic if the Hibernate box is checked in the Power Options properties panel. If the box is not checked, then Standby is automatic. You have to select this box to give you the option you want.
Standby is more convenient if you are using the PC constantly, it is a quicker recovery, but has a power trickle. For long periods of absence, use Hibernate, it is much slower in recovering, but effectively shuts your computer down.
The Power options panel is found by Control Panel>Power Options>Hibernate.
The two desktop icons created can be changed by Right clicking the icon then Properties>Change icon>Browse>Windows 32>shell32dll>select icon>OK>Apply>OK
You now have two brand new icons on your desktop for Shutdown and Standby/Hibernate. It works a treat.
My icons are :-
My icons are :-
