Devil may cry 3 special edition problem
3,352 (0.59/day)
System Name Dark Stealth
Processor Ryzen 5 5600x
Motherboard Gigabyte B450M Gaming rev 1.0
Cooling Snowman, arctic p12 x2 fans
Memory 16x2 DDR4 Corsair Dominator Pro
Video Card(s) 3080 10gb
Storage 2TB NVME PCIE 4.0 Crucial P3 Plus, 1TB Crucial MX500 SSD, 4TB WD RED HDD
Display(s) HP Omen 34c (34" monitor 3440x1440 165Hz VA panel)
Case Zalman S2
Power Supply Corsair 750TX
Mouse Logitech pro superlight, mx mouse s3, Razer Basiliskx with battery
Keyboard Custom mechanical keyboard tm680
Benchmark Scores 70-80 fps 3440x1440 on cyberpunk 2077 max settings
Hello guys!
I am having a problem with devil may cry, but i can't really understand.
I have devil may cry 4 and it runs perfectly. When i open the game a black screen appears and that, DON'T SEND :P
Anyone who know or has had any experience with this problem?
I found in other forums that the card has the real problem with vertex. This is weird cuz my card runs dmc 4 really great.
Any help will be apprechiated!
Pls!!! Someone help T_T!
(sorry for the bump but i got no response)
what are your system specs? maybe you didnt update your graphics card drivers,
try to reinstall, in most cases I reinstalled game and works, it's worth a try...
reply if you tried one of the methods =)
I just tried all the methods you suggested and nothing changed the don't send screen
I have tried another program which disabled a lot of things, but none of the was of use too
Anyway thx for the reply as none has helped me till now ;)
hmmmm....i think it is the compatibility, i see you have windows xp 64 bit?
XP64 is terrible for gaming, tons of compatibility issues. that could well be the problem.
I guess none of your opinions is of usage, as x64 helps gaming and in another thread i have mentioned some facts about x64, why it is better than x32. That can't be the problem
we all use/support 64 bit (no such thing as x32, btw) - its XP 64 bit, that is the problem. its incompatible with many DRM and security methods, so the games dont work.
my advice, install windows 7 ultimate 32 bit, or windows xp SP3 32bit, i have these 2 windows, and I'm really satisfied with them, no problems for games ;)
I have seen in other forums that the real problem is of the card about vertexes
I have disabled this kind of problem but it still displays dont send
Windows xp 64 bit sucks for gamers.. like every1 else has already told you. If you wanna game and refuse to go to windows 7 then u have to use xp 32 bit to avoid headaches. Otherwise update to windows 7 64 bit
Yo man!
Look at this thread, there are proofs which explain why in x64 my rig is better and i think the 32 bit has already reached its limit
My rig is a beast in x64
The problem is either the card can't play it or it's xp64.
As far as I remember you didn't prove anything in that last thread that's why it was closed. Your not going to fix anything if you just ignore us.
64 bit is better
just not XP 64 bit
32 bit is not worth it with any OS except XP.
