Difference Between GTS and GTX
204 (0.04/day)
Lower Sackville, NS
System Name ThinkPad T410
Processor Intel Core i5 540M
Motherboard Lenovo 2522DM1
Cooling Stock
Memory 8GB DDR3
Video Card(s) nVidia NVS 3100M
Storage 128GB SSD
Display(s) 1440x900
Software Windows 8.1 64bit
What exactly is the difference between the GTX and GTS suffixes? :confused:
1,226 (0.20/day)
The Netherlands
System Name Silent allround
Processor i5 750 @ 3,0Ghz 1.04v / 3.4Ghz 1.11v/ 3,6Ghz 1.15v
Motherboard Gigabyte P55-USB3
Cooling Thermalright IFX-14 + Scythe Slip Stream 140mm @ 600RPM
Memory 2 x 4GB Samsung M378B5273DH0-CH9 @ 2000 MHz 9-10-10-27 T1
Video Card(s) Sapphire HD 5870 Vapor-X @ 940/1270
Storage Intel Postville 80GB SSD & Western Digital Green 2TB
Display(s) Dell Ultrasharp U2412M
Case Bitfenix Merc Alpha
Audio Device(s) Asus Xonar D2 with Unified Drivers
Power Supply Nexus NX-5000 R3 530W
Benchmark Scores Super pi 1M : 8,549s @ 4,7Ghz (Core i7 920)
Depends on which card we're talking about?
5,393 (0.92/day)
Kingsville, TX
System Name ODIN
Processor AMD Ryzen 7 5800X
Motherboard Gigabyte B550 Aorus Elite AX V2
Cooling Dark Rock 4
Memory G Skill RipjawsV F4 3600 Mhz C16
Video Card(s) MSI GeForce RTX 3080 Ventus 3X OC LHR
Storage Crucial 2 TB M.2 SSD :: WD Blue M.2 1TB SSD :: 1 TB WD Black VelociRaptor
Case Fractal Meshify C
Audio Device(s) Onboard Audio
Mouse Corsair M65
Keyboard Corsair K70 RGB Lux
Last 2 generations, nothing. The GTS are designed for power saving and make up the larger majority of the low end and entry level cards. The GTX label is reserved for the mid-range to enthusiast level cards. They are designed with the mentality of, "Who cards about power, focus on performance first."
GTX = focus on the performance
GTS = focus on power consumption
Now, 8000 series and older....that depended on the card, company, generation....ignore them and never buy cards that old.
crazyeyesreaper
Not a Moderator
9,841 (1.67/day)
System Name Old reliable
Processor Intel 8700K @ 4.8 GHz
Motherboard MSI Z370 Gaming Pro Carbon AC
Cooling Custom Water
Memory 32 GB Crucial Ballistix 3666 MHz
Video Card(s) MSI RTX 3080 10GB Suprim X
Storage 3x SSDs 2x HDDs
Display(s) ASUS VG27AQL1A x2 2560x1440 8bit IPS
Case Thermaltake Core P3 TG
Audio Device(s) Samson Meteor Mic / Generic 2.1 / KRK KNS 6400 headset
Power Supply Zalman EBT-1000
Mouse Mionix NAOS 7000
Keyboard Mionix
it use to be
LE GS GT GTS GTX ULTRA and there was a GTO in there as well basically it just determines where the gpu falls in the market
GTX = mid to high end
ULTRA = enthusiast high end aka $1000 gpu
GTS = mid range good price / performance etc etc
GT = low ti mid range
GS = low
LE = turbo cache utter garbage super crap
5,061 (0.86/day)
Processor AMD Ryzen 5 7600
Memory Kingston Fury Beast DDR5-5600 16GBx2
Video Card(s) Gigabyte Gaming OC AMD Radeon RX 7800 XT 16GB
Storage TEAMGROUP T-Force Z440 2TB, SPower A60 2TB, SPower A55 2TB, Seagate 4TBx2
Display(s) AOC 24G2 + Xitrix WFP-2415
Case Montech Air X
Audio Device(s) Realtek onboard
Power Supply Be Quiet! Pure Power 11 FM 750W 80+ Gold
Mouse Logitech G Pro X Superlight Wireless
Keyboard Royal Kludge RK-S98 Tri-Mode RGB Mechanical Keyboard
it use to be
GS = low
There's also cards with no suffix at all (GeForce 6600 v. 6600 GT)
If we're talking about the last two generations, it's G, GT, GTS, GTX, from low-range to high-end. These suffixes aims to confuse customers, because there are no differences in the number anyway...oh wait.
wolf
Better Than Native
8,685 (1.32/day)
System Name MightyX
Processor Ryzen 9800X3D
Motherboard Gigabyte B650I AX
Cooling Scythe Fuma 2
Storage WD Black SN850X 2TB
Display(s) LG 42C2 4K OLED
Case Coolermaster NR200P
VR HMD Meta Quest 3
GS = low
pretty much spot on, nowadays I'd hold GTX and Ultra in roughly the same regard, however they havent made an Ultra card in some time now, last was 8800Ultra I believe.
in between GT and GS there were sometimes 'vanilla' cards which had no suffix/prefix at all, like 6600 and 6800.
and lets not forget XT, used to denote the TOP end ATi cards of the era, it was the reverse with Nvidia, Used only for the bottom of the barrel. I learned that the hard way with an FX5600XT.
204 (0.04/day)
Lower Sackville, NS
Cooling Stock
Memory 8GB DDR3
Storage 128GB SSD
Display(s) 1440x900
Thanks guys, for some context im talkin about my gpu (GTS 250) with 1GB VRAM
AltecV1
1,286 (0.22/day)
Republic of Estonia
Processor C2D E8400@3.6 ghz
Motherboard ASUS P5KPL-AM
Cooling Freezer 7 pro
Memory Kingston 4GB 800Mhz cl6
Video Card(s) Sapphire HD4850 700/1000 + Accelero S1 Rev. 2
Storage WD 250 GB AAKS
Display(s) 22" Samsung SyncMaster 226BW
Audio Device(s) int.
Power Supply Forton Blue Storm II 500W
Software Windows 7 64bit Ultimate
wolf
Better Than Native
8,685 (1.32/day)
System Name MightyX
VR HMD Meta Quest 3
lol, that card/core has had a few of the prefix/suffixes.
essentially the fully unlocked (all 128 sp's) core started its life as an 8800GTS, then moved on to be the 9800GTX, getting higher clockspeeds all around. later it became the 9800GTX+ apon the transition from 65nm to 55nm, and againt got higher core/shader clockspeeds.
then when Nvidia made their GTX200 series cards, the GT200 core wasn't really viable to try and scale down to the performance they wanted for a midrange card, so the 9800GTX+ was again renamed to the GTS250.
and this is not naming all of the many many other cards that came to be from a G92 GPU.
754 (0.10/day)
Processor Intel Core i7 4790K
Motherboard Asus Z97i Plus
Cooling Antec Kuhler 620 + Gentle Typhoon 3000RPM
Memory A-DATA XPG V2 DDR3-2400 16GB
Video Card(s) MSI GTX 970 Gaming 4G
Storage Samsung 850 Ev0 500GB
Display(s) Qnix QX2710 @100Hz
Case Silverstone SG13
Power Supply Silverstone SX-500LG
Keyboard Corsair K70 Lux
Benchmark Scores Not interested in benchmarks
XT = Xtra Trash (nVidia)
XT = XTreme (ATI) ;)
5,393 (0.92/day)
Kingsville, TX
System Name ODIN
Cooling Dark Rock 4
Mouse Corsair M65
All the BS listed here is why I was so glad ATI finally just put their foot down about all these suffixs. Everyone is stil forgetting how the card makers would add extra stuff to the name after the fact like FTW, GTO, XTX, XXX, SC, OC, etc. It was a nightmare to tell which card was really the best. I am also glad Nvidia kinda followed ATI example and banned a lot of those suffixes as well, but the are starting to loosing up some. I hope the stop in this generation with letting slide since the technical name for the chip already has a three letter prefix. I don't want to see a GTX 460 XXX Edition. Give it a name like other companies and just call it something like GTX 460 Falcon. MSI and HIS already does this based on the cooler used.
wolf
Better Than Native
8,685 (1.32/day)
System Name MightyX
VR HMD Meta Quest 3
the 5600XT was about as rubbish as a gfx card can really get, having said that, once I realised just how shit it was, I did not hesitate to overclock the nuts off it as an experiment :) It was the first Nv card I ever oc'd ;) weird that later on I came apon a Gefore 4 Ti 4600 that was much faster.
EDIT: @ TheLaughingMan, around teh 8800 era I scapped calling cards what the Nv called them and just went for GPU codenames, like G92GT, G80GTX etc... waaay too many 8's and 0's.
8,102 (1.32/day)
Hillsboro, OR
System Name Main/DC
Processor i7-3770K/i7-2600K
Audio Device(s) on board
The other thing, today, is that some GTX have the ability to 3 or 4 way SLI, where as GTS is limited to 2 way.
hat
Enthusiast
21,754 (3.23/day)
Ohio
Cooling Cryorig M9 :: Stock
Benchmark Scores >9000
Dunno. There's so many prefixes and suffixes that both companies have it's tough to keep track. That, and individual retailers like XFX add thier own shit, like XXX editions.
8,102 (1.32/day)
Hillsboro, OR
System Name Main/DC
But at least both AMD and Nvidia have stopped with all the hoopla. Now it's the manufacturers who are trying to designate their different versions of the same GPU.
754 (0.10/day)
I love ati's way of naming cards.
5,061 (0.86/day)
Case Montech Air X
But their naming is still different. With AMD it's Radeon HD xxxx. For Nvidia it's GeForce Gxxx/G xxx/GT xxx/GTS xxx/GTX xxx.
5,519 (1.03/day)
There is no point in finding any sence in this branding. 8800GT is better than the GTS, but then came the 512MB GTS and...? GTS250 > 9800GTX.
dont search for any logical reason, just look at benchmarks.
wolf
Better Than Native
8,685 (1.32/day)
System Name MightyX
VR HMD Meta Quest 3
this is why I used GPU codenames at the time, for instance.
would be, G92GT is better than G80GTS, then came G92GTS, but I digress, benchmarks will show you the way.
754 (0.10/day)
i wonder why nVidia still uses GTX, GTS etc. suffixes. I mean, there is only ONE 480, only ONE 470, only ONE 465, only ONE (actually 2, but they still use GTX for both) 460.... etc.
204 (0.04/day)
Lower Sackville, NS
Cooling Stock
Memory 8GB DDR3
Storage 128GB SSD
Display(s) 1440x900
They do this probably to confuse buyers, so that they fall back on that old rule of thumb and just go with price = quality
wolf
Better Than Native
8,685 (1.32/day)
System Name MightyX
VR HMD Meta Quest 3
within a single company (ie Nv) the price you pay generally does mean you get a faster card, given the comparison is drawn from within the same generation.
hat
Enthusiast
21,754 (3.23/day)
Ohio
It would be nice if they would just make one card... the last time the same card had two suffixes was the 8800, and then they added a 3rd later.
