hello,
Do you have any advices on this. I can't compare with a normal processor, because I bought the cpu delidded, I just removed the lid, and cleaned again the die. After installing with an old XSPC Raystorm waterblock, I find it strange that under load the temperature gets hot very fast, from 30 to 60 degrees in an instant.
On the gpu it goes from 30 to 40.
Is the waterblock damaged and needs lapping? I fastened the screws as much as possible without damaging the die. I am not using springs, don't have them...
Or this is normal? The CPU die is much smaller then GPU, but still the power consumption is half or so.
