Disabling Control Flow Guard (CFG), an exploit protection feature in Windows 10 fixes various games stuttering
Does it fix your stuttering?
  • Wow! This completely fixes stuttering for me
    Votes: 6 66.7%
  • Nyet, comrade. Still runs like a Lada for me
    Votes: 3 33.3%
  • Total voters
    9
1,340 (0.35/day)
Nowy Warsaw
System Name SYBARIS
Processor AMD Ryzen 5 3600
Motherboard MSI Arsenal Gaming B450 Tomahawk
Cooling Cryorig H7 Quad Lumi
Memory Team T-Force Delta RGB 2x8GB 3200CL16
Video Card(s) Colorful GeForce RTX 2060 6GV2
Storage Crucial MX500 500GB | WD Black WD1003FZEX 1TB | Seagate ST1000LM024 1TB | WD My Passport Slim 1TB
Display(s) AOC 24G2 24" 144hz IPS
Case Montech Air ARGB
Audio Device(s) Massdrop + Sennheiser PC37X | Koss KSC75
Power Supply Corsair CX650-F
Mouse Razer Viper Mini | Cooler Master MM711 | Logitech G102 | Logitech G402
Keyboard Drop + The Lord of the Rings Dwarvish
Software Tiny11 Windows 11 Education 24H2 x64
Came up across this in Nvidia subreddit. While I'm always suspicious of any claim by DSOG, seems like many people are posting positive results. And while he claims it helps for DX12, some people are also claiming it helps in Witcher 3, Final Fantasy XV and Far Cry 5 which are DX11 titles.
One of the replies said this about the feature :
notgreat said:
It's a security thing that makes it so that malicious input causing a buffer overflow (or similar attacks) will crash the program rather than execute malicious code. Basically, don't disable it for anything connected to the internet and you'll probably be fine. (But it's still stripping away a layer of useful security)
While the DSOG author cites Resetera as source, the Resetera member sources his findings to a forum thread in Guru3D.
Here is the OG OP:
gerardfraser said:
1.Search and Open Exploit Protection
2.Click On the Program Settings Tab
3.Click On The + Add Programs To Customise
4.Click On Choose Exact File Path
5.Find Game Which You would Like To Try To Remove DX12 Stutter. Click Open
6.Programs Settings For Game Opened ,Scroll Down To Control Flow Guard (Never Use For Global Setting)
7.Put Check Mark In Override System Settings And Turn From On To Off And Apply
8.Restart May Be Needed
Here are some documentations about Control Flow Guard:
* Official Microsoft doc
* The Windows Club article on the feature
* Wikipedia
* CFG causes performance degradation for Chromium based browsers
* https://www.reddit.com/r/https%3A//www.reddit.com/r/PUBATTLEGROUNDS/comments/8jgz6g/disabling_control_flow_guard_in_windows_defender/dyzxvw8/
13,953 (2.04/day)
Nebraska, USA
Case Fractal Design Define R4
Mouse Logitech M190
Software W10 Pro 64-bit
I think if disabling Exploit fixes the game, the game has a bug and needs to be fixed.
44,274 (6.80/day)
Should be reported, however just like AVs, some have caused games to run like crap or suddenly start a scan.
13,953 (2.04/day)
Nebraska, USA
Mouse Logitech M190
True - but if 1/2 dozen 3rd party games and AVs out of 100s of games, security and other applications cause problems, I would point fingers at the 1/2 dozen 3rd party programs.
So yeah, "should be reported".
476 (0.14/day)
System Name Specs Last Update: 8/April/2024
Processor Intel Core i5 9400f 2.9GHz/4.0 Turbo (NoOC)
Motherboard Gigabyte Z370M D3H rev. 1.0
Cooling be quite! Dark Rock Slim 180W TDP (The Silent Wings 3 120mm Fan)
Memory Corsair Red Line 8x2 16GB 3000MHz (NoOC) DDR4-3000 15-17-17-35 (CMK16GX4M2B3000C15R) V1.35 ver 4.24
Video Card(s) NVIDIA GeForce MSI 980 Ti Golden Edition (NoOC)| Spare: GTX 650 Ti 1 GB
Storage Samsung 870 EVO 4 TB | Samsung 860 EVO 1 TB | Cold Backup: WDC Black 930 GiB WD1003FZEX
Display(s) Asus VG248QZ 1920x1080 144hz 24" (Current: 60hz)
Case Corsair Air 540
Power Supply Corsair 850W RMi
Mouse Logitech M187 wireless (First day of use 30-9-2021)
Keyboard Logitech K270 wireless
Software Windows 10 21H2 LTSC 2021 / Linux: Candidates: Bazzite - Linux MX - Tuxedo - Kubuntu
I have learned through out the years that even if I disabled the real time scanner/scanners of an AV, it could still bug app/s or the OS. I have this tendency to read the change log of a new update for various AVs to see what get fixed to learn what kind of bugs they can inflect.
Oh, and video codecs that gets installed on the system could also make troubles and having various GPU control apps running in the same time.
23,872 (6.16/day)
Trying this now. Looks interesting, somewhat credible.
138 (0.02/day)
Came up across this in Nvidia subreddit. While I'm always suspicious of any claim done by DSOG seems like many people are posting positive results. And while he claims it helps for DX12, some people are also claiming it helps in Witcher 3, Final Fantasy XV and Far Cry 5 which are DX11 titles.
One of the replies said this about it :
I can't check it atm and I don't have or remember any particular game that's a stuttery mess. So what you guys think?
Yeah I did up that guide last year or something for people to try.Some say placebo ,some say it works.I did notice since Control came out a few people referenced the guide.To the nutbars I did not invent this thing ,just was trying to help people out especially on Nvidia with DX12.There cards are terrible in most DX12 games,DX11 way better.
23,872 (6.16/day)
So far, good results. Lichdom Battlemage had a specific stutter issue (very infrequent) that I have yet to encounter with setting CFG off. Installing TW3 now for a stroll through Novigrad...
EDIT: butter smooth in TW3. Something definitely feels different and if I watch the framerate, I'm simply stuck at 120 (yes even in Novigrad, but that wasn't new) and anytime there's a minute drop, its not a wild chase through 119-117-115 FPS, but a single more pronounced one to 110 FPS - and does not exhibit stuttery behaviour. Can definitely see some minor differences in how the game handles sudden CPU load spikes. No single stutter observed... but this needs more playtime to really prove itself, TW3 ran just fine for me prior to the change. Turning CFG on again and rebooting, back into Novigrad I did encounter two minor stutters...
As always very hard to grasp these things (is it real or not) but I'm slowly becoming a believer here.
1,909 (0.32/day)
Processor 5930K
Motherboard MSI X99 SLI
Cooling WATER
Memory 16GB DDR4 2132
Video Card(s) EVGAY 2070 SUPER
Storage SEVERAL SSD"S
Display(s) Catleap/Yamakasi 2560X1440
Case D Frame MINI drilled out
Power Supply Corsair TX750
Mouse DEATH ADDER
Keyboard Razer Black Widow Tournament
Software W10HB
Benchmark Scores PhIlLyChEeSeStEaK
What is the "Exploit Protection" in windows? Sorry blonde moment.............:rolleyes:
1,340 (0.35/day)
Nowy Warsaw
System Name SYBARIS
This gives me hope. Lemme check if it fixes Deus Ex MD and RotTR this weekend. Though I think it's mostly because of low framerate tbh.
My understanding is that Windows 10 features are not letting the game reach their full potential. There's so many things in Windows 10 that people suggest if turned off supposedly increase performance. There's also Full Screen Optimization. Even though you set your game full screen it's actually not. You can easily check this by changing volume by Fn + F3/F2 if your keyboard has the function. In newer games a slider shows up. In older games (in my experience Insurgency 2014) it does not. Also alt + tabing is seamless in games with FSO layer. Almost like borderless window even though fullscreen has been set in in-game settings.
Plus there are so many people claiming it fixes stuttering in that reddit thread plus the resetera thread too. So...
Mussels
Freshwater Moderator
58,412 (7.78/day)
Oystralia
Case Fractal Design R6
Benchmark Scores Nyooom.
I had to look up what this even was - perhaps add to the OP what exploit protection *is* and how to disable it for people who end up here by google searches?
3,984 (1.08/day)
System Name Wut?
Processor 3900X
Motherboard ASRock Taichi X570
Cooling Water
Memory 32GB GSkill CL16 3600mhz
Video Card(s) Vega 56
Storage 2 x AData XPG 8200 Pro 1TB
Display(s) 3440 x 1440
Case Thermaltake Tower 900
Power Supply Seasonic Prime Ultra Platinum
I had to look it up as well. Will definitely look into this more. Seems like you can set preferences per application and it doesn't have to be an all or nothing affair.
6,881 (1.42/day)
Florida
System Name natr0n-PC
Video Card(s) EVGA 3070ti FTW
Storage Various
Display(s) Pixio PX279 Prime
Software XP/7/8.1/10
Windows 10 is not worth the hassle.
With DX 12 coming to Win 7 soon people can play games hassle free like the good old days.
11,096 (1.74/day)
Austin Texas
System Name stress-less
Processor 9800X3D @ 5.42GHZ
Video Card(s) RTX 4090 FE
Case Jonsbo Z20
Audio Device(s) Yes
Power Supply Corsair SF750
Keyboard 65% HE Keyboard
this definitely helps - I tested with HT OFF (which causes massive hitching) and while it still dropped a frame here and there it was 99% smoother.
Going to do this for all my problematic games. thanks!
1,340 (0.35/day)
Nowy Warsaw
System Name SYBARIS
Lol. This is what I was thinking too. And since after this year W7 won't get any updates anymore I'll just dual boot Linux and Windows 7.
4,914 (1.48/day)
Processor Intel Core i7-13700 PL2 150W
Cooling Cooler Master RGB Tower cooler
Memory Crucial Pro DDR5-5600 32GB Kit OC 6600
Video Card(s) Gigabyte Radeon RX 9070 GAMING OC 16G
Storage 970 EVO NVMe 500GB, WD850N 2TB
Case Corsair iCUE 4000D RGB AIRFLOW
Audio Device(s) EVGA NU Audio, Edifier Bookshelf Speakers R1280
Power Supply TT TOUGHPOWER GF A3 Gold 1050W
Software Windows 11 Professional v24H2
If you want to navigate by GUI it's click Settings, click Update & Security, click Windows Security, on the right click App & browser control, scroll down to Exploit Protection, and click Exploit protection settings.
130656
130657
130658
6,431 (2.85/day)
Poland
Video Card(s) RTX3080 Ti FE
Display(s) LG 34GN850P-B
Mouse Endgame Gear XM1R
Keyboard Wooting Two HE
In before someone exploits this workaround to inject malware into "backup" exe file.
13,953 (2.04/day)
Nebraska, USA
Mouse Logitech M190
Got a link? I know of no Windows "feature" that hinders the performance of any application - and games are applications too. Security programs in general (regardless of maker) can impact the performance of a computer (where computer = hardware + OS). But that's not the fault of the OS. That's the fault of the bad guys.
I say again, if the vast majority of applications work just fine, but a small hand-full of programs don't, it most likely is not the fault of the OS.
Don't get too excited about this. It currently is only for World fo Warcraft and is NOT slated to be fully implemented with W7. See https://www.anandtech.com/show/14078/microsoft-brings-dx12-to-windows-7
Migrating to W10 is still the best option in the long run.
Mussels
58,412 (7.78/day)
Oystralia
Ignore the anti W10 trolls, we've found a bug in a security program that causes stutter - they're the antivaxxers of the computer world "I WONT GET INFECTED! MY PC HAS NATURAL IMMUNITY!"
sjpowa
6 (0.00/day)
THIS IS A HUGE FIX FOR ME!!!
I got a RTX 2060 to play smooth on fps like cod and bfv on a 144hz monitor and i got micro stuttering all the time.
If i set my monitor at 60hz or 75hz the stuttering is higher and the v-sync doesn't help, but now just disabling this thing globally i can play smooth on even 60fps or 75 + the v-sync or without.... before was impossible and i was giving the fault at my monitor.
This is crazy
138 (0.02/day)
This is crazy
I done up the guide so you can pick single programs. Just some friendly advice DO NOT DISABLE the setting globally but I can not tell you what to do and if your fine with it disabled globally ,chances are nothing will happen
22,182 (3.43/day)
Olympia, WA
System Name Pioneer
Processor Ryzen 9 9950X
Case Thermaltake Core X31
Can't believe I didn't see this earlier.
Things like this exist in linux land too, and have for a while. They are known there as "stack canaries." The principal is most likely the same here: The idea is to write a "canary" byte every so often with a known value (the term canary comes from the birds that miners would use as sacrifical detectors to find out when they were entering an area with low oxygen or toxic gas, fun factoid). If a stack overflow exploit happens, the program detects the change in the canary value and halts execution (crashes) rather than execute malicious code.
The drawback is decreased code density (which means slower execution) and raised memory usage, the memory usage can go up by a factor of as little as a few to as much as 30% increase depending on how agressive the canaries are applied. I imagine windows must be doing it agressively, hence you guys getting benefits from disabling it.
Just a little explanation for you guys as to how this stuff works.
18,584 (2.63/day)
System Name AlderLake
1,213 (0.59/day)
Canada
System Name New compy
Processor AMD Ryzen 5800x3D
Case Thermaltake Core v71
Immunity is relative, if you take your pc onto darkweb you're just asking for trouble, but if you only browse a handful of sites you're probably ok. I would recommend any third party security over windows, the first thing a hacker learns on is windows built in software.
9,340 (4.93/day)
Louisiana
Keyboard G710+x3
Window is not the only security in existence lol
Think this windows defender setting is a ms account perk though thankfully I use local account and use third party security.
Game bar and gaming mode has always been best to disable.
