Disabling Cores on i7-920
OrbitzXT
1,969 (0.30/day)
New York City
System Name AX-01
Processor Intel Core i5-2500K @3.7 GHz
Motherboard ASRock Z68 Extreme3 Gen3
Cooling Zalman 9700
Memory Kingston HyperX T1 Series 8GB DDR3 1600 MHZ
Video Card(s) GTX 590
Storage Intel X25-M
Display(s) 42" Samsung LED HDTV
Case Antec Twelve Hundred
Audio Device(s) HT | OMEGA STRIKER 7.1
Power Supply Kingwin 1000W
Software Windows 7 64-Bit
I've been noticing that my i7-920 never gets close to maxing out, so I disabled hyper threading some time ago to see if I could push my overclocking a bit farther. I'm still not anywhere close to maxing the cores while playing the games I do with 4 cores, would it make sense to essentially turn my chip into a dual core and clock it even higher?
Does this even make sense to try? Heat hasn't been an issue, so the 2 active cores are still going to require the same amount of voltage, right?
um.... if there is no option in the bios to disable the other cores, then the only other option is to disable them in windows.
open up MSCONFIG,
click on the boot tab
click advanced
then change the number of "processors" to the amount of cores you want to use.
its unlikely to help you over clock much higher, i wouldn't expect more then 150MHz higher then your current clock at best.
open up MSCONFIG,
click advanced
that wont help, the cores will still be active windows wont use them.
disabling HT only removes the extra Virtual cores but they didnt exist in the first place anyway. If you are gaming then turning HT off removes stuttering and shizzle in certain games, if you are doing video editing then HT on is the best idea
open up MSCONFIG,
click advanced
I might have misspoke. I already have the ability to disable cores in my bios, I know where the option is. I'm just asking if it's worth it, since with 4 active cores they never come close to getting maxed out. So if I go with 2 cores instead, can I overclock higher and get overall better performance out of the games I play which don't even use 4 cores.
ah there is an option, yes disabling extra cores=lower heat and more overclocking, but then again performance suffers in some apps as extra cores are gone
which games are you refering to?
im going to say its unlikely to help you overclock much higher (as you said heat was not an issue)... what is currently limiting your overclock atm? Cpu volts?
i also would not go below 3 cores, it seems to be the sweet spot right now and has been for a while. even if it looks like only 2 cores are being use'd for the game, it leaves the 3rd for anything else. low priority game threads / windows crap.
yeah so far it would performs better on dual than triple or quad. only some softwares that can run quad or more to the max
Seems pretty pointless IMO... if you're not even coming close to maxing out the chip as is, why try to OC more and take it even further from being maxed?
I say keep it a quad and just clock it as high as it will go.
