Distributedcom error makes my pc stuck!!
108 (0.03/day)
Processor AMD FX(tm)-8320 Eight-Core Processor 3.5GHZ
Motherboard MSI Socket AM3+ 970A-G46 GLan Audio Raid
Cooling Cpu Cooler Coolermaster Hyper 212 Evo for Intel and AMD Socket 775 / 1155 / 1156 / 1366 / AM2 / AM2+
Memory RAM 8
Video Card(s) NVIDIA GeForce GTX 760
Case Nzxt Phantom Full Tower no PSU Black
Power Supply Antec Power Supply 620W ATX 24 pin High Current Gamer HCG-620 Active-PFC Retail
Software windows 10
This also happened before i reset my pc ,i dont know the reason why it keep happening though. So i don't know if there is any way that i can fix that? any help is appreciate it.
Depends on what you find, if you could find anything. It could give you more data to work with; knowing that x triggers y is a fundamental part in troubleshooting.
Haven't honestly faced this specific problem before, buy personally, I'd look into the web and see if there's a known bug concerning that specific software; try to tinker with the settings of the software; check the software's log -if it has any- to see if there's more hints to what causes the issue; reinstall it, or, if all else fails and I can live without it, Programs and Features->Uninstall!
i even reinstall 2 times windows , same problem there lmao people in google saying this is a bug of windows 10 users without a fix.... even if you grant permission you still cannot access the runtimebroker as it says and you cant fix the error lmao
Does affect your use of the PC ie: BSOD or lock up if no then don't pay it any attention and carry on as normal
Must be something you installed, run sfc/scannow to see if any files are corrupt.
Other option, Windows 7
