Does performance of SLI and Crossfire depends on number of CPU cores
74 (0.02/day)
Does performance of having SLI or Crossfire depend on number of CPU cores. I have heard from many sites that transferring data between multiple GPU's at same time is hard for CPU's with less number of cores which negates the performance improvement achieved by SLI. They say having more cores do give better performance with SLI and Crossfire as transfer of data can be handled better if distributed among different cores than stressing on limited cores.
cdawall
where the hell are my stars
27,683 (4.04/day)
Houston
System Name Moving into the mobile space
Processor 7940HS
Motherboard HP trash
Cooling HP trash
Memory 2x8GB
Video Card(s) 4070 mobile
Storage 512GB+2TB NVME
Display(s) some 165hz thing that isn't as nice as it sounded
6,871 (1.09/day)
S.E. Virginia
System Name Barb's Domain
Processor i9 10850k 5.1GHz all cores
Motherboard MSI MPG Z490 GAMING EDGE WIFI
Cooling Deep Cool Assassin III
Memory 2*16gig Corsair LPX DDR4 3200
Video Card(s) RTX 4080 FE
Storage 500gb Samsung 980 Pro M2 SSD, 500GB WD Blue SATA SSD, 2TB Seagate Hybrid SSHD
Display(s) Dell - S3222DGM 32" 2k Curved/ASUS VP28UQG 28" 4K (ran at 2k), Sanyo 75" 4k TV
Case SilverStone Fortress FT04
Audio Device(s) Bose Companion II speakers, Corsair - HS70 PRO headphones
Power Supply Corsair RM850x (2021)
Keyboard Logitech Orion Spectrum G910
VR HMD Oculus Quest 2
Software Windows 11 Pro 64 bit
Benchmark Scores https://www.3dmark.com/spy/34962882
^what cdawall said
How it was explained to you is not correct at all. As long as the CPU is strong enough for the game in question, reguardless of core count, it will not hamper SLI or crossfire performance.
cdawall
27,683 (4.04/day)
Houston
Processor 7940HS
Cooling HP trash
Memory 2x8GB
Right, and things like Mantle prove AMD is striving to make CPU bottlenecks even less of a potential problem.
Reviews even show it.
4,399 (1.09/day)
Texas
Mouse Logitech G5
Keyboard Logitech G19S
No, even games that are heavily threaded don't benefit much from more cores beyond 4. You might see some slight increasing or decreases depending on the number of cores, but were talking within the margin of error and even a small % difference.
693 (0.15/day)
System Name Old but gold
Processor 3770k @ 4.5Ghz
Motherboard Asus Maximus Gene V
Cooling Hyper 212 Evo
Memory 16Gb 1600 DDR3@2400 Cl11
Video Card(s) GTX 1080 FE
Storage SanDisk Extreme 120Gb SSD (os) , SanDisk 480Gb (Games), WD Caviar Black 4 TB (Games and storage)
Display(s) 32" Samsung HDTV 1080P
Case Some old Dell
Audio Device(s) Onboard HDMI
Power Supply EVGA G2 550w
Software Windows 10 Pro 1903
@cdawall Which site is that from? A 5960x getting beaten by an FX 8370.....that doesn't seem right?
cdawall
27,683 (4.04/day)
Houston
Processor 7940HS
Cooling HP trash
Memory 2x8GB
43,629 (6.36/day)
Memory 64GB G.Skill 6000Mhz
Video Card(s) Asus RTX 4090
Storage WD/Samsung m.2's
Display(s) LG C2 Evo OLED 42"
Case Fractal Design North
Mouse Razer Basilisk V3 Pro
Keyboard Epomaker 84 key
All of those benchmarks are CPU dependent games. Also, there's something wrong with the reviewers setup(s).. dunno why he's getting such low frames in some of the tests. That being said, the speed/power of the actual cores and overall architecture of the CPU has more to do with SLI/CrossFire performance than the amount of cores.
cdawall
27,683 (4.04/day)
Houston
Processor 7940HS
Cooling HP trash
Memory 2x8GB
All of those benchmarks are CPU dependent games. That being said, the speed/power of the actual cores and overall architecture of the CPU has more to do with SLI/CrossFire performance than the amount of cores.
Honest question did you state that backwards or say the FX was better than the 5960x?
13,956 (2.04/day)
Nebraska, USA
Case Fractal Design Define R4
Mouse Logitech M190
Software W10 Pro 64-bit
But that suggests if you have 2 cores or a single core processor, that performance differences compared to a quad is negligible. And that may or may not be the case.
So for everyone above who said "no". I respectfully disagree and say the answer is, "it depends". It depends on where you are starting from. That is, for example, specifically which dual core and which quad core - and which game too.
So for Vineet Reddy, since you did not specify in your opening post the specific CPUs, how many cores, their speeds and which games, so the answer is, "Maybe, maybe not. It depends". If comparing 1 or 2 cores to a quad core CPU, then yes, it could make a difference. If comparing a quad to a 6 or 8 core, probably not.
To further add to the muddiness of this, it depends on the game too. And not just the game, but the age of the game (many newer games take advantage of more cores).
And finally, (if not most importantly), it depends on the speeds of the processors in question.
So bottom line is the OP's question is too vague and generalized for a yes or no answer. So instead, the correct answer is, "it depends".
43,629 (6.36/day)
Nope. I didn't state any CPU over the other.
cdawall
27,683 (4.04/day)
Houston
Processor 7940HS
Cooling HP trash
Memory 2x8GB
The Pentium G3580 is a perfect example of how it really doesn't the architecture will make as much difference as number of CPU threads. The age old intel limitation of 16/4 for slot breakdown is a prime example, FSB before that.
I was under the impression those were GPU bound not CPU bound. Hence why CPU change made next to no difference.
newtekie1
Semi-Retired Folder
28,473 (4.01/day)
Indiana, USA
Memory 32GB DDR4-3600
Video Card(s) RTX 2070 Super
Case Fractal Design Define S
In the summer months I run my 4790K almost exclusively as a dual-core. I have yet to come across a game that this makes a noticeable difference on with my 970s in SLI.
3,091 (0.53/day)
MN
System Name Personal / HTPC
Case Titan Silent 2 / CM HAF XB Evo
Like others have said, it doesn't depend on how many cores, but the power of the CPU in question. If you want an idea (though the CPU and GPUs I had are kind of dated by today's standards) of what to expect from going from an older CPU (Phenom II x4 940) to a newer CPU (i5-4670k), you can check my post here.
It'll show you the improvement I gained on a couple of games running 570s in SLI after going from an OC'ed PII x4 to a stock i5-4670k. I went from 4 cores to 4 cores. The only difference is the sheer power that the i5 has over the PII.
4,399 (1.09/day)
Texas
Mouse Logitech G5
That's why I stated "Beyond 4" which is the ideal amount of cores for a gamer IMHO. 2 cores can run games fairly well as well even in an SLI situation (Mostly involving i3's and the G3258 overclocked). But my point was that 4 was ideal and anymore really makes no difference, I did not insist that a single or dual core is just as good as a quad in gaming.
With or without HT? Just curious...
13,956 (2.04/day)
Nebraska, USA
Mouse Logitech M190
Those examples illustrate my point. Because Vineet Reddy (the OP) did not specify the processors or the game, the answer must be unspecific too.
If you cherry pick specific CPU examples to compare, you can illustrate how a specific quad will blow the socks off a specific dual on a particular game.
Likewise, you can cherry pick a specific dual that will blow the socks off a specific quad in a different specific game.
And, you can cherry pick a game that does not care at all.
We need specifics to give a specific answer.
cdawall
27,683 (4.04/day)
Houston
Processor 7940HS
Cooling HP trash
Memory 2x8GB
Likewise, you can cherry pick a specific dual that will blow the socks off a specific quad in that specific game.
Most of us were a part of his "server gaming rig" thread and are basing our posts off of that.
newtekie1
Semi-Retired Folder
28,473 (4.01/day)
Indiana, USA
