Double click Vs single click, Windows settings, which do you prefer to use?
  • I prefer to use Windows standard double click method, reasons?
    Votes: 9 69.2%
  • I also change my Windows settings to use a single click action, reasons?
    Votes: 3 23.1%
  • I don't give a damn either way, you think about things too much...
    Votes: 1 7.7%
  • Total voters
    13
Status
Not open for further replies.
5,731 (1.04/day)
West Midlands. UK.
System Name Ryzen Reynolds
Cooling Raijintek Leto Pro
Power Supply Corsair VS 550w
Mouse Zalman ZM-M401R
Keyboard Razor Lycosa
What do I mean? basically in Windows you have to double click an icon/folder/app/document to open it, whereas when it comes to things like web links only a single click is required to open it, though you can change your pointer settings in Windows to change this so you only need to single click an app or document or whatever to open it. Now... this is a random question, I know, but do bare with me as I try to explain how I came to be thinking of it :)
I was looking at my desktop a few days ago and the big mess of 50+ shortcuts for all kinds of things from apps to games, documents, pictures etc was really pissing me off, Windows desktop arrangement isn't perfect and can't seem to order them correctly whether you set it to "by name" or "type" or just whatever, it generally doesn't always get it right and sometimes will randomly reset/rearrange them at will. I have used apps that will do a similar job though again have found them to be not perfect and sometimes not behave as you want them to, reset icon locations etc.
So, I have now created folders on my desktop to group all my apps, docs, games, pics etc into the relevant folders. Yay! though it irks me in that Windows default setting for opening anything such as folders, shortcuts, media etc is to double click it, surely that's not a big deal?? Not on the face of it no.... however, I have now gone from having my shortcuts plastered all over my desktop to being arranged neatly into relevant folders and now where I would have to perform a double click, I have to do twice the work by double clicking into relevant folder and then again double clicking required app, document, media etc etc it adds up or I have somewhat of an OCD obsession going on with carrying out twice the clicks for the same outcome, I don't know.
Anywho, long story short, I have changed mouse pointer behaviour to now only require a single click to open drives, programs, games and more specifically folders, and I haven't found any issues this far, though I have tried to use this setting in the past with Windows 7/XP and just couldnt get on with it, I can't recall what specifically I couldn't get on with or what if any issues I had back then but it was one of those things I tried and very soon disregarded because it didnt feel right or there were more drawbacks using this method than the standard Windows double click method. Needless to say I couldnt be happier, perhaps the prevelance of smartphone useage over the years with single "tap" and things like app drawers etc I have become more accustomed to using a single click/tap type of action.
Thoughts?
In the months I reversed the clicking like it is on Chrome OS. Far as Double click I just don't see why would
Single click, without hesitation.
Ever since Windows 95 (yes, 23 years ago! :eek: ) with IE4, which introduced the feature, I tried it and never looked back. It's one of those small, but epic, features that make a much bigger difference than would at first appear.
Besides the shear convenience of having your desktop work like a web page, it doubles the life of your left mouse button. Think about it.
Single click! Ain’t nobody got time for no extra click!
Double Click, why? Because why change what works well. There are other schools of thought however..
Mice are inexpensive and a quality built mouse will likely out-live it's user. Example, the bog standard switches Dell and HP use in their branded mice are rated at 30 million actuation events before estimated first failure. You would have to click once a second, every second of every day for almost a year before you break one. You are more likely to wear out your hand before you wear out one of those switches. And those are the inexpensive ones. The high quality switches are easily rated for 100 million actuation events or more.
Thoughts?
Double click prevents me from accidentally opening a program I didn't want to.
double click still good with me
tried single click and found it annoying and counter productive
example :)
File maintenance one click and the dam thing loads/displays /runs
when i wanted this
file Maintenance one click to select second (usually right click) for the action i intend to perform ( open /delete/move /play)
Heck if single click is/was so brilliant then why does the right mouse button have context menus appended to it :)
It's not quite as clear cut as that. I've had mouse buttons fail and that's even with the single click option, so reducing the amount of times those buttons are mashed makes a big difference. This is especially true if the user tends to use undue pressure.
Exactly this ^ !! I tried single click out for a month, it drove me crazy! :banghead:
True. Failures do happen. And cheap mice that can and does happen frequently. However, I've rarely had good quality mice go bad. Still have an original MS optical from the late 90's that gets used daily and has yet to fail.
I tried and I hated it myself it was too Crappleish, went right back to double after 2 days.
Not sure we need this same thread for the third time now.
Status
