- Feb 9, 2011
- 32 (0.01/day)
- Spain
System Name | Zero RGB PC |
Processor | Intel Core-i7 12700KF |
Motherboard | Gigabyte Z690 AORUS PRO |
Cooling | Noctua NH-D15S chromax.black |
Memory | Kingston Fury Renegade DDR5-6400 CL32 2x16GB |
Video Card(s) | PNY GeForce RTX 4090 24GB XLR8 Gaming VERTO |
Storage | Kingston KC3000 2TB + Samsung 860 EVO 4TB |
Display(s) | Asus ROG Swift PG32UQ + Acer PREDATOR X45 OLED |
Case | Phanteks Eclipse P600S + Be Quiet! SILENT WINGS 3 140mm PWM + 3x Noctua NF-A12x25 chromax.black.swap |
Audio Device(s) | Drop PC38X / Corsair HS80 MAX |
Power Supply | FSP Hydro Ti PRO 1000W 80 Plus Titanium |
Mouse | Lamzu Thorn |
Keyboard | Razer Huntsman V2 TKL |
Software | Windows 11 Pro |
Good afternoon, I have a question about this cable.
Would they work for the same PSU or wouldn't. Fits perfectly, another thing is that something can go wrong or directly not turn on the computer, but first I wanted to be sure. Is the pinout position important in this case?
The power supply is an Antec Signature 1000 Titanium (manufactured by Seasonic, same OEM design as the Seasonic PRIME TX-1000 or the Corsair AX1000): https://www.antec.com/product/power/signature-titanium-1000
The cable is an original Corsair Type 4: https://www.corsair.com/es/es/Categorías/Productos/Accesorios-|-Piezas/Componentes-para-PC/Fuentes-de-alimentación/Premium-Individually-Sleeved-PSU-Cables-Pro-Kit-Type-4-Gen-4/p/CP-8920222
These are the 18 pin connectors that plug to the power supply, not to the motherboard, at the other end the wires are identical.
Thanks.
Thanks.
