Draining Loop ? (1st time ever)
470 (0.15/day)
Scotland
Hi guys,
Just about to add my 1080 Classified to my loop.
However this is the first ever water loop I've owned. So I've never, ever, had to drain one before (ever).
If possible I'd like to save the water.
It's still *only 2 months old* and is 100ml "EK coolant" mixed with 900ml of "Mayhems Ultra Pure H2O" and 'silver kill coil' included since the beginning.
Here's a picture:
Any suggestions how I can do it safely?
Have a great day,
~Nick
9,781 (2.14/day)
Massachusetts
Processor i7-11700K
Cooling Noctua NH-U12A
Case Fractal Design Meshify-C
Audio Device(s) on board
Mouse Logitech G502 spectrum
the res is on the bottom.....couldnt be any easier bud. tilt n drain.
if you really have no idea where to start...id recommend you Watching it done first....just go onto Youtube, and watch a vid or two, dont over think it, and dont rush it......its not that tough
remember...distilled water is the best coolant. (personally) i wouldnt save fluid, but if You MUST, your adding an extra step of difficulty....just be certain to use a CLEAN recepticle to hold the Fluid
470 (0.15/day)
Scotland
Reason I want to save the fluid is because I've bought some "conductonaut" liquid metal. And I've just finished putting my card into block. But I want to see what temps are like without the liquid metal first (and make sure I haven't already broken anything) before I use the liquid metal). So don't want to waste fluid. (got normal non-conductive paste on there for now).
In the U.K. you can't buy distilled water or coolant from a shop or a garage or even supermarket. You have to order it all online.
I've got fresh stuff sitting there but I don't want to use it with this "intermediate" step of checking everything working before upgrading to the conductonaut liquid metal.
12,062 (2.53/day)
Gypsyland, UK
System Name HP Omen 17
Processor i7 7700HQ
Memory 16GB 2400Mhz DDR4
Video Card(s) GTX 1060
Power Supply 230W
Mouse Roccat Kone XTD+
Damn son, that Rad to CPU block tubing is bent af. Consider investing in an angled fitting for that particular area.
As for draining, see above. Gravity is your friend. Most people put a T-line fitting at the bottom of their loop to make drainage easy. I strongly recommend using fresh coolant (distilled water only, it's cheap and your kill coil will do the rest of the work), because whatever container you pour your old coolant into is going to have residue in it.
Actually you can. B&Q, Homebase, hell, even Morrisons has 2 Litre bottles of the stuff. Might be called De-ionised water.
https://www.reddit.com/r/AskUK/comments/3xohc5/where_to_buy_distilled_water/
EDIT: Halfords £3.50 for 5L :toast: http://www.halfords.com/workshop-to...ump-starters/halfords-battery-top-up-water-5l
2,516 (0.46/day)
Canada
Why are your RAMs in slot A2/B2? Should be A1/B1 for best performance no?
Just tilt the case and dump out of the res as mentioned. You can save the coolant by capturing it in a clean container if you really want, a 2l soda bottle rinsed with isopropyl would be sufficient IMO. I would just dump it and run distilled/deionized with some biocide, cheap & best solution. A t fitting in the outermost hose going to the front RAD will facilitate easier draining next time around.
4,994 (0.69/day)
South of England
System Name Box of Distraction
Processor Ryzen 7 1800X
Motherboard Crosshair VI Hero
Cooling Custom watercooling
Memory G.Skill TridentZ 2x8GB @ 3466MHz CL14 1T
Video Card(s) EVGA 1080Ti FE. WC'd & TDP limit increased to 360W.
Storage Samsung 960 Evo 500GB & WD Black 2TB storage drive.
Display(s) Asus ROG Swift PG278QR 27" 1440P 165hz Gsync
Case Phanteks Enthoo Pro M
Audio Device(s) Phillips Fidelio X2 headphones / basic Bose speakers
Power Supply EVGA Supernova 750W G3
Keyboard Cherry MX Board 6.0 (mx red switches)
Software Win 10 & Linux Mint
Benchmark Scores https://hwbot.org/user/infrared
It can be helpful to have a bleed valve at the top to allow the water to drain easily, or just crack off one of the top fittings while your drain is open at the bottom. You won't be able to get all of it out so I'd find something to bung or clamp the pipes with while you're putting the gpu in the loop.
I second using fresh coolant but it's up to you, as mentioned above, make sure your container is spotless before you do this.
Also.. You've got 5 fans blowing into the case and 1 at the back (I think there's one at the back?). Might be worth re-doing the top rad as an exhaust while you're busy working on the loop. Your call tho.
Enjoy the 1080 :D
the54thvoid
Super Intoxicated Moderator
13,590 (2.42/day)
Memory 32GB Kingston Fury
Video Card(s) MSI RTX 5080 Vanguard SOC
Case Asus Prime AP201
Audio Device(s) On Board
Software W10
+1 on the de-ionised water (car battery fluid). The more shit in your loop - the more likely you'll get some gunk build up - no matter what mayhems and EK tell you. It is sales after all.
And FFS man - make your loop sexy, even if nobody can see it (close up my 1st Titan under water).
470 (0.15/day)
Scotland
you sure you've not got mixed up? the slots are coloured coded for ease of installation.
for dual-memory mode its either red + red or black + black
I've actually got 2 more modules but they have been temporarily removed because I'm pushing for higher 3dmark benching scores the the 2 older 'removed' modules won't overclock as high (even though they are factory rated at 2133). The remaining ones are only rated at 1866 (so the 1866 ones O/C higher than the 2133 chips) lol
? On my old AMD FX motherboard (nothing is colour coded lol).
I thought about putting coloured coolant through it and some lighting but I heard colour "stains" cooling equipment.
sneekypeet
not-so supermod
29,711 (4.27/day)
System Name EVA-01
Processor Intel i7 13700K
Case Thermaltake Core P3 TG
Seems either way works, and by the manual, your in dual channel with the RAM in those slots.
As to your color question... I always opted to buy colored tubing and ran distilled water through them. Your homework on color additives is correct, it ends up dyeing the reservoir, the tubing, radiator, and will be in the blocks(left behind, needing to be cleaned). It can properly be cleaned easily if you don't mind disassembling everything to do it and throwing away the tubing. Been there, done that! Just be thorough, as a little dye left somewhere will screw with your color if you want to change it later.
manofthem
WCG-TPU Team All-Star!
10,960 (2.10/day)
Florida
Processor 3900X @ 4.0
Cooling DeepCool Castle 360EX
Storage Sabrent Rocket Q 1TB
Display(s) LG 34UC88
Case Thermaltake P3
Mouse Logitech G900
Colored tubing works really well rather than colored coolants and dyes for some added extravagance. I've used pink dye, red coolant, and I've decided to stick with water.
Other main suggestion is what @RCoon said and think about some angled fittings to allow smoother and/or tighter bends for your tubing. You'll be happy you did.
theonedub
habe fidem
8,026 (1.37/day)
Northern CA, USA
System Name Erakith || AsRock NUCS
Processor AMD ThreadRipper 2990WX ES (32c/64t 3.5ghz@1.02v) || Intel i7 1360P Raptor Lake-P
Motherboard MSI X399 MEG Creation || AsRock OE
Cooling EK Supremacy TR4 Full Nickel, D5 w/ EK Top, 2X EK-CoolStream XTX 360 & Photon 270 Res || OE
Memory 32GB (4x8GB) Corsair Vengeance PRO RGB DDR4 3000|| 2x16GB Corsair DDR4
Video Card(s) Vega 64 EK FC|| Intel Iris Xe
Storage 250gb WD Black NVMe & (2) 2TB Intel 660p NVMe || 2TB Corsair MP600 Pro
Display(s) 34" Dell Ultrasharp U3415W
Power Supply Corsair HX1000
Software Windows 10 Pro x64 || WIndows 11 Pro x64
Add a drain line to the loop while you have it empty.
43,629 (6.36/day)
Memory 64GB G.Skill 6000Mhz
Video Card(s) Asus RTX 4090
Storage WD/Samsung m.2's
Display(s) LG C2 Evo OLED 42"
Case Fractal Design North
Mouse Razer Basilisk V3 Pro
Keyboard Epomaker 84 key
I actually wouldn't save the water. Now is a good time to change it out after your initial setup to get all of the particulates (that you get with a new system) out of the loop.
470 (0.15/day)
Scotland
I thought deionised water was different from distilled water?
sneekypeet
not-so supermod
29,711 (4.27/day)
System Name EVA-01
Essentially the same thing, just that deionized water takes the filtering to an extreme level of not leaving anything in it, where distilled water may still have some minor contaminants present.
43,629 (6.36/day)
If you have a reverse osmosis system under your kitchen sink with a separate little tap, you can just use that too. I've been using it for years.
175 (0.05/day)
Finland
System Name Amadeus
Processor AMD Ryzen 9 5900X
Motherboard Asus X570-F
Cooling EK CR360
Memory 32Gb DDR4 @3600MHz
Video Card(s) RTX 3080 10Gb
Storage 1Tb NVMe, 2Tb NVMe, 2x 2Tb USB HDD
Display(s) Samsung C32JG50
Case Lian Li O11 Dynamic
Audio Device(s) SoundBlaster G6 with Sennheiser Game One
Power Supply EVGA G2 750W
Mouse Logitech G603
Keyboard SteelSeries Apex M500
Benchmark Scores TimeSpy: 16 201
Not always, my MB manual says: For 2 stick of RAM use slots A2/B2 for dual channel.
