Driver problem after flash
6 (0.00/day)
Processor 4690K
Motherboard MSI Gaming 7
Cooling Water
Memory 16GB Blitz Red Dragon
Video Card(s) 2 x Powercolor PCS+ 290
Display(s) LG 34UM95-P
Power Supply SF 1300W
Software W7 64
Not sure what to do now.
I've run both my AMD 290's (Powercolor PCS+ 290) in my machine separately. I noticed there was a bios update which I downloaded and installed on one of the cards no problem.
Installed both cards into the PC for crossfire and flashed the 2nd card (top PCIE slot) and then my troubles started.
AMD catalyst control center error, can not start, currently no settings that can be configured. I notice this also means my monitor isn't recognized.
If I unplug the card and just run the second card, everything is fine.
If I copy the bios off the working card, re download the new or old BIOS and re flash I still have the problem.
I've attached the GPUZ read out of both cards.
Any suggestion in what to do?
Both cards have been flashed using ATIWinFlash. Both currently setup in a watercooling loop so really hoping I don't have to remove it.
Thanks
1,156 (0.19/day)
System Name HTPC whhaaaat?
Processor 2600k @ 4500mhz
Cooling Noctua NH-C14
Memory Gskill Ripjaw 2x4gb
Display(s) Vizio P 65'' 4k tv
Case Lian Li pc-c50b
Audio Device(s) Denon 3311
Power Supply Corsair 620HX
Did you try completely removing and reinstalling catalyst?
6 (0.00/day)
Processor 4690K
Cooling Water
Software W7 64
yes. used CC cleaner and DDU to make sure everything had gone. reinstalled the latest catalyst, still only the one card gets picked up
2,894 (0.47/day)
South Carolina
System Name KILLER
Processor Intel Core i7 4790K
Motherboard MSI Z87 G45 Gaming
Cooling Water Cooling
Memory 2x8GB Gskill 2400mhz
Video Card(s) EVGA GTX 980
Storage SSD Samsung 500GB
Display(s) 24" Asus 144hz
Case Cooler Master HAF
Audio Device(s) X-Fi Platinum
Power Supply Antec 1200 Watt Modular
Software Windows 10 64 Bit
Benchmark Scores 3DMark Vantage 51342
Uninstall driver, then install 13.9, after that you can install newer driver on top of that install.
Had this problem one time before with crossfire and that sorted it.
6 (0.00/day)
Processor 4690K
Cooling Water
Software W7 64
Hi Asylum.
13.9 wouldn't install. Well it said it did but didn't ask for reboot. After reboot no catalyst software. Tired it twice.
Install 13.12 instead and I get same problem as latest catalyst. "No AMD graphics driver is installed, or the AMD driver is not..."
  • 139install.txt
fullinfusion
Vanguard Beta Tester
9,909 (1.57/day)
Did you save the original bios?
And if so, flash back in DOS not WINDOWS! never use winflash for flashing.
6 (0.00/day)
Processor 4690K
Cooling Water
Software W7 64
Just tried DOS and it hasn't made any difference.
I don't have the original rom from that card but the rom looked identical to the the other gpu which i did copy.
Tired forum roms and other gpu original but still getting error
1,980 (0.39/day)
Mainland Britain
System Name H2o Box
Processor Intel(R) Xeon e5-2690 v2 Stock 3.300 GHz stock
Motherboard MSI X79A-G43 Plus (MS-7760) v3
Cooling CPU EK & Phobya G-Changer 360 V2.0 RAD H2o VGA "AlphaCool M18" Hybrid [pump replaced 18/8/21]
Memory G.Skill TridentX 16Gb 11-12-12-32 2T @ 1866Mhz [locked]
Video Card(s) Zotac GTX 1080ti AMP EXTREME
Storage HyperX Fury 120GB & Savage 480GB SSD, Seagate 250GB,250GB 7200rpm Kingston 64GB SSD
Display(s) Asus TUF Gaming VG32VQR 2560*1440 165Hz VA Panel
Case Corsair O-800D
Power Supply Be Quiet! [Dark Power Pro 11] 1200W CM replaced [7-4-2017]
Mouse Zelotes T-90
Keyboard K66 Mechanical US Layout
Software Win 10 Pro 64Bit v 20H2 / OS [build 19043.1237] WFEP 120.2212.3530.0
Hi
move dual bios switch over to performance bios image #2 [*or back to #1]*depending on which image was written to and corrupted
next
reinstall drivers
atb
Law-II
2,894 (0.47/day)
South Carolina
System Name KILLER
Hi Asylum.
Uninstall driver, shut down computer, reboot with only one card in main PCIe slot (if on water loop leave second card hanging out of slot), install 13.9 driver, confirm working, shut down computer, install second card with crossfire adapter, boot up and wait a few minutes, go to catalyst software and enable crossfire (if no install 13.9 again), reboot and wait a few minutes and problem should be solved (may have to enable crossfire now).
I know this sounds strange but the last few times I have done crossfire I have had this problem also.
I don't know if its because I change cards all the time between AMD and Nvidia or some kind of registry conflict but that has worked for me every time.
If that don't sort you out you have flashed one of your cards incorrectly and need to reflash to original bios.
6 (0.00/day)
Processor 4690K
Cooling Water
Software W7 64
Thanks for the suggeestions
Ok, so I switched to the 2nd bios tried 13.9 but didnt seem to install the driver. then tried 13.4->13.9->13.12.
On 13.12 the CC center has popped up with no errors and the GPUZ image is attached
Should I flash this bios#2 into bios#1 via atiflash (dos)?
1,980 (0.39/day)
Mainland Britain
System Name H2o Box
Case Corsair O-800D
Mouse Zelotes T-90
Hi
If the vga card works with the reserved Vbios image from position #2; use a backup copy of #2
Vbios image - to flash position #1
Note: DO NOT flash switch position #2 [reserved Vbios position]
atb
Law-II
6 (0.00/day)
Processor 4690K
Cooling Water
Software W7 64
Thanks Law.
Flashed and working again.
Wonder why the updated bios caused a problem. Guess I don't update unless told to in future.
1,980 (0.39/day)
Mainland Britain
System Name H2o Box
Case Corsair O-800D
Mouse Zelotes T-90
Hi
Great to see the vga card is up and running again :toast:
[indeed leave well alone unless instructed by manufacturer is wise choice]
atb
Law-II
44,274 (6.80/day)
Thanks Law.
Well you just learned something. Now be the poster child and tell all your friends not to flash their gpu bios.
