DVI and VGA > DVI(monitor boot priority)
438 (0.10/day)
Poland
Processor Intel Core i7-2600k @ 4,4 GHz
Motherboard Asus Maximus V Gene
Cooling Corsair H80i
Memory Corsair Vengeance 16 GB @ 1866 MHz
Video Card(s) EVGA GeForce GTX 980 Superclocked
Storage Corsair SSD Force GT 120 GB & Seagate Desktop SSHD 2TB
Display(s) BenQ XL2420T & BenQ T720
Case Fractal Design Define R5
Power Supply OCZ ZT 650W
Hey,
So I have two monitors - main, DVI-D and second on VGA > DVI with adapter.
My problem is: When I start computer I see boot screen on my second monitor, not first. How can I set priority of monitors? I want to see boot screen on my main monitor. Before GPU change I was using DP and VGA > DVI. It seems like DP have a grander boot priority then VGA/DVI.
So what can I do?
Thanks
Tintai
Don't think there is anything you can do. Same thing here but with a 480. Vga monitor comes up first, then when windows loads it goes to my hdmi monitor.....
I can't change this in some GPU/monitor/Bios settings? Maybe there is a way.
As far as I know there is no setting you can use to change this.
As an alternative, have you tried switching the connectors on the back of the card? My friend had a similar situation (with two DVI monitors on an AMD HD 7970) and he was able to get what he wanted by switching which cable went to which port.
Hmm. This is good idea. Maybe there are a DVI port 1 and DVI port 2. But only one of them has DVI-D. I need D for 120Hz.
