Easiest to build in cases?
296 (0.53/day)
CincinnatiOH!
I'm often inside my case (Corsair iCUE 5000x RGB) swapping things and I'm wondering whether there are better cases to use for frequent changes, and highly compatible with all cooling, especially air coolers. Some of the cases that MIGHT work including the list below, most of which were suggested to me.
InWin ModFree
BeQuiet! Dark Base Pro 901
Phanteks P600S
Fractal Design Torrent Full-sized
Thermaltake CTE C750
Thermaltake Core W200/P200
Lian Li Lancool 2
Lian Li Lancool 3
Lian Li Lancool 216
Fractal Design North with mesh side
Fractal Design Meshify C
Antec Performance 1 FT
Phanteks Enthoo Pro 2
Maybe something from Mountain Mods or Case Labs? Anything else? What's the best choice? Why?
Nothing open/sideless, please (e.g.: Thermaltake Core P3 SE, test bench). Thank you!
296 (0.53/day)
CincinnatiOH!
Isn't there anyone who can give me any feedback on the listed cases, or suggest others?
6,680 (1.59/day)
System Name The Little One
Processor i5-11320H @4.4GHZ
Motherboard Beelink/AZW SEI
Video Card(s) Iris XE
Storage WD Black SN850X 8TB m.2, Seagate 4TB SSD + SN850 8TB x2 in an external enclosure
Display(s) 2x Samsung 43" + 1x 32"
Audio Device(s) No-name compact bluetooth speakers
Power Supply 65w brick
Mouse Logitech MX Master 3
VR HMD Whahdatiz ???
Benchmark Scores PDQ
Right off the top of my head, a couple more that come to mind are:
A) Corsair Air 740
B) Thermaltake Tower 900
I have used both of these and they were a joy to build & work in, due to their sheer volume of space inside, cooling options (not just number, but types and sizes) and cable routing possibilities...but the same can be said about the Enthoo & Case Labs too, which I have also used on occasion for client rigs when the requested "go big or go home" preferences were expressed to me :)
Just as an example, in my TT900, I used a 560mm push/pull AIO in a 1 of a kind, custom-built-by-me mounting arrangement, plus 11 additional 140mm fans, and STILL had tons of room to install/remove/re-install parts to & from it and hide 99.7% of the cables, without having to disassemble a bunch of stuff nor worry about breaking anything :D
18 (0.01/day)
System Name Lara10rd
Processor Intel Core i9 13900K
Motherboard Asus Strix Z790-F Gaming
Cooling Corsair Link H150i RGB LCD
Memory Corsair Vengeance RGB 32GB DDR5 6000mhz
Video Card(s) Nvidia RTX4080
Storage WD Black 770 Pciex 4.0 M.2 500GB
Display(s) MSI 32" 2K 165Hz 1MS Curve
Case NZXT H6
Audio Device(s) Realtek internal
Power Supply Thermaltake GF3 1200watts 80 + Gold
Mouse Corsair Harpoon Wireless
Keyboard Corsair K70 RGB
Benchmark Scores 3DMark TimeSpy 27, 175
I used to have this case, the (Corsair iCUE 5000D) but I changed it for the NZXT H9 Flow, I can say that the change was positive, especially for the improvement in airflow and the ease with which I can install my components, something I would like to point out I have an Asus strix 4070 TI OC, it is quite big, I couldn't close the front glass, to solve it, I bought the support to put it vertically. It is the same one that NZXT manufactures, for that case and it greatly improved the aesthetics. Greetings.:toast:
2,307 (1.20/day)
System Name GrandadsBadAss
Display(s) Acer XG270HU
Keyboard Roccat Vulcan Aimo
Software Win 10/11pro
I recently built a backup rig in the Corsair 5000D Airflow and found it to be nice and roomy. While I went with a custom loop in it rather than air, I wouldn't hesitate to recommend it for an easy to build in air cooled rig. It was gravy building a dual rad loop in it. Overall it's a well thought out case. You should find it more than adequate for any dual tower set up. There's plenty of fan mounts and overall case flow is top notch. I would have no qualms running it strictly air cooled. At some point I probably will.
freeagent
10,391 (4.30/day)
Winnipeg, Canada
Cooling Thermalright Phantom Spirit 120 EVO, 2x T30
Memory 2x 16GB Lexar Ares @ 6400 28-36-36-68 1.55v
Display(s) LG 50UP7100
Case Asus ProArt PA602
Audio Device(s) JBL Bar 700
VR HMD Oculus 3
Software Yes
Benchmark Scores Yes
The Meshify C and Torrent C are about the same to build in. The Torrent C requires a bit more attention to detail due to the space behind the tray.
The Meshify C is a little more flexible when it comes to cooling options, the Torrent C is basically a straight up air cooling chassis. You can use an AIO/CLC in a TC, but you have to be creative when it comes to choosing fans.. and you will have to run them..
But.. Meshify C can move hella CFM's :D
609 (1.01/day)
USA
System Name Dark Palimpsest
Processor Intel i9 13900k with Optimus Foundation Block
Motherboard EVGA z690 Classified
Cooling MO-RA3 420mm Custom Loop
Memory G.Skill 6000CL30, 64GB
Video Card(s) Nvidia 4090 FE with Heatkiller Block
Storage 3 NVMe SSDs, 2TB-each, plus a SATA SSD
Display(s) Gigabyte FO32U2P (32" QD-OLED) , Asus ProArt PA248QV (24")
Case Be quiet! Dark Base Pro 900
Audio Device(s) Logitech G Pro X
Power Supply Be quiet! Straight Power 12 1200W
Mouse Logitech G502 X
Keyboard GMMK Pro + Numpad
I have the version 1 Dark Base Pro 900 and I still love it. It's not the easiest to work in, but it has tons of options that make it easy to find solutions for whatever parts you want to throw at it. Version 2 improved everything that made mine difficult at times and the 901 is a complete overhaul with a bunch of new features and a focus on better airflow options. Seems like an awesome case. The quality of their high end products is outstanding.
5,269 (0.86/day)
System Name [Daily Driver]
Processor [Ryzen 7 5800X3D]
Motherboard [MSI MAG B550 TOMAHAWK]
Cooling [be quiet! Dark Rock Slim]
Memory [64GB Crucial Pro 3200MHz (32GBx2)]
Video Card(s) [PNY RTX 3070Ti XLR8]
Storage [1TB SN850 NVMe, 4TB 990 Pro NVMe, 2TB 870 EVO SSD, 2TB SA510 SSD]
Display(s) [2x 27" HP X27q at 1440p]
Case [Fractal Meshify-C]
Audio Device(s) [Fanmusic TRUTHEAR IEM, HyperX Duocast]
Power Supply [CORSAIR RMx 1000]
Mouse [Logitech G Pro Wireless]
Keyboard [Logitech G512 Carbon (GX-Brown)]
Software [Windows 11 64-Bit]
I have a Fractal Design Meshify C and love it.
Ruru
S.T.A.R.S.
13,792 (3.05/day)
Jyväskylä, Finland
Cooling Eisbaer 360 + EK Vector TUF + Acool XT45 240mm + Swiftech res + EK-XTOP SPC-60 / Eisbaer 240 + DCC
Video Card(s) Asus RTX 3080 TUF / Powercolor RX 6700 XT
Display(s) 4K120 IPS + 4K60 IPS / 1080p projector @ 90"
Audio Device(s) Sony WH-CH720N / Hecate G1500
Power Supply EVGA G2 750W / Seasonic FX-750
VR HMD Oculus Rift CV1
2,276 (1.04/day)
System Name BigRed
Processor I7 12700k
Case Corsair 7000D
Software Windows 10 Pro X64
Benchmark Scores Who cares
The Lian Li o11 series opens up to the front and side, with the side panel also coming off, so are pretty accesable with all the panels off.
3,195 (2.27/day)
Motherboard Apple proprietary
Cooling Apple proprietary
Case Apple proprietary
Mouse Apple Magic Trackpad 2
Software macOS Sonoma 14.7
It's unlikely that more than a couple of TPU forum participants have worked directly with more than a couple of cases on this list.
I only have experience with the Lian Li Lancool II Mesh Performance. It is indeed a very easy case to work in. I have zero experience with any of the other cases so I can't make a relative comparison.
I also have a Lian Li O11D Mini. Co-designed by noted overclocked Der8auer it is also very easy to work in and also fairly configurable. You can remove the two glass panels, other metal side panel, and top grill giving easy access. I actually use this case with a mini-ITX motherboard which allows for maximum configuration potential.
I would not hesitate to recommend either case for first time PC builders. The main caveat with the O11D Mini is its requirement for an SFX power supply.
9,802 (3.23/day)
System Name Good enough
Case Phanteks NV7
Power Supply GPS-750C
The bigger the better, that's all there is to it really.
2,276 (1.04/day)
System Name BigRed
Processor I7 12700k
Case Corsair 7000D
I'm using a 7000D which is pretty big, and easy to work with, but not really a cheap case.
Ruru
S.T.A.R.S.
13,792 (3.05/day)
Jyväskylä, Finland
Even it's little brother (4000D) feels somewhat big, at least when I had a mATX setup not that long time ago :laugh: with some planning, even custom loop cooling fits on this.
freeagent
10,391 (4.30/day)
Winnipeg, Canada
VR HMD Oculus 3
Software Yes
I can’t stand big cases, so much wasted space :)
9,828 (3.40/day)
System Name Best AMD Computer
Processor AMD 7900X3D
Cooling In Win SR36
Display(s) GIGABYTE FV43U
Case Corsair 7000D Airflow
Power Supply Deepcool 1000M
Keyboard Logitech G510
Enthooo Pro 2. I have used 2 of them in builds. Next is Corsair 5000-7000D and for small Phanteks P360.
177 (0.28/day)
France
System Name the thing / the second shit / boxshit pc
Processor r5 7500f / fx 8350 / w3680 @ 4.2GHz
Motherboard b650 LiveMixer / 990x evo r2 / x58 sabertooth
Cooling assassin x 120 se / stock crap w/ 92mm fan / NH-U12P SE2
Memory 32gb @6400mt.s cl32 / 16gb / 24gb cl11
Video Card(s) 6700 xt / w2100 / hd 5870
Storage 7.25 tb on 9 drives / 1tb on 2 drives / 2tb on 4 drives
Case centurion 5 II / focus g / silencio 550
Audio Device(s) DT 990 Pro 250 ohm, scarlett 2i2 3rd gen
Power Supply straight power 11 750w / random no-name 500w / cooler master gx 550w
Mouse g502
Keyboard corsair something
Benchmark Scores slower than your phone
I have a Fractal design focus g, it's good to build in but please never buy one.
Screw hole are badly threaded ( mine was so badly threaded that i had to cut the screw to get the side pannel open), super sharp metal inside the case and only 2 hdd drives but it is an "open" case (no compartment) so easy to build in.
Hope it helped
wouldn't be susprised if not.
Ruru
S.T.A.R.S.
13,792 (3.05/day)
Jyväskylä, Finland
Nah, when you have your tower on the floor, it's out of sight and out of mind. :laugh:
296 (0.53/day)
CincinnatiOH!
Thanks all! Great feedback! First time to this forum, recommended by @freeagent.
Aside from spaciousness, do any of these cases have features built-in to make it easier to build and change things (e.g. sliding/removable mobo plate, customizable features)? If so, what?
I have a follow-up question.
At this time, I'm doing a lot of fan swapping, including RGB and ARGB fans, and I'm using a couple of crappy FCs, one powered by Molex D, the other by SATA, which forces me to keep my side panel ajar so those 2 cables are accessible (I ran them from behind to that side) to these external FCs. I also sometimes plug fans into my 2 CPU headers with an extension. I'm not pleased with this arrangement, and so I'm interested in either something I can add to my (Corsair 5000x) case with a long reach, or preferably a stand alone unit for running fans, including lights.
  • Whichever, it must be high quality but
  • not gonna break the bank (the only recommendation I have so far is Aquacomputer FCs, which are near the max I HOPE to spend of $200),
  • even if it only has a couple of ports each (PWM, RGB, & ARGB) that is fine - I don't need a lot.
  • It has to have precise and complete control with a display through the whole range of RPM (I have server and consumer fans), temps (there are 3 thermocouples I can take out of one of my FCs if needed), duration, etc.
  • It must fully support PWM - some manufacturers sell 3-pin FCs and yet claim they support PWM.
  • individual shut-offs (i.e. kill switches) and/or linear regulators, and high-quality parts;
I'm not an engineer or I'd design and build it myself, but I don't have the time to learn, plus my math skills are weak. If someone wants to design and build it, I'm down for that, or if someone wants to design it and link me to all the parts so I can improve my soldering skills, or use a breadboard, that's also cool.
Bonus points:
  • doesn't come from China, N. Korea, Russia, etc. I realize this may not be possible;
  • can transmit data to my computer via USB if it's stand-alone, including RPM, timings;
  • If it's internal and can plug into headers as well as the PSU, that's nice but my headers only handle 1A each for the signal;
  • control amps, watts and/or volts;
I've probably forgotten something.
Separate question: does anyone know where I can get the InWin Mars fan in the USA?
2,276 (1.04/day)
System Name BigRed
Processor I7 12700k
Case Corsair 7000D
freeagent
10,391 (4.30/day)
Winnipeg, Canada
VR HMD Oculus 3
Software Yes
2,276 (1.04/day)
System Name BigRed
Processor I7 12700k
Case Corsair 7000D
Bonus points:
The new Lian li o11 dynamic evo XL has everything you need imo
https://lian-li.com/product/o11-dynamic-evo-xl/
Well.. its not wasted if you can fill it with H2oh gear :)
It is :)
AsRock
TPU addict
19,255 (2.95/day)
UK\USA
Cooling D15
Yes, he might be better of hunting down the Gamers Nexus video's.
672 (0.13/day)
mississauga, on, Canada
System Name YACS amd
Processor 5800x,
Motherboard gigabyte x570 aorus gaming elite.
Cooling bykski GPU, and CPU, syscooling p93x pump
Memory corsair vengeance pro rgb, 3600 ddr4 stock timings.
Video Card(s) xfx merc 310 7900xtx
Storage kingston kc3000 2TB, amongst others. Fanxiang s770 2TB
Display(s) benq ew3270u, or acer XB270hu, acer XB280hk, asus VG 278H,
Case lian li LANCOOL III
Audio Device(s) obs,
Power Supply FSP Hydro Ti pro 1000w
Mouse logitech g703
Keyboard durogod keyboard. (cherry brown switches)
Software win 11, win10pro.
lian li LANCOOL iii
6,680 (1.59/day)
I would tend to disagree with this statement, as the user base here includes people from many different parts of the pc enthusiast crowd.... IT pros, average every day users, young, old & everywhere in between, experienced builders, modders, and tinkerers, tweeners/newbies, people who constantly upgrade/tweak their builds, others who only build a new rig every 3-5 years or stick to prebuilts, etc etc....
Or as I like to say: Go big, or go home (and yanky yer wanky :D)
