Empty Control Panel in Vista - help please!
alexp999
Staff
8,012 (1.23/day)
Dorset, UK
System Name Gaming Rig | Uni Laptop
Processor Intel Q6600 G0 (2007) @ 3.6Ghz @ 1.45625v (LLC) / 4 GHz Bench @ 1.63v | AMD Turion 64 X2 TL-62 2 GHz
Motherboard ASUS P5Q Deluxe (Intel P45) | HP 6715b
Cooling Xigmatek Dark Knight w/AC MX2 ~ Case Fans: 2 x 180mm + 1 x 120mm Silverstone Fans
Memory 4GB OCZ Platinum PC2-8000 @ 1000Mhz 5-5-5-15 2.1v | 2 x 1GB DDR2 667 MHz
Video Card(s) XFX GTX 285 1GB, Modded FTW BIOS @ 725/1512/1350 w/Accelero Xtreme GTX 280 + Scythe sinks| ATI X1250
Storage 2x WD6400AAKS 1 TB Raid 0, 140GB Raid 1 & 80GB Maxtor Basics External HDD (storage) | 160GB 2.5"
Display(s) Samsung SyncMaster SM2433BW @ 1920 x 1200 via DVI-D | 15.4" WSXGA+ (1680 x 1050 resolution)
Case Silverstone Fortress FT01B-W ~ Logitech G15 R1 / Microsoft Laser Mouse 6000
Audio Device(s) Soundmax AD2000BX Onboard Sound, via Logitech X-230 2.1 | ADI SoundMAX HD Audio
Power Supply Corsair TX650W | HP 90W
Software Windows 7 Ultimate Build 7100 x64 | Windows 7 Ultimate Build 7100 x64
Benchmark Scores 3DM06: 19519, Vantage: P16170 ~ Win7: -CPU 7.5 -MEM 7.5 -AERO 7.9 -GFX 6.0 -HDD 6.0
How come my control panel is empty in Vista? Only way i have found getting round it, is to go to services and then stop and restart software licensing. It does this on two of my PC's and I am running genuine windows!
Any help appreciated thanks.
I haven't seen this issue...did you set it to show Classic View? I know at times it takes a few seconds for my CP to fully load and it will start to display icons about 3-5 at a time until it's complete.
Very interesting.
Very interesting.
Doesnt matter whether it is classic or not, have last couple of minutes to see if something would show. Cant rem where i found the fix, but thats the only way! and it always works!!! Would be nice if i could find a fix though. Oh and ive tried a wipe and reinstall too! Only thing I changed this time was using vlite but it did it on my laptop too after a clean wipe using the normal genuine vista media and a genuine key!
Bit lost, just a pain. Also the printers link will not show up in the start menu and when the CP does go up the swanny it disables the computer properties. CP just acts like an empty folder and right click on My computer and clicking on properties acts like you never pressed anything, really wierd!
Wait a sec after a few mintues of having diasbling and reenabling the software licensing and getting the CP to work, printers is now showing up in the start menu and I have changed nothing, so I would say they are defo linked. Do you reckon maybe it would fix the problem if i changed software licensing to delayed start?
Thanks.
It could help, I've never had to mess with any of that stuff. I've been messing with disabling different services and such, but really all I do is turn off UAC and go. Might as well try delayed start, maybe that's what it needs.
:toast:
thanks for you help, will try it and let you know.
