Error 'APIC not counting' - GPU-Z not working with my APU C-50
andyqi
2 (0.00/day)
When I try to run the program, it popups an error: APIC not counting, trying reset. If press OK, another error popups: APIC still not counting, epic fail. Then GPU-Z hangs there, I have to kill it by task manager.:banghead:
GPU-Z v0.5.6
[SW]
Driver Packaging Version 8.911-111025a-128243C-ATI
Catalyst Version 11.11
Provider AMD
2D Driver Version 8.01.01.1207
2D Driver File Path /REGISTRY/MACHINE/SYSTEM/ControlSet001/Control/CLASS/{4D36E968-E325-11CE-BFC1-08002BE10318}/0000
Direct3D Version 7.14.10.0873
OpenGL Version 6.14.10.11251
AMD VISION Engine Control Center Version 2011.1025.2231.38573
[HW]
Graphics Card Manufacturer Powered by AMD
Graphics Chipset AMD Radeon HD 6200 series Graphics
Device ID 9804
Vendor 1002
Subsystem ID 84A4
Subsystem Vendor ID 1043
Graphics Bus Capability PCI
Maximum Bus Setting PCI
BIOS Version 012.036.000.007
BIOS Part Number 113-C06001-102
BIOS Date 2010/11/08
Memory Size 1462 MB
Memory Type HyperMemory
Core Clock in MHz 276 MHz
Memory Clock in MHz 533 MHz
i have exactly the same problem... im using HP G4 a4-3300m
no problems yesterday but now its giving me that error
Yes! If you install GPU-Z v0.5.6, you can get it run until the next system restart.
Thanks god that I am not the only one got this problem.:respect:
anyone figured out what's the fix for this?..
weird thing btw i played starcraft 2 enabled my xfire after i close the game itried gpuz and it worked :P but after i restarted my laptop same problem again :(
Same problem here but I didn't even reboot and it doesn't work. I have an A8-3500m APU and only the HD6620G , no xfire. I guess the program doesn't work with any APU yet.
when you start cpuz or aida64 after a reboot, before gpuz, the problem might not appear
Yes, opening CPU-Z first does remove the problem with GPU-Z. I still think that's a bug that needs to be fixed though.
