Error OC Memory detect on X399 Threadripper Zenith Extreme
38 (0.01/day)
System Name DarkEstra V3.0
Processor Intel Core i7-6700K 4.0GHz Quad-Core Processor
Motherboard Gigabyte GA-Z170X-GAMING 6 ATX LGA1151 Motherboard
Cooling Corsair Hydro Series Cooling H75 Performance Liquid CPU Cooler
Memory Corsair Vengeance LPX 16GB (2 x 8GB) DDR4-3200 Memory
Video Card(s) Dual MSI Gaming x RX580 8GB
Storage Samsung 960 Evo 250GB + Crucial MX300 275GB
Display(s) Philips 247ELH
Case Cougar Evolution ATX Mid Tower Case
Audio Device(s) On Board
Power Supply Cooler Master Silent Pro Hybrid 800W 80+ Gold Certified Fully-Modular ATX Power Supply
Mouse Razer DeathAdder Elite
Keyboard Tecware Phantom
Software Microsoft Windows 10 Professional
Hello
i have a problem with this setup
after i installed all the hardware
tried to bootup
it won't post
and the little screen shows
" CO Error , Memory Detect "
and it also do the same after pulling out all of ram slots
Specs
ASUS ROG-STRIX-GTX1080TI-O11G-GAMING
Thermaltake Toughpower iRGB Plus 1250W 80+ Titanium
ASUS ROG ZENITH EXTREME X399
Enermax LIQTECH TR4 280mm
AMD Ryzen Threadripper 1950X
G.SKILL TridentZ RGB Series 16GB (2 x 8GB) 288-Pin 3600MHz (PC4 28800) Desktop Memory Model F4-3600C17D-16GTZR 4 packs
Thank u
Hello
tried to bootup
it won't post
Specs
Thank u
Clear cmos, read your motherboard manual, make sure to update board bios, go online and ask gskill and asus technical support to ensure your ram is compatible, make sure ram is in correct slots for your specific ram configuration.
cleared cmos several times
changed the ram slot
still no post or
how can i update bios without post ??
still no post or
Ok so when you mean post do you not get any display or do you and system stops for an error, some asus boards you can update with just the cpu installed. Check your manual for details on it
i would reseat the cpu if changing the ram slots didnt work. then try some other ram...
Did it ever POST?
Ryzen platform is VERY sensitive to memory, so if you have unsupported memory (check the Qualified Vendor's List for the motherboard - it lists exact product numbers) then it likely won't work.
The memory you have in your specs is 3600 which AFAIK *can* work, but only if it is of a specific type. Not just any 3600 MHz memory will do.
Did it ever POST?
Re-read the first comment...
There are only two memory modules listed in the manual for 3600 speed, both are Corsair.
Code:
CMK32GX4M4B3600C18 ver4.31 32GB(8GB*4)
CMK32GX4M4B3600C18R ver4.31 32GB(8GB*4)
It's very likely the memory you have won't work, unfortunately.
The spec of your memory is: CL17-18-18-38, 1.35 volt, Unbuffered
It appears this should work, but why they don't, I don't know. I can only assume something is out of spec somewhere (doesn't initialize fast enough, or a timing issue through POST, or something else).
Unfortunately I don't have the required analyzers to see what the memory does on a system that POSTs, and on a system that doesn't. I wish someone would take a look and get to the bottom of this as it is annoying how the specs can't be relied upon anymore to know if a piece of hardware will actually work. You'd think higher-spec memory would work at a lower spec, but that simply isn't the case.
I'm not even sure the QVLs are an exhaustive list. Are they?
I wanted to be sure it NEVER posted, not even once.
Code:
He has the Zenith LIVEDASH hooked up, so it gets to that and stops booting.
And he is gone to never return, smh
