Everest Temp Question
jbunch07
5,260 (0.83/day)
Chattanooga,TN
Processor i5-2500k
Motherboard ASRock z68 pro3-m
Cooling Corsair A70
Memory Kingston HyperX 8GB 2 x 4GB 1600mhz
Storage OCZ Agility3 60GB(boot) 2x320GB Raid0(storage)
Display(s) Samsung 24" 1920x1200
Case Custom
Power Supply PC Power and Cooling 750w
Software Win 7 x64
I'm using Everest ultimate to measure CPU temp amongst other things but had a questions as if it seems accurate?
It says CPU temp is 57 but all the cores are 29 that doesn't seem right to me? whats going on here? My CPU is water cooled so it shouldn't be that hot, should it? :confused:
What is the CPU temp in your bios. The CPU temp is generally the CPU socket temperature.
Give me a moment and I'll report back with that info. ;)
Report back as to what your core temps are showing in both RealTemp and Coretemp(specifically version 0.99.3)
@erocker
Amen to that!
BIOS shows CPU temp at 40c or 104F
realtemp is does not support my cpu
Doesn't your motherboard vendor provide you with a temperature software?
Probably, but I don't want to use that. I do most of my OCing in the bios so its usually not need, however i do use things like prime95 and amd overdrive for testing and confirming results.
more results
