EVGA Intros Power Boost Gadget to Improve PCI-E Power Stability
$immond$
i seriously doubt this can make any difference at all. vga cards are not unstable because of power delivery issues from the socket.
and $20 .. cmon ... $3 maybe and they'd still make a ton of profit
if your (evga?) motherboard doesnt work right without it, then you bought a POS motherboard that is not engineered properly
:laugh: I agree this is complete horse shit.
qamulek
184 (0.03/day)
I like that, maybe a few of them pick up a beer on the way home from work so there isn't as much traffic on the yellow wire as the black one.
If you send a billion electrons in then a billion electrons must come out or you build up a charge which can eventually lead to trouble.
My guess is the +12v wires are being load balanced, but the ground wires are simply connected to each other. As an example lets say each wire was rated to carry a unit of 1(going unit-less). Three +12v that are load balanced can carry a total of 3 units in. The ground units are simply connected together giving a variation of currents with the possible distribution of (.7,.8,1.5). One ground wire is now pulling 50% more current then its rated for. Add two more wires with the assumption that the two wires added pull the same current as the .7 above, then normalize the total current to 3: (.477,.477,.477,.545,1.02). The 1.5 current wire is now 1.02 which is just 2% over the rated current.
5,213 (0.87/day)
System Name Addison Clark
Processor Ryzen 9 7950x3D delid
Motherboard Asus X670E Hero
Cooling Custom Bykski loop CPU, GPU, 2x 360 rads, and 1x 280 rad with Arctic P12 and P14 ARGB fans
Memory G.Skill DDR5-6000 64GB CL30
Video Card(s) Gigabyte 4090 Aorus Master
Storage Kingston Fury 2TB and 4TB NVME
Display(s) Samsung 57"
Case Lian Li O11 mini
Power Supply Thermaltake 1000w SFX-L
Keyboard Corsair K95 Platnium
Software Win 11 Pro
This takes me back to the OCZ DDR booster. Atleast this contraption from EVGA will work on any board with aleast a PCI-E x1 slot.
hat
Enthusiast
21,731 (3.42/day)
Ohio
Cooling Cryorig M9 :: Stock
Benchmark Scores >9000
Is this a troll? What's with the 4chan smileys in the vid?
Deleted member 74752
I suspect this was provided by request's from overclockers much the same as this was... http://www.evga.com/products/moreInfo.asp?pn=M020-00-000205&family=Accessories - Hardware&sw=4
I know of nothing much that does not work as advertised in the Evga line-up. They have always been on top for a reason with their products as well as service. I find it gratifying that Evga does listen to overclockers and acts on their wishes from time to time. Maybe someone will document the advantages of this device and report the findings.
5,965 (0.99/day)
New York
Processor AMD Ryzen 9 5950x, Ryzen 9 5980HX
Motherboard MSI X570 Tomahawk
Cooling Be Quiet Dark Rock Pro 4(With Noctua Fans)
Memory 32Gb Crucial 3600 Ballistix
Video Card(s) Gigabyte RTX 3080, Asus 6800M
Storage Adata SX8200 1TB NVME/WD Black 1TB NVME
Display(s) Dell 27 Inch 165Hz
Case Phanteks P500A
Audio Device(s) IFI Zen Dac/JDS Labs Atom+/SMSL Amp+Rivers Audio
Mouse Logitech G502 SE Hero
Keyboard Corsair K70 RGB Mk.2
VR HMD Samsung Odyssey Plus
I don't even know man
good board and good psu and this is not needed from the looks, hell i can't think of any way someone would need this unless they were runnin like 4 cards and other stuff
and 20 dollars, . . . . . damn
1,080 (0.16/day)
Look behind you!!
System Name NEW
Processor Intel 4770 non-K
Motherboard Gigabyte H81M-DS2V
Cooling CM Hyper 212 plus
Memory 16gb Muskin
Video Card(s) XFX 380X 4gb
Storage Sandisk 120gb plus WD blue 1tb
Display(s) AOC 23.5 LED bl
Case XIGMATEK
Audio Device(s) motherboard
Power Supply Cooler Master 500
20 bucks for that!! :wtf:
dont forget the 8 bucks to ship it :rolleyes:
newtekie1
Semi-Retired Folder
28,472 (4.24/day)
Indiana, USA
Memory 32GB DDR4-3600
Video Card(s) RTX 2070 Super
Case Fractal Design Define S
7,662 (1.24/day)
c:\programs\kitteh.exe
Processor C2Q6600 @ 1.6 GHz
Motherboard Anus PQ5
Cooling ACFPro
Memory GEiL2 x 1 GB PC2 6400
Video Card(s) MSi 4830 (RIP)
Storage Seagate Barracuda 7200.10 320 GB Perpendicular Recording
Display(s) Dell 17'
Case El Cheepo
Audio Device(s) 7.1 Onboard
Power Supply Corsair TX750
Software MCE2K5
HillBeast
407 (0.08/day)
New Zealand
System Name Kuja
Processor Intel Core i7 930
Motherboard Gigabyte X58A-UD3R
Cooling Corsair H50 HB.o Special Edition with Koolance CHC-122 NB Block
Memory OCZ Extreme Edition 4GB Dual Channel
Video Card(s) Sapphire Radeon 5870 Vapor-X Rev. 2
Storage 2x 1TB WD Green in RAID
Display(s) BenQ V2400W
Case Lian Li PC-A17 HB.o Special Edition
Audio Device(s) Onboard Realtek 889A
Power Supply Gigabyte Odin Pro 800W
Software Windows 7 Professional
Benchmark Scores 93632 sysPoints in sysTest '09 47 FPS in Star Tales Benchmark
This is the stupidest thing I have ever seen in my life. A TRUE overclocker owns soldering iron. Why does EVGA think they don't know how to identify the 12V rail and solder on a plug of their own, and if they did, wouldn't it be better to use more than just a single molex plug? What's it add? 50W? Wow. That's a huge amount.
Here's what I'd do: go to the electronics store, pick up a $10 soldering iron, $3 of lead/tin mix, and $7 of wire. There you go, and you can use that however you like.
5,614 (1.07/day)
San Diego, CA
System Name White Boy
Cooling CORSAIR H100
Display(s) 1 Dell 30U11 30"
Case BIT FENIX Prodigy
Audio Device(s) none
So wait were taking a 5 v power source and using to to add "voltage stability" to video cards that take a 12v source?
I know on the SR2, and on the classified and on the Rampage 3, they have this feature built into the boards. But given that video cards have their own power source, but is this really going to work or is it needed, when the board doesn't come with it. I just don't see the point.:wtf:
I call it B.S, just like those gaming nic cards.
The killer 2100 actually works . .
Mussels
Freshwater Moderator
58,413 (8.19/day)
Oystralia
Case Fractal Design R6
Benchmark Scores Nyooom.
lol, the original image has one of 4chans smiley faces XD
I think the idea behind this is that if you have a cheap shitty PSU with poor power distribution over its 12V rails, you're using another rail to help boost the power to the PCI-E slot, reducing the chance of overloading one rail.
that said, i doubt a little thing like this could even handle enough power going through it to make a noticeable difference.
Wile E
Power User
24,318 (3.79/day)
System Name The ClusterF**k
Processor 980X @ 4Ghz
Video Card(s) Evga GTX 580
No and No!! The original EVGA classified was having 24-pin connectors melt because of excess power draw from the PCI-E lanes with quad 4890's. This only applied to extreme overclockers running 4x4890's over 1000mhz. From what Shamino says, ATI is the only ones that draw power out of spec from the PCI-E slots. The classified's PCI-E power traces are/were actually designed stronger than any other board at the time. Shamino released a hardmod to eliminate the melting by adding auxiliary 12v power to the 24-pin. In the end this is why the 4-way classified included the 4-pin molex.
http://www.xtremesystems.org/forums/showthread.php?t=226942
Yes only on the 4-way. They were the first to do this, but Asus and Gigabyte soon followed, but went as far as having two 4-pins.
Ok, so it was quadfire, but the point still stands, It was 4 OCed cards causing problems. I wasn't focusing on the specifics, just the overall situation. Could this help with that instead of modding the 24pin? Please note, this does not mean I support this product at this price.
And my old ECS KA3-MVP had a power connector for the PCIe lanes, evga wasn't the first, as far as I knew, unless of course you are talking only within the scope of this generation of hardware?
chuchnit
95 (0.02/day)
KY
No it is that when really pushing the voltage and clocks under load some, mainly ATI/AMD, cards pull out of spec power from the PCI-E slot. By pulling that much power through the traces and 24-pin it generates enough heat to melt the connector. You could have the best PSU in the world and it would still happen. It's just too much power for the connector to deliver and stay cool. There is a way to hardmod the card and feed power to the PCI-E on the card with a molex, but hell if I can find that mod. I have to have a guide with nice pics.
I have no clue if this thing works. In theory I guess it should and I would imagine EVGA had tested it. It's not like it needs to supply a ton of power. You only need enough to lower the load placed on the 24-pin.
Wile E said:
Well, wasn't it the Evga boards having Quad-SLI power delivery issues because their PCIe power sub-system was not up to snuff?
I bet this works for those setups, but that begs the question, why not just do it right from the beginning?
There is what you said earlier. You must remember that the original classified were designed for 3-way X-fire/SLI + physx card if using nvidia GPU's. It wasn't until the xtreme overclockers got a hold of the board did they try to run 4-way by modding thermalright HR-03's or using PCI-E extenders. Plus they were running four cards, under load, at 1050-1150mhz. Another thing to note was that this was the only board to even have this ability at the time. Not until the Classified 4-way and P6T7-WS boards came out did another X58 have the slots to do this. If another did it wasn't used because it couldn't perform as the Classified did on the CPU clocks.
5,614 (1.07/day)
San Diego, CA
This is why I was confused.
Poisonsnak
362 (0.05/day)
Saskatoon, SK
Processor FX-8150
Motherboard Gigabyte 990FXA-UD3
Cooling Thermalright Ultra-120 Extreme lapped & shimmed
Memory Patriot Viper Extreme 8GB DDR3-1866 9-11-9-27 1.65V
Video Card(s) MSI 6950 2GB Twin Frozr II @ 6970 875/1375
Storage Crucial M4 0309 64GB
Display(s) Dell U2410
Case Corsair 650D
Power Supply Corsair AX750
Software Windows [8] Developer Preview
My guess is the +12v wires are being load balanced, but the ground wires are simply connected to each other....
Hmm interesting idea on the load balancing, from looking at the PCBs I always thought they were all just connected together but maybe they aren't.
I guess the joke about the electrons being exhausted after work and going for beer wasn't too funny.
Wile E
Power User
24,318 (3.79/day)
Right, but some do now.
I'm just trying to figure out what this thing's market is, and if it actually works.
chuchnit
95 (0.02/day)
KY
Honestly I don't know, hehe. Most extreme benchers, where there could be a use for this, will be using boards with aux power already since the top benching boards have them. I just don't see a regular overclocker needing this. I mean I guess it could work in theory by taking some of the load off of the 24-pin and splitting it with this gadget. I still doubt it would make any difference for the average Joe. Hell I'm scratching my head too. :laugh:
1,334 (0.24/day)
wires of the the same connector all start from the same point at the PSU side. not sure about the video card side though.
9,899 (1.77/day)
Essex, England
System Name My pc
Processor Ryzen 5 3600
Motherboard Asus Rog b450-f
Cooling Cooler master 120mm aio
Memory 16gb ddr4 3200mhz
Video Card(s) MSI Ventus 3x 3070
Storage 2tb intel nvme and 2tb generic ssd
Display(s) Generic dell 1080p overclocked to 75hz
Case Phanteks enthoo
Power Supply 650w of borderline fire hazard
Mouse Some wierd Chinese vertical mouse
Keyboard Generic mechanical keyboard
Software Windows ten
Wait a second, don't most cards people overclock draw their power froma power cable or two and purposely stay within the pci-e line spec for the rest.
I.E won't draw more than 75w from the powerlines anyway?
Wile E
Power User
24,318 (3.79/day)
Some cards don't follow the spec when OCed.
9,899 (1.77/day)
Essex, England
System Name My pc
Aye but even then, they tend to overdraw from the power cables first right?
I mean even a pci-e 6 pin powercable can technically output the full 150w of the 8 pin if it wanted too ( the 8 pin just has two extra earths after all)
Although I suppose 480s would probably need to draw from everywhere when overclocked.
Wile E
Power User
24,318 (3.79/day)
Apparently, some ATI cards drew too much from the slots, which was causing problems with the 24pin connector overheating.
I don't know. Doesn't seem to me this has a very big niche to fill.
190 (0.04/day)
VT
It was brought out because of cries from the masses that EVGA had to do something about nvidia and ATI not following spec on their cards.
As chuchnit said this was designed to supplement power from the 24pin. Some people had their 24pin connector melt because nvidia and ati cards were drawing to much power through the pcie slots.
Wile E
Power User
24,318 (3.79/day)
Ok, so that begs the question: Why didn't they give the board more power connectors for the PCIe slots to begin with? I mean, they had to know 4 heavily OCed cards might overdraw on the slots.
This is one of those things where I see the point, but at the same time, feel we probably shouldn't need to resort to this.
And the price is retarded.
