EVGA precision tool problem
3xploit
275 (0.04/day)
Canada
Processor i7 920 @ 3.9ghz 1.33vLoad
Motherboard evga x58
Cooling TRUE
Memory 6x1gb Aeneon 1600
Video Card(s) GTS 512 820/2052/1107 + accelero s1 (2x 120mm fans)
Storage Western Digital 500gb SATA
Display(s) ViewSonic 22" 1680x1050
Case Antec Three Hundred
Audio Device(s) ONBOARD
Power Supply Tuniq 5501
Software Windows 7 x64 7100
I have two profiles set up:
1. stock clocks
2. oc clocks 810/2106/1152
I always use oc clocks when I play a game. In grid and cod4 it will switch back to stock clocks for no apparent reason. I have core clock in on screen display so I know it switches back to stock clocks in the middle of a game. Anyone else having this problem? I'm using extreme-g 177.83 drivers.
The program is loaded with bugs like this, it is kind of a pain in the ass. I prefer Rivatuner(made by the same person). It has a lot more features, and doesn't seem to be so full of bugs.
In my situation, I set the fan speed to 100% constantly, but for some reason it will revert to 30% which causes the GPU's to overheat in games.
This caused me to move back to using Rivatuner.
1. stock clocks
zero mine works great , didn't the guy who makes Riva tuner make the EVGA tool?
I dont have any probs with this at all. i find it a great little program. Is it right up to date? What version are you using.
Also the other thing I have noticed, do you have any hotkeys set for your Profiles? It could that your accidentaly hitting them in game or something.
thx for the fast replies
newtekie: yeah I'm probably going to switch back to rivatuner if this problem isn't fixed eventually but I hope they do fix this problem because i dont even need half the functions in rivatuner lol
trt40: yes I believe they are the same person, which is strange because I never had any problems like this with rivatuner.
alexp999: I'm using 1.3.2. Yes I do use hotkeys, profile 1 (stock) is f2 and profile 2 (oc clocks) is f4 so they are out of reach when playing games.
I deleted the stock clocks profile and it fixed the problem. Now I'm giong to try making oc clocks profile 1 and stock clocks profile 2.
