"Failed to Lock Vertex Buffer", Half Life 2 DM error
Joshmcmillan
892 (0.13/day)
Australia, NSW,Mid North Coast.
System Name Commander
Processor Intel i3 540 3.06Ghz
Motherboard Gigabyte GA-H55-UD3H
Cooling 4x 80mm Case Fans, Zalman ZM-MFC1 Fan Controller, Stock CPU Cooler
Memory 4GB DDR3 1333Mhz (2x 2GB) - Kingston
Video Card(s) HIS ATi Radeon HD3850 256mb DDR3
Storage 640GB Western Digital Caviar Black
Display(s) 22" BenQ FP22W LCD, 700:1, 5ms, 16:10
Case Don't know exactly, metal, built on LED's.
Audio Device(s) Integrated - Altec Lansing 5.1 Speakers (6.5" Sub)
Power Supply Antec True 550W, 24 AMP on 12v rail
Software Vista Home Premium 64bit - AVG - Spybot
recently I have been getting an error whilst playing half life 2 deathmatch. It crashed the game and comes up with an engine error saying, "failed to lock vertex buffer in CMesh DX8", or something similar to that. Does anyone know how to stop this?
Also, I'm getting an HD3850 on Saturday and reformatting, is there any chance of this error still being there, because people on the internet say that reformat and it stays?..:(:(
2,489 (0.34/day)
Ohio
System Name Onus
Processor E8500 @ 3.95ghz ~1.25v
Motherboard ASUS P5E Deluxe
Cooling Scythe Orochi cpu, 5x 120mm Zalman red LED case fans, stock GPU coolers
Memory 8gb (4x2gb) G.Skill PC8000 5-5-5-15
Video Card(s) 2x ASUS 3870x2s
Storage 4x160gb RAID 0 Main, 2x 500gb RAID 0 media storage.
Display(s) LG W2600H
Case Lian Li PC-A70B, painted black and other modded aspects :)
Audio Device(s) HT Omega Striker. Klipsch RF-3II fronts, Yamaha NS-A222 rears, Klipsch RC-3II center, Klipsch SUB12
Power Supply Corsair CMPSU-750TX
Software Windows 7 Ultimate x64, lots of games, photoshop n stuff.
The fact that it mentions DX8 is interesting. Are your graphic drivers up to date?
Joshmcmillan
892 (0.13/day)
I had a couple of month old display drivers on my intergrated 6150 and I upgraded as an attempt to fix the problem but it didn't. I have Direct X 9.0c.
I don't too much it not working now, I just REALLY hope it works when I get my HD3850.
Joshmcmillan
892 (0.13/day)
Anyone else have any ideas?
43,629 (6.36/day)
Memory 64GB G.Skill 6000Mhz
Video Card(s) Asus RTX 4090
Storage WD/Samsung m.2's
Display(s) LG C2 Evo OLED 42"
Case Fractal Design North
Mouse Razer Basilisk V3 Pro
Keyboard Epomaker 84 key
Sorry, but your integrated graphics just can't handle the game. The 3850 will solve that problem. Just be sure to install the new drivers correctly.
1,959 (0.26/day)
The Kingdom of Norway
Processor Ryzen 5900X
Motherboard Gigabyte B550I AORUS PRO AX 1.1
Cooling Noctua NB-U12A
Memory 2x 32GB Fury DDR4 3200mhz
Video Card(s) PowerColor Radeon 7800 XT Hellhound
Storage Kingston FURY Renegade 2TB PCIe 4.0
Display(s) 2x Dell U2412M
Case Phanteks P400A
Audio Device(s) Hifimediy Sabre 9018 USB DAC
Power Supply Corsair AX850 (from 2012)
Software Windows 10?
3850 will fix it easly :)
Kreij
Senior Monkey Moderator
13,817 (2.07/day)
Cheeseland (Wisconsin, USA)
Many people with different configurations are seeing this error on various games.
This was posted on one site ... might be worth a try.
ok this is a simple fix and i stumbled upon it while searching other forums for a os page pool memory problem.
BE WARNED THIS SOLUTION, IF NOT DONE CORRECTLY MAY BE HARMFUL TO YOUR COMPUTER.
Heres the solution:
Start Menu > Run > regedit
Surf down to this key. The REG_DWORD "PagedPoolSize"
Code:
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Session Manager\Memory Management
Double click on "PagedPoolSize". Hexadecimal is listed first.
Change the "Value Data" to one of these below:
Note: You only need to enter EITHER Hexadecimal or Decimal.
They both are the same. I recomend using 256Mb should solve the problem.
Code:
Megabytes Hexadecimal Decimal
192Mb 0c000000 201326592
256Mb 10000000 268435456
384Mb 18000000 402653184
You do not need anything bigger than 400Mb... in most cases 300Mb is too much as well.
Once you are done, make sure you reboot your computer.
howells1
1 (0.00/day)
Thanks Kreij for providing your registry edit. I noticed that the original post regards the CmeshDX8 error in the steam engine, but the edit also solves the notorious nv4_disp infinite loop BSOD error that many people with nvidia cards have been getting. I was certainly getting crashes on all source games until I tried your instructions, and voila: all nv4_disp BSOD errors, crashes, and stalls in loading vanished. Now my new Dell Inspiron is truly showing off its new hardware. And this is after I tried updating drivers, reverting back, trying third party modifications, pretty much everything short of returning the computer.
I have posted your instructions in the nvidia forum and linked my thread over there to this one. If there are people out there that still have the problems I had, I want to make sure they try this one!
Ketxxx
Heedless Psychic
11,521 (1.65/day)
Kingdom of gods
System Name Ravens Talon
Processor AMD R7 3700X @ 4.4GHz 1.3v
Motherboard MSI X570 Tomahawk
Cooling Modded 240mm Coolermaster Liquidmaster
Memory 2x16GB Klevv BoltX 3600MHz & custom timings
Video Card(s) Powercolor 6800XT Red Devil
Storage 250GB Asgard SSD, 1TB Integral SSD, 2TB Seagate Barracuda
Display(s) 27" BenQ Mobiuz
Case NZXT Phantom 530
Audio Device(s) Asus Xonar DX 7.1 PCI-E
Power Supply 1000w Supernova
Benchmark Scores Fast. I don't need epeen.
You own a Dell....? :shadedshu
Tric0ps
1 (0.00/day)
Kreij: Value data
Kreij,
So what how do i right in the value data?
:confused:
Reply plz:(
5,147 (0.73/day)
AZ
System Name Thought I'd be done with this by now
Processor i7 11700k 8/16
Motherboard MSI Z590 Pro Wifi
Cooling Be Quiet Dark Rock Pro 4, 9x aigo AR12
Memory 32GB GSkill TridentZ Neo DDR4-4000 CL18-22-22-42
Video Card(s) MSI Ventus 2x Geforce RTX 3070
Storage 1TB MX300 M.2 OS + Games, + cloud mostly
Display(s) Samsung 40" 4k (TV)
Case Lian Li PC-011 Dynamic EVO Black
Audio Device(s) onboard HD -> Yamaha 5.1
Power Supply EVGA 850 GQ
Mouse Logitech wireless
Keyboard same
VR HMD nah
Benchmark Scores no one cares anymore lols
directx issue, I actually got it with my 2900xt on Pirates of the carribean online. had to go to older drivers and force my directx in the game to get it to work. then magically one of their updates fixed it.
Haven't had the issue on my 9600gt.
you might wanna try forcing directx9
in steam right click HL2 deathmatch> properties > set launch options > type in "-dxlevel 90" without the quotes.
Joshmcmillan
892 (0.13/day)
Ancient thread. I've had my HD3850 for AGES, never had this problem since.
