fallout 3 games saves not working
820 (0.14/day)
Bristol-U.K
Processor Intel i5-12400F
Motherboard Asus Prime H610M-A WIFI D4
Memory CORSAIR VENGENCE 16GB LPX DDR4 3200MHZ
Video Card(s) RTX 4070
Storage 1TB SSD
Display(s) MSi Optix 27" 1440p 144hz + MSI OPTIX 27" 1440P 165HZ
Case COOLER MASTER MB320L ARGB
Power Supply Corsair cv650
Mouse Logitech G203
Keyboard Corsair Strafe RGB MX Silent
Software Windows 11 PRO
decided to have a blast
only to find that i couldnt continue from my last game save!!!
all my saves are still in my documents location
its just that the game wont recognize them
any ideas
have you updated at all? There are some bugs with the older versions on fallout and save games. And if you are using saves from a different patch they wont work either
If they were created using an xbox live account, you'll have to play via xbox live to access them. If they were created without an xbox live account, you access them by not logging in.
go do your intall folder and name the Fallout3.exe.cat to Fallout3.exe.bak!!! it did work for me:)
ur a star
worked like a treat
thanks man:toast:
That fixed it? I wonder why. My hunch was this had something to with Live. When logged into Live in-game it makes a new folder in the with your Live username and the saves are in there. You can just move them manually.
you should post this in FO3 forum, and thats probably because of mods
Adding mods shouldnt affect the saves. Patches either, they never did me. Sometimes if I launch from the launcher and not the shortcut to the .exe, it doesnt load up Live to access my game.
hey, i just registered to confirm something. it seems i dont have a Fallout3.exe.cat :eek: i'm using patch 1.6 so i dont know if that makes a difference.
i should point out though that im trying to load my saves from when i had no patches installed. so at this point in time i have old saves in the documents\mygames\fallout3\saves\username...
when i start fallout3 the continue and load options are blocked yet the saves are in the save folder. it seems i also cant sign in to live.
any help would be very appreciated as i was close to 100% completion but now have to start again :(
FIXED!
thats rather strange, i put the new saves back into the save folder but this time put one of the old save alongside the new ones. this time i was able to sign in and load a save including the old one! i loaded it and then saved the game. although when it saved it contiued from the new save list.
example:
old save list went from 01 to 88, the new save list which was started after the game was patched went from 01 to 11. i moved 88 into the save folder, loaded it and save the game and instead of being save 89 it actually saved as 12.
it still doesnt make sense that the old saves wouldn't just load though. oh well, hope this helps someone. also now i can play the dlc's continuing with lvl 20 :P
thats why i hate copy protection on games ,they will F everything up:ohwell:
BTW if you rename the fallout 3.exe.cat to .bak it will disable live file check so you can use non profile save games and it also lessens the game crashes:)
was this too me? like i said i dont have a fallout3.exe.cat and it seems i dont need one anyway. everythings working fine now although im getting some major lag in anchorage when my followers start shooting :confused:
in the process of updating my bios as i think i have a few compatibility isues with my RAM.
was this too me? like i said i dont have a fallout2.exe.cat and it seems i dont need one anyway. everythings working fine now although im getting some major lag in anchorage when my followers start shooting :confused:
well we are talking about fallout 3 not fallout 2:o
meant 3...lag in operation anchorage has me gobsmacked, no idea why its happening. sorry to compare to crysis but what the frik! i havent had lag like this in crysis ever!
i cant help you there buddy:ohwell:
