Fallout: NV problem
TheMailMan78
Big Member
22,598 (3.41/day)
'Merica. The Great SOUTH!
I just did a clean install of Fallout:NV and my OS on a new SSD. Now I'm sure this is a software issue but you never know. Anyway here is the issue.
The game runs great. However after a little while of play the sound (music) stops. Then after a few seconds the game just freezes and the ambient sounds keep playing. Then all of a sudden the game unfreezes and works normal. Only once did it crash completely to desktop.
Now I'm not sure if its my SSD or the new patch. It didn't do this before ether.....hope its the patch :laugh:
probably a bad install
psh that's not your pc, that's you laggin, lay off the crack man.
Have you added any audio codecs like ffdshow? (and if you added ffdshow, did you set FalloutNV.exe as an exception?)
Nope. Just the regular stuff. Nothing I ain't done before.
No thats tonight.
I've got a similar issue. Have been playing for a couple of hours now - before the patch I never had problems with NV. Now I got your same issue, but it only happens when I use VATS. And not every time I use VATS, it only happened like 3 times.
The fps falls to 0 then 2, 4 etc. Exiting and re-entering VATS kinda makes the game work again..
This game has been running so smooth for me and so bug free that I'll not install any patch. I'm 40+ hours in and at the strip. My game has crashed to desktop exactly twice during all of these hours. I'm just going to finish the game tonight anyway if I can. I'm ready to move on to another game now.
Then make sure you play offline for the rest of your gameplay otherwise steam will just install the patch for you. :ohwell:
I am currently testing these ini files by Crazyeyes. Someone else feel free to give them a go.
I bought the game myself last night and installed it along with the patch, no issues at all for me and im running a ssd as well... Like buddie recommended its probably a bad install
Verify it make sure none of the files are corrupted as mine was doing weird shit when i patched the game.
http://img.techpowerup.org/101119/Untitled114.png
I tried the ini file out but it made no difference for me. Fps remained the same, but then when I go in VATS mode fps drops to 0 - 5.
This didn't used to happen before the patch.
I've got a fresh Win 7 install, and only the one 160GB SSD (due to lack of space in case) and the only game I have installed is FONV.
mostly the ini file increases the number of cells to load and and memory that can be allocated for storing data aka entire cell data
default is 3 / 36 i upped it to 6 / 72
also increased ipreloadsize 2621440 to 104857600 basically going from 25mb of cell data at any time to 100mb increased Havok Thread count and increased Shadowmap size from 256x256 to 2048x2048.
I forgot to reset my New Vegas game to ultra settings tho so using the ini files means you have to re Max out the Graphic settings in the launcher again when changing over to them. I should have checked that but i forgot to re max the settings since the last time i played New Vegas i was running a 150 npc battle scene i was working on which even at 4ghz with dual cards still runs at 25fps at best.
Also increased the
Ugridstoload from 5 to 7
meaning the cell data for things on the horizon is usually cached and in some situations allows for greater detail at distance but comes with a fairly large performance hit for weaker gpus
Wait a second I didn't need to do that
Does the ini fix need to be applied to the ini file in the My Documents directory only or also to the ini file in SteamApps?
to both thats why theres 2 ini files in the folder mailman linked in order to add redundency and make sure it loads the proper settings
the fallout_default ini in the steamapps = default the launcher will load so you need to remax that with ultra in the graphics settings but otherwise it maintains the same edits i made to the regular ini file in the my documents folder.
you wont notice a huge impact but .. if you add the above and make New Vegas Large Address aware it does smooth things out a bit after all from what i know mailman went from unplayable to playable again with the above changes and a new dx9 dll
hell if you have the time you can now create your own dx9 dll file for any gpu period i was just lazy as the current dll fix works fine but if the ATi fix dosent work on say the 5000 or 6000 series card you have you can always make a DLL file that sees and labels your gpu correctly and forces the right shaders fixing that performance issue as well.
another tweak that can be tried if your using an SSD is to turn on harddrive caching in the ini file as it can help eliminate texture pop in(note thats its a rare fix dosent do much usually causes a performance hit as it trashes the hdd but with an SSD it should be fine and potentially help more often then not)
Mine doesn't use steam at all. So no worries there.
to be blunt tho even the new patch is a sorry affair the games still buggier then any other game using the same game engine. Obsidian just sucks at fixing stuff so most users should be prepared to have to edit a few things to get the ball rolling. :toast:
I solved the problem -
1) Tell Steam not to update the game;
2) right click on Fallout.exe in steamapps, click Properties, then Previous Versions, restore the previous patch (by copying it instead of the current Fallout.exe, and voila! :toast:
In my case at least that's for sure.
its different for different people for some the patch was a god send fixed all issues yadda yadda game runs like it was suppose to for others it caused massive issues worse then the previous version, Like anything tech related theres no end all be all answer to fix it yet
So for me I didn't even get a chance to play the game, Steam updated the patch straight away so I dont know what the difference is. All I know is it runs great, but now I need to learn how to play lol
run fraps and see what your FPS is when your playing and let us know what your fps is when you hit the vegas strip for the first time. Im willing to bet your gonna hit the wall BP hit on release where even a 5970 was brought to its knees :roll: but time will tell.
What :confused:
My fps have always been okay on the vegas strip.
Perhaps you're confusing me with somebody else? :)
Edit: You made me check my strip fps :laugh:
There is something funny there I never noticed it before. When I'm in front of gomorrah I have 60 fps,
then in the actual strip the fps dropped to 36/37.
Never noticed it before ...
