Finding out what program keeps changing Minimum processor state to 100%
33 (0.05/day)
System Name The Financial Mistake 2.0
Processor Intel Xeon w5-3435X 5.3GHz
Motherboard ASUS Pro WS W790E-SAGE-SE
Cooling Alphacool ES Jet 2U 4677, 2x480 Monsta + 1x360 Monsta / Phanteks T30 x22
Memory 4x16GB Kingston Fury Renegade Pro 7000MT/s CL32
Video Card(s) NVIDIA RTX 4090 FE
Storage 4x Samsung 990 Pro 2TB, Crucial P5 Plus 2TB
Display(s) ALIENWARE AW3423DWF
Case Caselabs TH10
Audio Device(s) Creative X3
Power Supply Corsair AX1600i
Mouse Elecom HUGE Trackball, ROG Chakram
Keyboard Mountain Everest Max
Benchmark Scores Time Spy Extreme: 19,874 Time Spy: 33,772
To be brief, something, most likely a program, keeps changing the "minimum processor state" from 5% to 100% and I have no idea which one, Is there any way to find out what keeps doing it in something like event viewer or any other tool?
tried google searching but got brain dead questions/answers that were not related.
9,340 (4.93/day)
Louisiana
Keyboard G710+x3
Xeon system ? which os 10-11 ?
This is a performance mode setting so I'd just switch to balanced again
Monitoring tools usually poll so much it would likely make it tougher to find anything.
But hwinfo64 can show stuff in a glance
I use the portable so there's nothing to install just run 64.exe shortcut to desktop
Check the box sensors only and start.
Opening page should show frequencies for each core current/ min/ max.
HWiNFO - Download
216 (0.12/day)
WorldWideWeb
System Name ROG
Processor i5-11400F
Motherboard ROG Strix Z490-H Gaming
Cooling Be Quiet Pure Rock (BK009)
Memory Kingston Fury RENEGADE KF3600C16D4/16GX (KIT 2x16)
Video Card(s) GTX1060 6Gb AERO ITX OC
Storage NVMe WD Black SN750 ; Samsung EVO 840 SSD and Mechanical TBs...
Display(s) iiyama Black Hawk G-Master GB2745HSU
Case CM HAF-X
Audio Device(s) Yamaha AV Creative DTT2200
Power Supply Corsair RM-1000
Mouse SteelSeries Rival
Keyboard MS Sidewinder X6
Software Windows 10/11
This is not valid enough info on a modern system these days, there's so much working in the background.
Being an MSI user, a few months ago back in the end of 2023 there's was an issue with the MSI SDK, eating 10 to 25% cpu to users, so the culprit was an app and usually its like so, so start by task manager and trace it back, services can be stopped, paused, delayed etc... its more likely to be an app/service than a driver or hw related, excluding a badly hurt OS integrity....
33 (0.05/day)
Case Caselabs TH10
HWiNFO - Download
Yeah Xeon system on Win11, normally i wouldn't be bothered about it but its a near 90w power increase when its not able to go idle
its not any monitoring tool polling that does it, I'm aware of such programs like crappy RGB software that spikes CPU usage, this is not that, I mean in the actual windows power plan the min processor state sometimes changes to 100% locking all 16 cores to 3.1GHz minimum instead of the usual 800 or parked which is why it could be a program that keeps setting power plan options themselves, task manager afaik doesn't have a way of showing what program is changing system settings, there isn't really anything installed yet aside from the usual asus intel driver stuff and steam/games
9,340 (4.93/day)
Louisiana
Keyboard G710+x3
I'm sure you have a shortcut to power options by now but here's an option to add it to your context menu and switch it easily
By the way I didn't say polling is your issue I said it may cloud what is going on with the added polling the app I posted does.
I'd look for weird power plans added that you don't recognize I'm sure you've restored defaults/... already so sorry for stating things like this.
Some ssd performance apps can add a power plans to optimize the device.
BitTorrent ?
33 (0.05/day)
Case Caselabs TH10
My apologies.
no bittorrent, qbitorrent is present but is not allowed to auto start
Yeah all plans were reset back to normal, I'm going to try deleting all the vendor stuff like alienware display command, ASUS armoury crate and icue etc
Its a pain to try finding it as I have no idea when it actually does it which is why i was hoping there was something that could record if a system setting was changed in a log or similar.
88 (0.15/day)
Could help monitor the registry and you could start programs and watch if any changes happen
Setup 2 filters, operation RegSetValue and path contains 893dee8e-2bef-41e0-89c6-b55d0929964c
edit: just to be clear you are using the balanced power plan? for high performance minimum processor state 100% is the default afaik
3,974 (1.92/day)
Thessaloniki, Greece
System Name PC on since March 2025, upgraded from 5900X
Processor Ryzen 7 9700X (March 2025), 150W PPT limit, 85C temp limit, CO -25, +100MHz (up to 5.65GHz)
Motherboard Asrock X870E NOVA, BIOS v3.2, AGESA PI 1.2.0.3a Patch A
Cooling Arctic Liquid Freezer II 420mm Rev7 (Jan 2024) with off-center mount for Ryzen, TIM: Kryosheet
Memory 2x32GB G.Skill Trident Z5 RGB (March2025) 6200MT/s 1.42V CL30-36-36-36-28-64 1T, tRFC:500, Hynix A-D
Video Card(s) Sapphire Nitro+ RX 7900XTX (Dec 2023) 314~467W (370W current) PowerLimit, 1060mV, Adrenalin v25.3.1
Storage NVMe: 990Pro 2TB(OS 25), 980Pro 1TB(22), 970Pro 512(19) / S-III: 850Pro 1TB(15) 860Evo 1TB(20)
Case Thermaltake Core P8 TG Gaming Full Tower, Fans: 9x140mm + 3x120mm
Software Windows 11 Home 64bit (v24H2, OSBuild 26100.3775), Install March 2025
When this happens do you see any high background activity also? CPU activity?
In windows settings, first icon >> Power option (not the power plan section) there is a slider there with 3 settings. How is that configured?
33 (0.05/day)
Case Caselabs TH10
Thanks, this is exactly what I was looking for, I have it set up as you instructed and will follow up with what program caused the problem when it happens again, for now I'll try messing around with all the peripheral/driver software programs first.
It caught the two times I manually changed the value so its good to go, yes it is on the balanced plan which should say 5% / 100% and look like this below
When I catch it at 100% / 100% all cores read as 3100mhz and CPU package power sits at 170w+, while not actually a problem functionally, for my system, the idle power is quite bad by design but made worse by this power plan issue.
9,340 (4.93/day)
Louisiana
Keyboard G710+x3
All I see is svchost which has always caused issues for many reasons in the past from windows activation to update searching....
