[Case Gallery] First mod
falkoner79
5 (0.00/day)
Processor Intel Pentium 4 2.4ghz@3ghz
Motherboard Gigabyte GA-8KNXP
Memory ddr400 1536mb
Video Card(s) GeForce FX5500
Storage SAMSUNG SP0612N 60GB, WD1200BB 120GB, Maxtor 6Y120L0 122.9GB
Display(s) CRT LG Studioworks 900B
Audio Device(s) M-AUDIO Delta Audiophile 2496
Power Supply Antec 400w
Software Windows XP pro SP3
Specs:
Abit KD7A
AMD Athlon XP +2700
Hynix DDR400 3x256mb
Sparkle GeForce FX5200
Samsung WriteMaster SH-S203N
LG Studioworks 900B
Mods:
Custom Paint Job,Cable management,Added few coolers
It`s my first case mod.
I Will repaint all case in black, and change few coolers
Why this two fanf id mounted on case not in case? And seriusly... Inside with grill this could looks fine :)
Very nice cable management, cracking paint job - like the guy attempted to say above, mount those 2 side panel fans internally then use 2 wire fan guards on the outside - maybe buy 2 $1 guards and spray them white / black? :toast:
cool graphics...fans on the outside are different (bet they get a lot of attention)
Nice job
it may not be the prettiest inside but its a nice first attempt. alot better than mine i can tell you. i do like the way you've mounted the fans to the side pannel
yeah.. those fans really made it not nice.. and those multi colored leds... other than that and the bad wirings, it looks good.
ok i will try to fix fans but it will take time. it was mistake
Aerocool make fans that mount outside the case, maybe the overall look would improve. But the build is clean.
I voted 9/10 because:
Awesome flames! and socket A is the best. Champion.
